Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
The batteries were running low on our Electronic Safe so my wife tried to change them. She removed one battery but accidentally closed the door before she could remove both and replace them. The door locked and now we cannot get in. Next to the keypad there is an override key hole which takes a cylindrical key but the key will not go in as the lock barrel does not seem to be lined up with the key hole. It was suggested that I spray WD40 in the hole and try gently tapping the key with a hammer but this did not work.
  • 10,865 Answers
Hello Peter. The WD40 may still work as it is a penetrating lubricant which continues to work for several hours after it is applied. I would recommend pushing the key in and pulling it out a wee bit and then trying to turn it, and also wiggling it.
If all else fails call your local lock smith shop and make an appointment to bring it to the shop in order to save a house call. Joe
Posted on Nov 08, 2010
My safe, a Cathedral EA15 Will not lock. Any suggestions people?
Instructions
  1. 1
    Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
  2. 2
    Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
  1. 1
    Enter your code to open the safe.
  2. 2
    Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
  3. 3
    Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
  1. 1
    Use your code to open the electronic digital safe's door.
  2. 2
    Locate and remove the battery cover on the inside of the door.
  3. 3
    Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
  4. 4
    Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Feb 08, 2015 | Locks & Locksmithing
How do i change the code on the S-25EBF safe
I'm not familiar with that safe but here's a few to try. You'll need to open the safe first in any case after opening then first try simply entering another code, lock it (with the door open) and try to unlock it,. Next, there may be a reset button inside the safe on the door press, hold, release and try entering a new code this may also require you to enter the original code w/wo some type of access code. As a simpler method, with the door open and electronics exposed, remove the cover plate and batteries, wait at lease an hour and replace the batteries, this may also start you with a code such as 0000. Can you tell me where you purchased it? This may help a lot!
May 21, 2014 | Safe International Digital Electronic Safe...
I have the key I know the3 combination but still i could not open because it's in low battery
if you know the battery is low then you need to open your safe using the keys and then change your batteries as the safe won't open using your 3 digit code if the batteries are low.
Jan 03, 2013 | Safe International Digital Electronic Safe...
How to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Nov 01, 2009 | Home Security
I forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Good luck
Sep 14, 2009 | Locks & Locksmithing
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
I have a sentrysafe t6 mode i cannot open as battery is dead
Locksmiths install sentry safe batteries this way
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the sentry safe battery holder Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Jun 07, 2009 | Sentry Fireproof Safe
Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Mar 22, 2009 | Sentry Fireproof Safe
How do I change an electronic safe combination?
hi, on mine if you open the door their is a red button press and hold for five seconds, then release put new code in then press again for 5 secs turn thelock to lock position do not close the door, put in the new code and see if it ulocks, if so, bingo, DO NOT CLOSE THE DOOR TILL YOU ARE CERTAIN THE CODE YOU PUT IN WORKS, hope this helps, mine only has a four digit code but i think its the same set up.
Feb 18, 2009 | Schylling Combination Steel Safe
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
62 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
