Question about PSC VS800 (0684000110000201) Barcode Scanner
My psc vs 8000 emits 4 long beeps on startup. these beeps continue as scanner is powered up Please lmk what I should do to repair problem Thanks Mannie
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
One of my Motorola HT750 radios makes a constant BEEP tone on all 4 channels. Worked the last time I used it with no issues. Took it to get reprogrammed and all of the setup/frequencies were fine. Could...
Typically any unprogrammed channels when selected will emit a long continuous beep. It is possible your radio has a programming problem, or a channel select problem, or another internal problem in need of repair.
Best regards.
Oct 01, 2013 | Radio Communications
What problem is indicated by two beeps at startup on a Dell XPS 8500?
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer.
Oct 06, 2012 | Dell Computers & Internet
Laptop beeps continuously on startup until "fn"
Number of Beeps: Failure Coverage 1) BIOS ROM checksum inprogress or failure. BIOS Chip 2) No RAM Detected No Memory Detected NoMemory Detected 3) Chipset Error (North and South Bridge Chipset,DMA/IMR/Timer Error for Intel platform); Chipset Error Motherboard FailureTime-Of-Day Clock test failure. Gate A20 Failure Super I/O Chip Failure KeyboardController Test Failure Motherboard Failure 4 )RAM Read/Write Failure Memory Failure 5 )RTC Power Fail. COMS Battery Failure 6 )Video BIOS Test Failure Video Card Failure 7 )CPU Cache test failure CPU Failure 8 )LCD LCD Failure
Apr 20, 2011 | Dell Alienware M11x (Intel Core 2 Duo...
Model JBGP80 MEV2BC Display panel shows "F1" and emits beeps (very annoying)... while unit seems now to be working fine otherwise. I will check and re-establish any cabling, etc. Meanwhile, how do I...
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Sep 16, 2010 | GE JGBP80 Gas Kitchen Range
Ms9520 buzzez and then will not scan
Look at your user's guide on Pg 14, here is a online link for it: http://lib.store.yahoo.net/lib/barcodescannersdiscount/MetrologicVoyagerUG.pdf "Continuous Razzberry Tone with all LEDs off: If, upon power, the scanner emits a continuous razzberry tone, then the scanner has an experienced an electronic failure. Return the unit for repair to an authorized service center." Is the "Razzberry Tone" the low buzzing you refer to(?) Pg 24 has a "Trouble Shooting Guide" take a look at it too.
Jun 06, 2007 | Metrologic Instruments METROLOGIC VOYAGER...
Acer Veriton 6800 PC Desktop will only beep will not boot.
Hi Just checking first of all you have tried another memory module. This sounds like a faulty RAM. Please try and get back to me if that doesn't fix it. Thanks, Lolita
Jun 02, 2007 | Acer Veriton 6800 PC Desktop
Computers & Internet Logo
Top PSC Computers & Internet Experts
Tom Chichester
Terry
Terry
Paul Jones
Paul Jones
Level 1 Expert
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
