Question about Kyocera Mita FS 1010 Laser Printer
1st page (only) top margin too large. - Kyocera Mita FS 1010 Laser Printer
Set page margins when Page SetUp does not work?
You should set up margins selecting and pressing with cursor at CUSTOM MARGINS, It should work.
Feb 24, 2015 | Computers & Internet
How do I fix Canon IR2200 not printing whole page. Large margins on top and cutting off bottom of page.
It sound like the paper tray is not set correctly. Probably set to landscape and trying to print portrait.
Jun 12, 2014 | Canon imageRUNNER 2200
Pt 65 margins
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Apr 20, 2014 | Brother PT-1000 Thermal Label Printer
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Check Your Margins
Select New Margins
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
I am a teacher. We have Dell computers with windows 7 on them. Recently our school district downloaded Microsoft Office 10. Since the new microsoft office, my xerox phaser 8500 is printing strange. ...
Hi fsaltzman,
You need to check the margin settings in the print preview option, make sure you decrease the margins that are set by default and try printing a test page , this should work fine.
On the File menu, you need to click Page Setup, and then click the Margins tab.
Here you can adjust the margins as per your convenience.
To View page margins :-
  1. You need to go on the Tools menu, select Options, and then select the View tab.
  2. Under Print and Web Layout options, select the Text boundaries check box.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
May 11, 2011 | Office Equipment & Supplies
When printing booklets the top and bottom margins are too large making the print very small. How do I change the margins and the font size?
The margins of top and bottom and print size and font size are all the options that given to you inside the software that you are using to print the books. Now you have not mentioned the software that you are using. The two most prominent software for writing and printing books are MS Word 2007 and Adobe Writer.
Lets say you are using MS Word 2007. When on the top menu bar you click "Page Layout" button. Then you play and select the parameters that suites you requirement like "Margins" button meets your requirements. You can also check with the "Size" for the Print page sizes. To change the font size in MS Word 2007 highlight the text you want to re-size and then right click after placing the mouse pointer on the text the integer number you will see will be the font size and you can change it according to your liking.
One good tip for you for most quality software that are used for printing is that they offer an option "Print preview". It will show you how your document will look like before you print it.
Good Luck!
Dec 20, 2010 | HP LaserJet P4015N Printer
Wierd margins from printer
Check your paper size setting at the printer.  It may think you are using Legal when using Ltr.
Mar 24, 2009 | Kyocera FS-2000D Laser Printer
Printing Large Top Margin
check the header and top margin in your application. (word, Note pad, etc..)
default top margin for Microsoft word is 1".
also check the orientation of the printer output.
Nov 24, 2008 | Samsung CLP-500 Laser Printer
Print is missing off top of page
What application are you using (w/ the document)? Margins sound like the problem. If you have changed any bottom or top margin, or added a footer or header, it may have altered the overall option on top of page.
Dec 18, 2007 | Samsung CLP 300 Laser Printer
Paper margin problem in pagemaker application
Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
Jun 24, 2006 | HP Color LaserJet 2600n Printer
Kyocera Mita FS 1010 Laser Printer Logo
52 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
