Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
I bought the Bosch washer - WFVC3300UC model and my plumber is here to install. Can the door hinge on the washer be reversed? I bought the compatible dryer and that door hinge reverses, so I expected this one to reverse as well. thanks.
5 Suggested Answers
textonor
  • 130 Answers
SOURCE: Bosch Dryer WTMC3321
Hello Teambrant, the screws are a T-20 torx for the door and T-25 for the hinge. You can use the T-20 for both if you need to. Open the door all the way, remove the screws, then as you close the door it will come off. This kit will have all the parts needed for the kit. You will have to have the kit to reverse this door. The plastic retainers slide down, I use a pop sickle stick to push them down.
Posted on Feb 02, 2008
  • 3 Answers
SOURCE: 500 WFMC3301 Bosch Front Loader
The door for this model of washing machine cannot be changed to open from the left.
Posted on Jul 17, 2008
SOURCE: washer door opens with hinges on the left
Don't you think it would really boost sales if you did make a washer that the front loader door could open left to right . For homes that have very limited laundry room. and no way to switch.
Posted on Jun 15, 2009
  • 74 Answers
SOURCE: Is it possible to reverse the doors on a Bosch
yes ,it is possible,you don't require a kit from bosch,however,you will need to disassemble the machine.if you are not confident,get someone who is.
Posted on Oct 16, 2009
I have a Bosch 300 vision washer which wont turn on. The lights are on and there is no error code showing does anyone know what might be wrong?
lights are on, but won't turn on? I don't understand. if it simply won't start turning after filling, this could be the motor brushes. if it isn't starting at all, you may have an issue with the door mechanism.
Dec 08, 2014 | Bosch Vision 300 Series WFVC3300UC
How do i remove bosch pedistal drawers
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 11, 2014 | Bosch WFVC3300UC 300 Series Vision Front...
How to change the door hinge
Link to PART:
Bosch Washer Hinge - AppliancePartsPros.com
http://www.appliancepartspros.com/bosch-washer-hinge.html
Link to VIDEO - "HOW TO REPLACE DOOR HINGE"
(scroll down half way at this link)
VIDEO: Washing Machine Door Hinge ' eSpares
http://www.espares.co.uk/product/es486275/washing-machine-door-hinge
Jul 09, 2014 | Bosch WFMC 2100 Front Load Washer
Bosch washer won't agitate or spin
brushes are spring loaded you take your motor out of the machine and replace them your machine will work
Jan 06, 2014 | Bosch WFVC3300UC 300 Series Vision Front...
The Front Door Came off of my Bosch WFL 2060 when a huge container of detergent fell on it while open. I think I need a new Rear Door Panel, Gray, Wfl 2060/WFR 2460 because the old one is damaged, but I...
I have same problem. Washer vibrated badly during spin cycle and door subsequently came off because back panel..Mfr. # 00432074 cracked near hinge. Looks to me like hinge must first be inserted before panel replaced. I do not have proper tool either.
Sep 29, 2013 | Bosch Axxis WFL 2060 Front Load Washer
I can't figure out how to reverse the door on my
You need a left sided hinge kit...here is the link to the part from Bosch http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodlg.htm?Maktx=wtz1260&eshoptype=A
There is a PDF on their site under "support" and your model number wtmc3321us that shows this on page 8. Hope this helps you! :)
Jun 11, 2012 | Dryers
I have whirlpool model 9450 dryer. Is it possible to change the door opening from hinged on the right side to hinged on the left side?
It advertises the door as being reversible. Sorry I'm not sure how to accomplish this, but maybe check for an online installation manual?
Jan 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bosch oven model HGS3052UC doesnt close tightly, hasn't since new 3 yrs ago. any idea how to fix?
yesthis is a common problem with this brand. 2 things can be done. 1. replace the hinges left and right or add 3 washers on both sides of the hinge to bring the door hinges closer.Im a old bosch tech and I told them this was a issue.
Dec 27, 2009 | Bosch HGS3052U Gas Kitchen Range
How can I reverse the door?
It is not normally possible to reverse the door on a washing machine, because of the door lock and hinges are not configured to be reversed.
I am assuming that you are in the u/k of course, because I do not know if it can be done on washers produced in the USA.
Hope this clarifys it for you.
Dec 12, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
How do i change which side the door opens
I have a different Bosch but changing the door over is straightforward.
1. Remove the plastic cover above the top door which fits over the controls. There are 2 screws under it holding it on. Lever it up from the back on top and it pops off.
2. Remove the hinge for the top door held on by 2 bolts
3. Take the top door off
4. Remove the central hinge between the doors held on by 2 screws
4. Lift the bottom door off
5. Pull off the bottm plastic cover
6. Move the post in the bottom hinge to the other side. It screws out
7 Replace the bottom door
8 Replace the central hinge on the other side (Take off any plastic caps covering the holes)
9. Unscrew the post on the top hinge (there are 2 possible holes left and right) and put it in the other hole.
10. Put the top door on
11. Bolt the top hinge back on the other side
12 Replace top cover and screws.
13 Move handles (unscrew and pull towards the door edge to get them off)
Jul 10, 2009 | Bosch Classixx KSR32623 Refrigerator
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
139 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
