Not working. In control panel/printers it says, 'Door Open' (which it isn't) rather than 'Ready'. Have tried disconnecting reconnecting etc.
    Champion:
  • 202 Answers
Hello ,first check for physical damaged then may be posible door will not be sited properly check for the door sencor then insert a pice of paper inbetween the sencor your problem will be resolved.
Posted on Nov 08, 2010
HP Desk Jet F4280 Printer
In Windows go to the control panel and click Printers. If possible open the print spooler and check to see if Windows is "stuck" on the print job that was in progress when the printer jammed.
Sometimes Windows doesn't "let go" of the pending print job and it will prevent further printing if it didn't get the message that the jam has been cleared. You can also try disconnecting the printer, open and close the print door and also remove and reattach the rear panel (if your printer has one). Then reconnect the printer and see if Windows properly recognizes that it is ready to print.
Feb 26, 2015 | Hewlett Packard - Desk Jets HP Officejet...
Why won't my printer print after I installed the software? It says its ready but nothing will print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
MY LEXMARK 1270 CANT PRINT NOR SCAN BUT ITS STATUS IS READY
2. Unplug and re-plug the printer into the power source to reset it.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aKlcOJ. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 15, 2011 | Lexmark X1270 All-In-One InkJet Printer
The printer will not print, and it keeps saying that the printer door is open, but it's not. I just replaced the cartridges, but I made sure the door was closed. How can I get this working?
You may try the following to resolve the issue,
  • Open, and then close the cartridge door of the product. Make sure that the door rests securely against the body of the product.
  • Check if the error message still displays. If it does continue with next step.
  • Inspect the cartridge door and the area around it to make sure that no obstructions prevent the door from closing completely.
  • Press the Power button to turn ON the printer.
  • Disconnect the USB cable from the back of the printer.
  • Disconnect the power cord from the electrical outlet.
  • Disconnect the power cord from the printer.
  • Wait 30 seconds.
  • Reconnect the power cord to the electrical outlet.
  • Reconnect the power cord to the printer.
  • Press the Power button to turn on the printer.
  • Reconnect the USB cable to the printer.
  • If the error is still there you need to send it for repair, as the sensor for the door might have gone bad.
Regards,
Shrey
Jun 05, 2011 | HP PSC 1315 All-In-One InkJet Printer
I cannot clear the "Door
Hi
When you open the print cartridge access door there is a black toggle switch that needs to be in the depressed position to let the unit know the door is closed. If the cartridge door is not completely closed, the error message displays.
1. Open, and then close the cartridge door of the product. Make sure that the door rests securely against the body of the product.
NOTE: To see how to close the cartridge door of your specific model, see the cartridge section of your product's User Guide.
2. Check the product control panel to see if the error message still displays.
If the issue persists, see the next step.
Check the cartridge door for obstructions
1.Inspect the door and the area around it to make sure that no obstructions prevent the door from closing completely.
NOTE: Bits of paper, packing materials, and tape might prevent the door from closing completely.
2. Remove any obstructions.
3. Check the product control panel to see if the error message still displays.
If the problem still persists you need to reset the product...
1.Press the Power button to turn on the product.
2.Disconnect the USB cable from the back of the product.
3.Disconnect the power cord from the electrical outlet.
4.Disconnect the power cord from the product.
5.Wait 30 seconds.
6.Reconnect the power cord to the electrical outlet.
7.Reconnect the power cord to the product.
8.Press the Power button to turn on the product.
9.Reconnect the USB cable to the product.
10.Check the product control panel to see if the error message still displays.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 10, 2011 | HP OfficeJet 7130 All-In-One Printer
I have installed the latest download for my Lexmark 715 printer on my new computer. It says the printer is installed and ready to print. However, when I try to print my computer does not communicate with...
Hello
Make sure that in control panel/printers. Yours is set as default.
Next try shuting down pc,disconnecting printer,then restart pc and reconnect printer.
Nov 30, 2010 | Lexmark Z715 InkJet Printer
HP 5610 all-in-one fake "paper jam"
I request you to please perform the below steps to reslove false paper jam..
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Sep 02, 2009 | HP Officejet 5610 All-In-One InkJet...
I changed the cartridges in my 1315. Won't print or scan and reads door open
The below steps is not confirmed that it a fix, but you can try the below step. This is called as a printer partial reset. Uses fixes most of the general issues. Clears the memory in the printer (speed dial etc..)
  1. Disconnect the power cord from the back of the product.
  2. Wait 60 seconds.
  3. Reconnect the power cord to the back of the product.
  4. When the lights on the product control panel begin to flash, press and hold the On/Resume button (c01590957.gif ) and the Size button. Illustration: Press and hold On/Resume and Paper Size buttons c01581916.jpg
  5. When only the On/Resume button (c01590957.gif ) is flashing, release both buttons. The reset is complete when the button light stops flashing.
  6. Try printing again.
Aug 04, 2009 | HP PSC 1315 All-In-One InkJet Printer
Deleting Printed Items
go to control panel, open the printer, open the lexmark x5100, select printer menu , then select cancel all documents, do this in offline postion.
also delete content of temp folder c:\windows\temp
Nov 12, 2008 | Lexmark X5150 All-In-One InkJet Printer
29 people viewed this question
k24674
jasbo
jasbo
