Question about Diesel Watch DZ7071
Can you tell me how to operate this watch - Diesel Watch DZ7071
Manual for watch xonix dg 300 wr 100 m
In many watches you have two separate batteries for the analogue part and for the digital part. I am not sure if this is true for your case. I would go to a watch maker to look at it ad change the two batteries.
Jun 22, 2016 | DG Watches
When replacing the battery in my Citizen 8946-095604-ta a small spring fell out ,could you please tell me where it goes, thanks
it goes in a small hole in the back of the movement of the watch and connects to the back plate when replaced to operate the alarm.
Nov 28, 2012 | Casio G-Shock GW500A-1V Wrist Watch
I have a new, purchased ar an auction so no paperwork a Cartier pasha woman's wristwatch. I don't know how to wind it. Please tell me
There are several models of this watch and you don't say which one you have but thi range are either automatic (which means that it is self winding) or quartz (battery driven).
If it is not going it could be
(1) (for a quartz watch) the winder has been pulled out (push it back in) or the battery has expired. (Do you know how old the watch is?).
(2) If the watch says "automatic" on the face, then it haas probably just run down (they run for 2-3 days if they are not used). If this is the case, holding the watch horizontally, swing it gently from side it side for a few minutes (this will operate the self winding mechanism) and the watch should then start. To keep an autimatic watch operating it needs to be worn daily or placed on a winder when not in use.
Aug 23, 2010 | Watches
My watch is not moving . I want to know do I need to change the battery or it is self wind? ref. 384858.Thanks
Its easy to tell if its battery operated or self wind. Turn the crown (where you set the time) forward. Self wind watches will click as you turn the crown. If its battery operated then you will hear no clicks. Some watches have a screw down crown so if the crown wont turn forward then try turning back. Some watches have a capacitor that needs to be charged! Seiko Kinetics are charged by movement like an older automatic. Citizens are charged by light!
Jan 09, 2010 | Piaget Watches
I need a user manual. The watch is a Bulova 96C35. Can anyone tell me where to find one?
Go to "bulova.com"
Select "Boluva"
Scroll right to see "Strap"
Select "Strap"
Select "Mens"
Select your model
Select "operating instructions"
Jan 03, 2010 | Bulova Strap 96C35 Watch for Men
I have agents rotary quartz with the number 3081 stamped on the back. the watch is oblong with a black black face and gold lettering and a date box. and gold intergrated strap. Would you please be able to...
Your watch is battery operated hence the term "quartz" All quartz watches are battery powered. As for value I'm not sure. The manufacturer of the module (mechanism inside) is a reasonable indicator of value. If its ETA then its in the upper range. You could try seeing if Rotary have a site if so they may allow you to identify details on age etc from the stamp numbers.
Jul 24, 2009 | Rotary Automatic Limited Edition Dark...
How to set time on Harajuku Lovers digital watch
See, you just have to hold the blue button (in TIME 1 "T1") till the screen tell you "LIGTH OFF", then push the green button and u will see all the option.
i found it by myself... i took time but i did it...
i hope this can help u...
see ya....
Dec 18, 2008 | Bulova Watch
Diesel Watch DZ7071 Logo
132 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Diesel Watch Expert? Answer questions, earn points and help others
