Question about Canon Cameras
The camera consistently looks up. I have to open the battery chamber to reset the camera. I can only take a few pictures at a time before the camera locks up. I have put new batteries in the camera and this has not helped.
  • 4,889 Answers
Well as you can see this is not a battery related problem. But before we come to the conclusion that its a faulty control board lets try a few things. Did you try formatting the card? If not back up all your pictures and format the card. Corrupted file systems are known to cause this freezing problem. Give it a shot and let me know.
Sai.
Posted on Nov 08, 2010
My WB550 turns on then a lot of times will zoom by itself but wont take pictures... buttons wont work different ones at different times...
1-Take the battery and the memory card out of the camera for few seconds.
2-Press and hold the power button for 10 Seconds
3-Insert the battery / batteries; please check the polarity direction.
4-Close the battery chamber cover.
5-Power on the camera again.
If the same issue occurred so in that case the camera needs to be repaired
Jul 08, 2011 | Samsung WB550 Digital Camera
My ex Z1000 wont take pictures. i turn the camera on the lens goes in and out some times it looks like its going to let me take a picture and then the lens closes back into the camera and the screen goes...
your camera problem has the problem chance. Fisrt you should try with full charge battery. sometime weak battery cause also. Second main pcb does not resetting every time after taking picture. I hope you luck! Would you give more detail problem...
May 21, 2011 | Cameras
The camera won't open at all
Can you provide any more detail at all?
How old is it?
Have you installed your batteries properly?
It is very easy to get the positive/negative ends of the batteries mixed up, and the camera will not power up that way.
Also, be sure that your batteries are not dead.
I'd like to recommend you try the Energizer BLUE lithium batteries. They are the only ones that give consistently good use, and more than a few shots before they die. We've had them last over a month before (and we take a LOT of pictures.)
When you are looking at your battery compartment, the
battery closest to the edge of the camera should have the FLAT side up, and the other one closest to the door hinge should have the "nipple" side up.
Hope that helps!
Oct 27, 2010 | Canon PowerShot A1100 IS Digital Camera
Canon rebel XS error 99
Instead of taking out the battery, just open and close the battery compartment to reset the camera.
SVRGuy02 is right, set the slep time longer to avoid the issue so much and just open and close the battery compartment before beginning each shooting exercise
May 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
FUJI S3000
My camera now works!!! Found a suggestion to clean the battery compartment on opposite side of switch with lighter fluid. Only had pressurized fluid for lighter so used rubbing alcohol instead. Put a few drops of 70% Isopropyl alcohol in chamber and clicked switch several times. Dried with hair dryer. Didn't work, tried again. Didn't work. Then tried a few drops of wd-40, clicked several times, rinsed with alcohol, dried with hair dryer, clicked several times AND IT WORKED. Still works. Thanks everyone(especially codmac) for the ideas.
Jan 12, 2009 | Fuji FinePix S3100 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Camera wont turn on unless i take the batteries out
I tried alkaline batteries in this camera and it would only work for a few pictures, then it would go unstable and do unpredictable things. The lithium batterys also caused problems like the ones you described. As a last resort I found that there was a ni-mh battery for this camera. I could not find this accessory. I purchase some batteries and charger then installed them into camera. reset the camera using the reset function, then tested camera. It now works correctly and consistantly takes good pictures. If the camera does not work with the ni-mh batteries it might be damaged or bad.
Jan 29, 2008 | Samsung Digimax D53 Digital Camera
Picture problem
If you're having like a bright picture with venetian blinds, you could try the steps below:
POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Return batteries
- Turn on camera
MASTER RESET
- Turn on camera
- Press MENU button
- Scroll to the right until you see SETUP
- Scroll down and look for RESET
- Press right button so you could see YES or NO
- Select YES
- Press MENU button
- Turn off camera for a few seconds so that
settings will be refreshed
* If it still does not work, call the Manufacturer so they
could tell you how to send camera for repair.
Dec 13, 2007 | Samsung Digimax S500 Digital Camera
Samsung 301
Rechargeable batteries, do lose their capacity if recharged when partly down- the best way to discribe it is to say they have a memory- but only remember the last bit to be charged. So put the batteries into a torch or similar and leave on until completely flat and empty- then recharge. So do that and buy some new batteries - a couple of sets of batteries are best to have any way. Make sure they are NiMah and the charger accepts NiMah. Then clean out the contact in the bottom the of the battery chamber with the eraser at the end of a pencil. and the contach on the cap. Do that first then come back.
Jul 15, 2007 | Samsung Digimax 301 Digital Camera
Cameras Logo
12 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
