Hp mini 110 1115sa hang on hp logo screen.. - Computers & Internet
  • 23 Answers
Well, I just want to comment something about it. I got the same problem and I am following the treads over the Internet and found a lot of complains to HP and few ideas; and for those whose guarantee is finished by this date, like mine, we got trouble and no real solution.
I reset hardware, and it didn't work at all. So, it seems it's just a little push for the HP Bios to work properly because the problem resists. I replaced the memory module and the same symptom. I didn't flash the Bios and didn't use the Recovery Software as those steps were mentioned not to work for this issue.
When the mini boot, I tested the Hard Drive with the utility from HP BIOS and it passed, also the Ram did. I tested them with third party software and passed, both mounted in this mini. Everything pointed out that replacing the Hard Drive would work. I installed a new 250 Gb Toshiba HD and at first boot a "clack" noise came from the HD maybe in the middle of the POST and it passed and the message that "select other boot device, bla bla.." appear. Good, but at the second try, the same problem came out: HP mini hangs on the HP logo screen. Please, any ideas will help this community. Do this new drive is bad too?
I feel some overheating, (I don't know what Atom temperature should be), by the dissipator and guess it would freezes the POST routine, or simply the BIOS is malfunctioning. I noticed that when the mini was turned off for a long time, it boots without problems even with the original hard disk and it loaded and worked fine in windows 7. Besides, I could start a Disk Clone process in order to get the same original installed software from HP. But this failed, too. Norton Ghost report "an internal inconsistency error". I guessed this was because of the bad sectors the original HD would have. After this step. I got acces to both disks using Partition Magic and other tools, even though, I partitioned the new HD. I just found a partiton table error in original disk and was fixed by Partition Magic. Everithing, as I said, looked great to remove the original HD an install the new one. But you already know.
Again, any help will be appreciated. Thanks for reading.
Posted on Jan 27, 2011
GLUE HP LOGO ON BACK OF SCREEN
just put where it was originally......thank you for using FiXyA
Jul 26, 2012 | Computers & Internet
HP 4530s hangs at HP screen
Sub out the ram memory one at a time, next remove the hard drive and reseat it back in place, if none of these work try your recovery disc if possible, no change! have the hardware tested for possible replacement.
Jul 02, 2012 | HP Computers & Internet
My mini HP 110 doesn't boot, it hangs on HP logo screen. After several tries it boots and takes about 5 minutes to pass the Post then everything goes fine. You can still work for hours, and that is the...
There may be a problem with some other device besides the hard drive. Try running the new hard drive for some time and see if the problem creeps back up. If it does, you may have some type of bus device issue; memory, Bluetooth controller, USB controller, etc...
Jan 27, 2011 | Computers & Internet
Hi, i have a mini 1000 xp, it will show the hp logo and says press f9 or f10, but after that the screen will not load if dont click any button, it stays on black screen
It happens like that only when the Operating System fails to load correctly. Insert your OS CD and perform a repair. This will identify damaged files and reinstall them. If this procedure doesn't work, you will have to install a new copy of the Operating System.
Jan 05, 2011 | HP Mini 1000 Netbook
HP LaserJet P3005N - Printer will not start, it hangs on HP logo on screen on power-up. Thanks, SDR
Formatter failure worst case, try reseating the RAM, located behind the right side cover, slide it rearwards and off, open the metal door and if any DIMMS are installed, remove and replace them.
Dec 15, 2010 | HP Office Equipment & Supplies
Sincerely, Previously introduced: Name: Albert T...
There is a coin cell battery inside the netbook that needs to be changed.
Mar 29, 2017 | HP Mini 1000 Netbook
Will not boot up. Screen displays Window XP
Use your original Windows XP CD and run the recovery console when starting up the pc. Thats should repair any files which are hanging the pc at the XP logo
Oct 13, 2009 | HP vs17
Computers & Internet Logo
432 people viewed this question
David Payne
David Payne
