My f28 boiler is letting water out all the from the run off valve
    Genius:
  • 1,015 Answers
I assume you are talking about T&P valve. This stands for temperature and pressure relief valve and is a safty valve. Under no circumstances should they ever be plugged to stop leak. Chances are its just getting old and the spring that hold it shut is getting weak or rubber seat that seals it is getting worn. Valve should be replaced. If you feel comfortable doing this you should turn gas valve to pilot,shut off water supply and electric power. Remove valve.You will probably need a pipe wrench as they can be very tight.If it is standard 3/4 inch thread you can get a new one at most hardware stores. There should be a rating tag on the valve that will tell you the size,pressure and temperature rating. You may have to go to a plumbing supply outlet to get the right one. One other thing I should have said at the start is after you shut off water supply you should drain a few gallons out of boiler .be careful as water will be very hot.If your drain valve doesn't work wait 1-2 hours before you remove old valve.You will splill some water,but at least you wont scald yourself.Reinstall new valve using teflon tape or pipe thread compound to seal threads.Turn water supply back on ,gas valve back to on and electric power supply. Check for leaks,and you should be done. Hope this helps.Thanks
Posted on Nov 08, 2010
    Genius:
  • 1,400 Answers
Hello
This is a relief vave,probably rated for 30 psi.You either have air in your heating system causing the pressure to go up.
Or you need a new relief valve,sometimes the springs wareout or rust and iron from the water keep them from reseating properly.
You should have 15 to 20 psi of pressure on the boiler if its 30 or over you need to bleed air from the highest radiator or baseboard,if there is a 2nd floor go up to one and find the bleeder and bleed out air.Be carefull once the water starts coming it will be hot.
Valiant Eco TEC 831 boiler had f28 fault, external condense pipe frozen? Treated with warm water. Restarted ok then drppoed and water dripping from under boiler
There are a lot of boiler issues in the UK at the moment!
My GUESS is that the water freezing has either popped the joint or split the condensation pipe where it enters the boiler.
Mar 02, 2018 | Water Water Heaters
How to remove airlock from hot water system
At the boiler should be a purge setup. This consists of a valve to shut the zone off, and downstream of that valve is a drain ****. Attach a hose to the drain ****, and with the boiler running, close the valve and open the drain ****. (Turn the heat up on one zone at a time if you have multiple zones.) You should be able to notice when the air comes out of the hose by hearing it and the hose twitches and jumps when large amounts of air come out. After the air stops coming out, open the valve , close the drain, flip the bypass closed, and let the water circulate, then reapeat procedure. Do this until you hear or see no more air. You can run a long hose outside or you can use a bucket and a short hose. Using the bucket allows you to actually see the bubbles of air, but you will be dumping many buckets before you are done. Most boiler feed valves have a fast fill lever that bypasses the slow 12 psi that the boiler is normally fed at. Using this will speed up the purge considerably, but don't forget to flip the lever back down between, and after purging or the boiler relief valve will blow off and make a mess. Good luck!
Mar 18, 2017 | Water Water Heaters
Hi the pressure in boiler is very high and dripping out side its not the water valve intake been told its the heater exchanger
There should be a water pressure reducing valve in the make up water line. This valve or regulator should keep the boiler pressure at about 10- 12 pounds. It sounds like that valve is letting more pressure to the boiler than it should. There is also an expansion tank that works to keep the boiler pressure at 10 pounds. The rubber seal inside can go bad and the tank will fill with water.
Feb 27, 2015 | Water Water Heaters
Why can't i fill my boiler
You didn't specify what kind of boiler you have. Some low pressure steam boilers have a manual fill valve as well as an automatic float switch valve. Hot water boilers have a pressure reducing valve that constantly monitor the boiler pressure and maintain 12 to 18 PSI for the safety of the boiler. If the boiler runs out of water there is a good chance it will rupture and become unrepairable. If you are saying your boiler won't fill, and its a hot water boiler, the pressure reducing valve is probably blocked with sediment and needs replacement. The valve is in the water line that feeds directly into the boiler return line from city water. Hope this helps.
Oct 01, 2014 | Water Heaters
I HAVE A WATER ONLY BOILER MODEL WR11E IT IS ONLY 6 MONTHS OLD AND THE PROBLEM IS THE WATER IS ONLY LUKE WARM AND NOT HOT AS IT WAS BEFORE
Turn the boiler off. Connect a garden hose to the drain bib. Shut the water supply valve off.
Open the drain bib and drain boiler. Close drain bib and open supply valve.
When boiler is full, go to the farthest faucet and open the hot water and let run.
Go back to supply valve and turn off and on a couple of times rapidly this will "bounce" sediment loose.
Repeat above twice.
Nov 08, 2010 | Heating & Cooling
Code f28 what isit?
According to the user's guide, the fault code means that the boiler failed to start after 5 attempts. Here is the manual where I got the information. I would confirm the codes with your particular model. I am presuming that the codes would be standard for all their models. Source(s): http://www.vaillant.co.uk/stepone2/data/…
Mar 10, 2010 | Water Heaters
Amtrol water heater WH-7P gets barely warm water
From what you are saying it sounds like an issue with either a circulator pump or a zone valve. It depends on what type of system you have ... if you have a circulator pump that only runs the Amtrol then that is probably bad. If you have a zone valve system then it is probably the zone valve if you still have heat for the rest of the house. If you have no space heating then it is probably the circulator pump.
Nov 04, 2009 | Water Heaters
Re-pressure Vaillant Turbomax Plus boiler
two pipes coming into boiler on right hand side have brass block valves with a small round recess. These two valves are linked with a stainless fill hose.
Inside the recess on each valve is a small slot, there is a "key" with the boiler but prob lost with the manual. The advantage of the key is its sized so you wont be poking it in the wrong place!
Using a screwdriver turn both slots throug 90 degrees, you will hear water running through. Sometimes one valve is left open so try a combination until the watert runs.
Keep an eye on the pressure gauge and dont let it get too high, if you have no idea of setting pressure head for about 1bar.
Apr 04, 2008 | KDS Valiant 6380iPTD-01 Notebook
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
