Question about Amana Dryers
Making a loud noise when i turn it on I think it needs a new belt
  • Amana Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Nov 11, 2010
My car keep on breaks alternator belts and it also makes this loud whistling noise. I've put on a new water pump, 3 alternators and several alternator belts
make sure that the pulleys of all the driven equipment are in alignment and not at a bit of an angle to the axis of the drive belt
To break belts something is not lined up properly or something is not turning freely
Dec 31, 2015 | 2000 Mazda Protege
Why is my making a really loud noise and smells burnt when I turn it on. I have a new belt on it.
Improper installation of belt can result in a loose or off center belt which will flap and make lots of noise. It can also result in the burning rubber smell. The belt is probably ruined now, and will need to be replaced again. Make sure new ones are installed and centered correctly.
Oct 03, 2010 | Sharp Vacuums
98 Merc grand marques on cold start engine makes loud hammer tapp
Do you have the defrost on when it is doing this? Turn it off and see if it goes away. I'm still thinking A/C compressor.
Mar 30, 2010 | 1998 Mercury Grand Marquis
The dryer is making a loud noise. Think its the
the belt that spins the dryers drum around has a belt tensioner located at the botton base of the body. If the roller bearing goes bad the sound you hear is caused by that. Replace the belt as well when replacing the roller or the whole tensioner if needed
Feb 06, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Just replaced Serptine Belt now car making loud
It's not uncommon for a new belt to require re-tightening soon after it's been replaced. Check the belt for any excessive slack (shouldn't have more than 1/2 -3/4" ). A loose belt would be one possible cause for the loud noise you describe.
Jul 15, 2009 | 2003 Cadillac CTS
Front loading kenmore 86983110 makes loud noise when turned on. Think that there is a problem with the belt. I am tryng to take it apart now and do not know how to find the belt
The belt is located at the back of the appliance.
To remove belt you have to remove a panel at the back, on some model you remove top panel first.
The belt does not make loud noise. Loud noise when spinning is usually caused by bad drum bearing, located at the back of the drum.
Regards.
Jul 13, 2009 | Kenmore Dryers
Really loud noise.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40860&thid=810370
Really loud noise.
Posted by Theresa626 on July 20, 2008
The belt inside my Hoover broke and so we replaced it. But when we did, it now makes an extremely loud noise when turned on. We think it’s the roller to the vacuum because it doesn't make a noise when the roller is not in there. The roller sounds like its hitting something. However, we have pushed and pulled and done everything and all seems to be right. Everything is clicked in and the belt is on correctly and we've followed the manual. How can I fix this problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that it is a bad brushroll and could need new bearings or a complete new brushroll depending on if id is metal word or plastic. Some brushrolls are rebuildable and some are not, you can check your owner’s manual to see if it is or is not; or it could be the start of a broken fan blade or bearing in the motor section. But that is the only thing that I can think of that might be wrong. Feel free to contact your local vacuum cleaner dealer in your area or you can also contact the Hoover website or cust serv phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 20, 2008 | Hoover U5018-900 Bagged Upright Vacuum
Squealing NOISE possibly from fan belt
If the noise going away every time u turning off the ac it's probably your ac compressor belt.however i will suggest to take some vaseline and rub it all over the exposed parts of your drive belt.
Jun 22, 2008 | 1998 Dodge Caravan
Loud noise -- water pump??
Yes you definately need a new pump assembly part number 21001906 $59.95. That is a maytag part number and it is a very common repair. The new pump is a revised design and will look different but will mount the same. Axcess through front panel.
Nov 25, 2007 | Maytag MAV7200 Top Load Washer
Brush bar does not turn & makes a loud noise
Hi.
You either need A new clutch or clutch belts need replacing.
Its a lot to describe so try this it has manuals on how to do the job.
http://dysonmanuals.inc.io/
Oct 14, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dryers Logo
Top Amana Dryers Experts
Sal De
Marvin
Marvin
Android Man
Android Man
Are you an Amana Dryer Expert? Answer questions, earn points and help others
