Question about Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height
I NEED A TANK GASKET - Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height
  • 28 Answers
You should be able to go to your local hardware store for a replacement. Remove the one currently on there by removing the tank from the bowl.
Posted on Nov 08, 2010
How to replace a toilet gasket in the tank ?
You dont need any special tools are you taking tank off and pulling off the gasket and installing new one on the bolts
Oct 01, 2014 | Kohler Home
I have a pegasus 164-146. need a toilet tank gasket that the tank sits on to connect to the bowl. Cant find one anywhere
You need a spud washer.
Or a gasket and bowl kit.
Or toilet tank gasket
Or tank to bowl gasket
1) Fixya answer from last year says Lowes/ Home Depot sells part
Home Depot sells Pegasus toilets
http://www.fixya.com/support/t5647268-need_tank_bowl
2) Plumbing supply dot com has selection
http://www.plumbingsupply.com/tank_gaskets.html
http://www.plumbingsupply.com/closetspuds.html
Company also has contact page:
http://www.plumbingsupply.com/email.html
3) http://www.plumbingworld.com/toilettankgaskets.html
4) If gasket is not torn apart, you can probably seal it again using rectoseal on both sides of washer. This is how I fix problems. Buy rectorseal from home center.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on toilet or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 01, 2011 | Pegasus Technologies Two-Piece Round...
I dropped a gasket from the cap of an STP Carburator/Injector Cleaner bottle into the gas tank. Normally the cap gasket never comes off, this time it diod and the wind blew just right where the gasket...
Your fuel petcock has a filter on it that should not be affected by the gasket. If the gasket is paper and will deteriorate and cause problems , by all means get it out. If it is just a round plastic circle the size of a quarter it will not affect anything sitting in the tank. If you decide to retrieve the gasket , drain the tank, take the tank off, turn it over , and remove the fuel tank sender and you should get good access to the interior of the tank. If there is a splash of gas left in the tank it will help you wash the item to a position where you can see it and reach it with a long grabber or tweezers . Please NO SMOKING during this procedure.
Nov 04, 2010 | 2000 kawasaki ZRX 1100
Installing new jacuzzi 1.6 gallon maxima toilet. despite following the instructions, the water is leaking from between where the tank connects to the bowl. Please help.
Yes, it seems the folks who wrote the instructions have never actually done any plumbing.
first place a rubber washer on the bolt, then put it through the hole in the tank. Then place another rubber washer on the bolt, followed by a metal washer and a nut. Tighten the nut, not the bolt.
Using a screwdriver hold the bolt in place, and tighten the nut until snug and the rubber washers are compressed slightly.
Follow this step with all the "tank to bowl" bolts.
Now the bolts are tight to the tank and will not leak water.
Then place the large rubber gasket over the flush valve hole on the bottom of the tank. and set the tank on the bowl with the bolts through the bowls holes.
Place a metal washer on the bolt, and then a nut.
Tighten each nut equally until the tank has no wobble.
Oct 01, 2009 | Jacuzzi Bath Maxima EL61 959 White...
Mustang gas tank removal
yes to do it the right way you should take the tank out of the car empty and rinse out then replace when completly dry
Jun 24, 2009 | 1996 Ford Mustang
I need torque specs.for head and centerhead when replacing new gaskets.
never have used a torque wrench to install toilet tanks. Put gasket on tank and insert bolts with rubbers washers through gasket and set tank on bowl in a level and straight postion and start nuts tightening them evenly until tank starts to snug to bowl. Hand tight is usually sufficient, you will see the rubber gasket and washers will compress to bowl and tank forming a seal (EVENLY) and tank will be firm to bowl. DO NOT superman torque these nuts! Compare the torque to finger strength on a wing nut. Hope this helps ,"if I understood the question."
Mar 22, 2009 | Kohler KOHGP51487 Authorized Original...
Water Tank Leak
i had the same problem what i suggest to you clean where the water tank were its sit very good put the tank back me i never remove the water tank i clean regualy i put the tank empty on the machine and fill it with a glass never leak again pierre
Dec 08, 2008 | Saeco Vienna SuperAutomatica Coffee...
Water tank stay's on
2 things. Water tank has a magnet in it (little rectangle black plastic piece on the backside). Thats gone bad. need a new water tank.
2nd is you need a water tank gasket.
Gasket is easy to fix, flathead screwdriver.
May 13, 2008 | Saeco Magic De Luxe Espresso Machine
Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height Logo
76 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
