Question about Traeger Industries BBQ125 All-in-One Grill / Smoker
BBQ 125 HOT ROD REPLACEMENT - Traeger Industries BBQ125 All-in-One Grill / Smoker
I have a remote meat thermometer unit. I don't have the sensing tip that goes into the meat. How can I get a replacement
Most of these are generic. If you don't have a local BBQ store, try searching "bbq replacement probe" at Amazon. If you know your thermometer's model number or name, you can add that to your search.
Jul 21, 2017 | Grilling
Treager bbq keeps tripping breakers
I would strongly recommend you pull the control panel and inspect the fuse. Before tripping a breaker, your GFS outlet should trip, and/or blow the fuse.
If the unit is tripping circuits, then there is likely a short. Given the material draw from the hot rod, I would start with that. Putting a multi-meter on it to test voltage, should give you a basis to confirm with Treager if it's within spec. Sometimes it's simpler to replace the rod, but this can add up quickly if not the root issue.
Dec 26, 2013 | Traeger Industries Grilling
GPS-75-200 anode replacement
The anode is located under the power vent.
Remove power vent to gain access.
Otherwise, remove Hot water nipple and install combo anode rod. If odor is the reason for replacement, then installing a combo without removing the old anode will not solve odor problem until old anode completely dissolves over time.
Copy following link for specific information and illustrations, including odor elimination using hydrogen peroxide.
http://waterheatertimer.org/Replace-anode-rod.html
For easy access next time, you can remove old anode and plug hole, and then install combo rod.
If longevity of tank is reason you are accessing the anode, you can add a second combo anode in addition to the original anode and give longer protection
Aug 07, 2012 | RTO W4 A.O Smith Gas Hot Water Heater...
Bull bbq doesn't get hot enough?
Try cleaning all the burners they may be block and all the orfices.
Jul 04, 2012 | Bull Texan Grilling
I need a new thermostat for my BBQ, where can i get one
Try Calary bbq center the are on line , they could well help you.
May 20, 2011 | Heavy Duty BBQ Parts Igniter Wire...
How to char-broil burgers
You want to know how to char broil hamburgers right? Here is what you do! Start your BBQ 5 to 10 minutes before you put your burgers on (for gas BBQ) and let the metal racks heat up. Keep the top closed to let the heat go through the unit.
If your using a charcoal bbq wait until your coils are white hot and the racks are as hot as you can get them.
Don't buy the hamburger meat that has the smaller amount of fat in it. Get the stuff that has 15 to 20% fat in it. The juice in the fat will help cook the meat and taste better in a burger.
Put your rack on the lowest place as close to your fire/coals as possible.
When the bbq is hot Take your patties and plut them on the rack. If its hot enough you should hear a sizzle sound. DO NOT TURN THE MEAT. Let it sit on the grill and every few minutes take your spatula and press the meat flat on the grill to release more juices and get more attention from the flame or coals. This is what makes the black grill lines on the meat.
You only flip a grilled burger one time after putting it on the bbq. It should cook at least ten minutes or more on one side. If you turn the meat and there are no marks on it then you didn't wait long enough.
Sep 29, 2010 | Computers & Internet
Need a lid pivot
try google the bbq or the bbq centre in calgary
Jun 28, 2010 | Napoleon Prestige I P600RB Propane Grill
How to install power rod on a 2001 kx85,we did a piston and ring replacement and the power rod came right off, but how to reinstall is the problem
when your putting the barrel back onto the piston start lowering it down. when you lower so far swing the power rod into posistion cause you cant fit it after you have reinstalled the barrel. hope this helps just fitted a new piston and rings on ma kx80 and a had the same problem lol
Jun 11, 2010 | 2003 kawasaki KX 125
Need a manual for a Jumbuck Endeavour 4 MKII BBQ.
Need assembly instructions for a Voyager 4 Jumbuck BBQ, no more than two years old. Our daughter recently moved, the BBQ was dismantled by the removalists and she is now unable to find the assembly manual.
Many thanks
Rod Gilbert - rod.gilbert@hotmail.com
Apr 20, 2010 | Grilling
Traeger Industries BBQ125 All-in-One Grill / Smoker Logo
55 people viewed this question
Top Traeger Industries Grilling Experts
Gary Kenady
Gary Kenady
Craig Butler
Craig Butler
Paul Carew
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
