Question about Pentair Minimax Ch 250,000 Btu Natural Gas Pool Heater Millivolt Ignition
Which jets go with bottled gas?? Small or big?
  • 990 Answers
Small, due to higher pressure in the tank. It use's smaller orfaces to slow the gas down.
Posted on Nov 08, 2010
Can i replace the jets on cookmaster cooker to work on bottle gas
Bottled gas reqires a different gas nipple, most new hopbs come with a set. Note that in the UK you need a gas safe qualified engineer to fit gas appliences to the mains. Not sure about bottled gas appliances.
Aug 23, 2016 | Kitchen Ranges
Burner won't light on both sides of burned
The burner is lighting back to the injector on the gas control. 2 things burner out of postion or burner is blocked needs cleaning, you can remove this and clean with air line or small bottle brush.
May 20, 2012 | Grilling
Just put in a new Caldera LPGas cooktop the flame is yellow and putting soot on pots how can I adjust air to correct this?
you stove may have jets for natural gas rather than bottled gas the calorific value of natural gas is different to propane and the jets are larger because of this. if using bottled gas then you will get yellow flame and soot because there is too much gas to burn properly check your installation manual for procedure to change the jets for each gas
Dec 19, 2010 | Stainless Caldera SSK-305 Steel Gas...
Gas igniter not working on small electrolux 3 way frig. any suggestions please
Sounds like you did your homework ... this is my last thought ... has this problem gone on long enough that the air has been bled out of the gas line going to the frig and is the little valve on the burner in fact open and is the power to the valve on and connected so gas can get out when the frige wants to ignite? Check your fuses on the control board at the back of the frig.
Thanks for your interest in FixYa.com
Sep 29, 2010 | Electrolux Refrigerators
Jet size differnce from natural gas to bottled
You will need more then new orifices to convert from natural gas to propane. The gas valve will also need to be replaced. Not a good idea converting heater.
Jul 12, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
My Q 120 grill will not produce a high enough flame with hose adapter for 20 pound lp tank , works fine with small tanks. I have had problem for several years. Have replaced adapter hose and regulator.
Often with a big bottle, people turn the gas off and on at the big bottle and leave the grill valve open. That makes the regulator see a low pressure on its output, which is a potential leak indication. It goes into "bypass". Try turning off the tank, turning off the grill valve, and turning on the tank, then waiting 20-ish seconds before turning the grill valve on.
Aug 09, 2008 | Weber Q Grill
Pentair Minimax Ch 250,000 Btu Natural Gas Pool Heater Millivolt Ignition Logo
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
