Question about Dishwashers
D1786 Asko dishwasher soap dispenser wont latch shut
  • 10,865 Answers
Hello. Sometimes the cup will just get a build up of mineral or detergent on it that will cause it to become inoperable. If the cup door is hard to close or does not release easily, then a good cleaning may be all that is needed to get it working properly again. The best way to do the cleaning is to heat a cup of water up to very hot [close to boiling] and use a small brush like a toothbrush to clean all of the soap residue out of it. Rinse it a few times until the residue is gone.
Another cause could be the wax motor switch. On newer dishwasher they have a wax motor in which the wax is heated. This pushes a piston out which mechanically opens the door. The Timer activates the heat to the wax motor. Next is the bi-metal switch. These also are activated by the timer. These bi-metal switches will move or deform when electric which cause a bit of heat, is applied.
ALL of that said, another way around this door issue is to switch over to a dishwasher tab such as cascade which you literally toss in before closing the door. Joe
4 thumbs up please. ty.
Posted on Nov 08, 2010
I have a quiet partner ii the soap dispenser door will not stay shut, how cab I fix it?
I have the same dishwasher, and have a problem with it shutting when soap cakes up on it. Have you tried scraping the latch door area? Once I cleaned out all the scale it shut better and when I close it, I push gently on the door and help the latch shut. It still opens fine during the cycle and the soap is gone.
Oct 11, 2015 | Whirlpool Dishwashers
MY SOAP DOOR WONT STAY CLOSED
Soap dispenser latch problem.
a) Look at the latch whether there is build up of soap. CAREFULLY clean it. It might work.
b) If not just replace the whole dispenser unit. Not worth wasting time on trying to fix the spring problem. Most dispensers are $ 50 ~ $ 100 price range.
Sep 26, 2014 | Dishwashers
Soap dispenser won't stay closed
Only two reasons this may happen. One is the dispenser is just bad (most likely) or that the timer is somehow malfunctioning and sending power to the soap dispenser all the time (least likely) You will usually know if its the second because the dispenser will get really warm after the dishwasher had been on for a few minutes.
Aug 15, 2012 | Asko D1716 Built-in Dishwasher
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
The soap dispenser on my ASKO Model 1805 Dishwasher broke, we got a replacement part from ASKO but can't figure out how to get the old one off to replace it?
Remove the outer door panel, the screws around the edge hold it on. The soap cup will depending on serial break be held down with metal flanges or small screws. Bend the flange or remove the screws and push the soap dispenser out.
Appliance & Refrigerator Repair
Mar 23, 2011 | Dishwashers
Dishwasher isn't dispensing soap or rinsing well.
prime the sink before starting the dw yo make sure hot water is getting there
Jun 01, 2010 | Asko 1385 Dishwasher
I have a old Asko Dishwasher. It works perfectly. However at times at the end of the wash cycle the soap remains in the dispenser. This happens half the time.
Put less soap in. Your wash will be fine with less soap. We have same problem. MARK: do not have tall objects underneath that will stop upper rotor from spinning. Also objects in upper basket kan penetrate and stop uppper rotor from spinning. Using less soap works for us.
Mar 09, 2010 | Asko 24 in. D3450 Dishwasher
Soap door wont open
I have replaced a dish washer soap dispenser once. Not hard to do. Need the make and model number. This dispenser is activated mechanically so there may be a broken latch or spring in the dispenser. Check the dispensers operation manually and see if it appears to be operating normally.
Jan 16, 2010 | Frigidaire FDBB1940D Dishwasher
Asko 1876 dishwasher soap flap opens as soon as power on.
I don't know about the control panel - I am having trouble with mine too, but in regard to the soap dispenser -- don't use it anymore. Just buy those little tablets. That is what the secretary at the repair shop told me when I had a problem and that's been fine.
Sep 24, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Soap dispenser broken, can i replace it?
you can do it your self. No problemo. Two electric connectors, six screws 20 TORX.
Jul 09, 2009 | Asko Dishwashers
Dishwashers Logo
80 people viewed this question
Top Dishwashers Experts
Owen Barnes
