Question about GE Monogram ZDP48L4GHSS Dual Fuel (Electric and Gas) Kitchen Range
Led screen message (bad line). What does this mean, and what can I do?
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
How to i fix vertical lines on my led samsung tv
Here are a few responses from people with your set and this problem: https://www.youtube.com/watch?v=k8CjoegQolY
Jan 02, 2015 | Samsung Un46eh6000 46-inch 1080p 120hz Led...
I have a Samsung led 1080p from 2009 it's been in
You have a bad LCD/LED panel if they are pin stripes or look like they originate from a 'bullseye' looking point (screen was smashed.) A new panel is likely more cost than a new TV.
Oct 06, 2014 | Televison & Video
What does error message number 9 mean on my kymco mini s mobility scooter?
hi, it's a controller trip error message this can mean a bad connection or at worse a controller fault ...
Regards
Rob
May 05, 2014 | Health & Beauty
Pink and Green Horizontal lines across screen
Normally, horizontal lines on an LCD or LED monitor indicate a bad control board inside the monitor. However, occasionally the problem can be caused by loose or bad cable connections. The only things that you can really do is to disconnect both ends of the monitor cable and reconnect them firmly. Also, you can disconnect the monitor cable completely and just leave the power cable. With only the power cable attached, you can turn the monitor on and off. The monitor should have a "startup screen" or display a message that says something like "Video Cable Disconnected". If the green and pink lines are still present without your computer connected, then the monitor has gone bad. The good news is that Samsung SyncMaster monitors usually carry a 3 year warranty, whereas most monitors only have a 1 year warranty. You may be able to have the monitor replaced at no cost to you if it's less than 3 years old.
Jul 27, 2013 | Samsung SyncMaster Computers & Internet
My Samsung HL56A650 turns on, but no picture. We were watching it, and the picture just quit. When you turn it on now, the power recycles several times then all you get are 5 or 6 thin horizontal lines...
Now ur tv still get a solid power LED light?Yes,only few colors strip lines show up,mean ur tv board that call the T-CON decoders board is dead.This T-CON decoders board sit in the niddle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Jan 23, 2011 | Samsung HL56A650 56 in. TV
I have a HP Pavilion dv4-1220us Laptop and the screen flickers at the bottom. A 1/8" white line will appear at the bottom of the screen-this happens after about 1/2 hour of starting it up. Later the...
Usually this means u have a damaged led panel or panel ribbon connector try a new LED screen first try ordering from Amazon get the numbers off the back of the screen
Jan 17, 2018 | HP Pavilion dv4000 Notebook
No error message appears when there is pinter problems
the CLP 300 only have LED on the front panel of the printer. the color LED tells you what is happening with your ink cartridges. if all three or four LED flashing red. means paper jam of some other problem.
There is no software that you can monitor the status of the pirnter. even wit the network enable printer. (that is the Samsung's short coming).
sorry! that is all I can offer you. the good, the bad, and the ugly.
Nov 10, 2008 | Samsung CLP 300 Laser Printer
GE Monogram ZDP48L4GHSS Dual Fuel (Electric and Gas) Kitchen Range Logo
170 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
