Question about Saeco Magic De Luxe Espresso Machine
Bought new machine yesterday.says ventilate which i did,then jumps to dregs drawer full,which is empty and clean what can i do now?
THANKS to coffeeanyone!! This solved my prob perfectly.
the dregdrawer full message was killing me.
The solution:
as coffeeanyone said, slide the dreg cup back in SUPER carefully and presto,
she should be sweet.
THANKS THANKS THANKS
Posted on Jul 13, 2008
  • 40 Answers
Are you still having the ventilate sign come on? If so, let hot water run out for 10-15 sec.
On the dregs drawer full message- carefully put back the dump box -making sure it slides in right. This happened to me the first time until I figured it out how to carefully put it back. If it is not in all the way, it will keep giving you that message.
Posted on Jun 19, 2008
My Saeco Royal displays Dreg Drawer full after about 3-4 cups of coffee. i have cleaned the drawer. where do i find the Dreg drawer sensor to clean it.
hi,
this is normal as there is no switch or sensor. In fact the Royal as well as the Magic and others are counting the number of coffees that you have made between two removals of the dreg drawer. For this counter to reset, you have to remove the dreg drawer while the machine is ON, and remove it for about 10s minimum.
Retry and tell me if it is better.
Hope that helps,
M.
Mar 16, 2016 | Saeco Royal Digital Espresso & Coffee...
Right red light is blinking all the time
Alarm LED:
• Permanently on (one or more causes): No coffee left, water tank is empty, empty the residual water
tray is full (in this case the dreg drawer also has to be emptied to prevent problems).
• Flashing slowly (one or more causes): Brewing unit is missing, dreg drawer has not been inserted,
coffee container cover has not been inserted, service door is open, rotary knob for opening the hot
water / steam is not in the right position.
• Flashing rapidly:Ventilate the water system
Nov 09, 2014 | Saeco Odea-Giro Espresso Machine
I have a message that reads Dregdrawer full but it is empty
the machine is counting how many coffee is made,and then it's showing that dreg drawer is full. If you empty it before the machine showing that's full -machine don't know that you are empty it.Now you have to remove dreg drawer for 10 seconds and then put it back!
Oct 03, 2014 | Saeco Coffee Makers & Espresso Machines
Machine shows message 'dregdrawer full' even thought the dreg drawer is empty. cant get rid of this error message.
Hi
When you go to empty the dredge drawer you must leave the machine on. When you remove the dredge drawer it will say dredge drawer missing. Leave it out at least 15 seconds so the machine knows you are empting it. When you insert it again the machine will count about 24 cycles and tell you to empty it again. Its a counter.
May 12, 2011 | Gaggia Syncrony Compact Digital Espresso...
Machine won't work due to dreg drawer
Check to see if your machine has an "exit chute" or similar area where from the used pucks are ejected. The area might be clogged with used coffee grinds and causing a false reading from the machine.
Dec 14, 2009 | Saeco Royal Digital Plus Coffee...
Dregdrawer Full
There is no 'sensor' for this, an internal counter resets when you remove the drawer with the machine switched on and the "Dreg drawer Full" message displayed.
Make sure the machine displays this message "DREG DRAWER FULL" Do NOT turn off the machine, Pull out the drawer that the used grinds are dumped in(you have to remove the drip tray 1st) Check display - it should read "DREG DRAWER MISSING" If the display message is correct, wait 10 seconds then replace the drewer.
Message should be cleared.
If the "dreg drawer missing" does not display, you do have a bad sensor and machine needs to be serviced.
Nov 19, 2008 | Saeco Royal Digital Plus Coffee...
Dregdrawer full message will not go away
Have you tried removing the drawer with the machine on, leave it out for say 2 minutes and then replacing the dreg drawer again?
There is no dreg sensor. Dreg drawer full works off a counter - depending on when the counter was last reset your drawer may be full but it may be empty.
Simply removing the dreg drawer and replacing it quickly will not reset it. The machine has to think that you have actually taken the time to empty it - a couple of minutes should cover this.
If this does not resolve the issue, you need to get a Technician to take a look.
I hope this helps
Aug 26, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Dregs light stays on (even when emptied!) - can't use machine
the various lights are controlled by either magnets that hit various sensors or microswitches.
the dreg light i'm pretty sure is a microswitch.
Its pretty common for them to go out, they're standard in almost all super automatic machines.
that particular switch is a pain in the **** to get to. You can order them direct from saeco, but if you can, it may be easier to send it out.
There should be a microswitch for the grind box, for the drip tray, for the water tank, and there should be one if i remember right for the grinder.
Its different for each model.
Hope this helps.
Apr 06, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
Apr 05, 2008 | Saeco Incanto Classic Espresso Machine
Dregdrawer full
drain machine, turn off power , get vacuum cleaner nozzle into drawer slot (make sure its dry or u'll have to post a repair for vacuum cleaner repair) remove all deposits for chamber , shake and bang machine to lossen deposits. if drawer has metal clips or something that looks like sensors (does not have to have wires attached to be a sensor) clean !
Feb 02, 2008 | Gaggia Syncrony Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
124 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
