Question about Texas Instruments TI-83 Plus Calculator
How do you turn the key on to use the i key - Texas Instruments TI-83 Plus Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You need to turn the complex mode on to enable complex arithmetic. Press MODE, down-arrow to move to the line beginning "Real", right-arrow to highlight "a+bi", ENTER to select it, and 2ND QUIT to exit.
Posted on Nov 08, 2010
Hyndai sonata 2008. I put key in the ignition and it wont move. Seems to be locked. I tried to wiggle the wheel and nothing. What else can I do?
-You mean the ignition key is lock. So you can't turn the key to start right...?
Try this:
Insert the key into the key slot. then turn the steering left untill can't turn and hold there then turn the key. If it doesn't work then turn the other way and hold then turn the key. You should be able to turn the key like normal.
Good luck
Mai
May 16, 2017 | Cars & Trucks
Ignition of ford edge will not turn completely off..it is stuck in position 2 in auxillary power
1-
My ignition key will not turn to off. I can remove the key, but it stays in the accessory mode. What's the fix?
My ignition key will not turn to off can remove the key but it stays in...
2.
Ignition key is stuck and does not turn Inspection Service & Cost
Ignition key is stuck and does not turn Inspection Service Cost...
3.
Ignition key won turn
Aug 24, 2016 | 2012 Ford Edge
Ignition key won t turn
The ignition key won't turn likely because the shifter linkage that locks the key in OFF is worn or loose. Move the shifter linkage hard to the Park position and the key will turn. Have the linkage adjusted and the worn parts replaced
Mar 30, 2014 | 2000 Mercury Grand Marquis
Key wont turn ignition and steering wheel also locked
Turn the steering wheel anticlockwise or to the left and turn the key.
Jan 07, 2014 | 2007 Hyundai Atos Prime
Ignition key won't turn
double posted read post 1
Oct 16, 2013 | 2000 Plymouth Voyager
2001 ford taurus key won't turn ignition
The steering wheel was turned when the key was removed. So when you try to turn on the key, turn the wheel one way and the other way to release the pressure on the key. The key should turn ok.
Hope this helps.
Jul 29, 2012 | 2001 Ford Taurus
Key in ignition won,t turn 2004 ford escape
several things, does key go in and out easily, turn steering wheel in both directions while turning key. sometimes the steering wheel lock binds the lock cylinder and turning wheel releases the pressure and it will turn. other than that the ignition cylinder is jammed, wet key lightly with lubricant such as wd-40 and a light bit in key hole and try key again, If key is heavily worn out , try a different ignition key as it might not be disengaging all the tumblers in lock, if all this fails you need a new cylinder.
Jun 09, 2012 | Cars & Trucks
I have a 2004 Cadilac CTS we bought a replacement chip key which the Chev Olds dealer could not program I took the new key to a Cadilac dealer they told me the key is defective now the Chev dealer has...
Okay, to program a key you will need two keys that are already programmed, insert one key ignition turned on and engine off, remove the key and within 10 sec insert the second key and turn ignition on with engine off, remove that key and within 10 sec insert the key to be programed. you will need to do a 30 min.relearn with only one key,you will turn ignition on with engine off and wait about 10 min until light goes out then remove the key and repeat this step when light goes out repeat step one more time then use key to start car, computer has learned all info. you will now turn off engine, insert programmed key turn key on engine off then remove the key and insert key to be programed within 10 sec.all done good day.
May 27, 2011 | 2004 Cadillac CTS
I cannot turn the ignition on
battery dead , starter won't turn or key won't turn? if key will not turn , insert key, pull/turn steering whell one direction and try key. if not turning still pull/turn wheel other way and try key
Dec 31, 2009 | 1988 Ford F 150
Ignition key wont turn
is it correct key? key and ignition barrel could be worn wiggle key around in ignition while turning? gently but fast wiggling.try lube in key slot also.
if not replace barrel and key
May 31, 2009 | 1995 Toyota Camry
Texas Instruments TI-83 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
