Question about Canon PowerShot A640 Digital Camera
Battery Problem I have a new Canon PowerShot A640 (< 1yr old). Lately it keeps giving low battery indication & sometimes shuts down, even with fresh new batteries. Situation improves slightly when I don't use the LCD display, but shooting with the viewfinder is a pain. Can anyone suggest what is wrong?
  • 71 Answers
The batteries u r using for your camera are of very low rating or low ampere output, you should use atleast 2100mAhr rating batteries and you will be very much satisfied with the performance.
Regards,
Manoj Joseph
+91 9352008418
Posted on Jun 16, 2008
Testimonial: "Perfect solution!"
How do i fix low battery problem, I get about 5 o 6 photos before it shuts down to low battery and i want to change the batteries.
Some batteries, although the correct nominal voltage for the camera, are not powerful enough for continued use. I have found the best solution is to use rechargeable NiMH batteries of at least 2100 MaH, preferably 2500 MaH.
Jun 07, 2016 | Canon PowerShot SX 160 IS Red 16.0...
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at http://chdk.wikia.com/wiki/CHDK_in_Brief
This is a bit technical and will probably void your warranty, but might be worth the try.
May 08, 2011 | Canon PowerShot A460 Digital Camera
I have a Canon PowerShot A530 camera which is around 4 years old. till recently it was working great but from last 3 months, it is giving false indication of low batteries and shuts down. Even after full...
if you are using this camera for 4 yrs with the same lithium battery then you might need to try a new battery
any lithium battery cell's capacity diminishes after long use. it reduces the cell's ability to deliver current. the older batteries do not charge as much as new one.
when you charge your battery it irreversibly loses approximately 20% capacity per year.
hope this help
Sep 08, 2010 | Cameras
Low battery all the time
this is not a good signal. you can make this prove. clean the internal camera contact with a specific contact spray and one cotton fioc
ore you can use normal denaturated alcohol. this is one possibilty. if you dont have any betterment. its probably that the camera have a eletronic defekt. this is not so uncommon with old camera. the camera have internal fuse the works not good and gives this problem. motherboard defekt. good luck i hope for you that is only a dirty contact faulty.
paolo
Jun 01, 2010 | Canon PowerShot A550 Digital Camera
I have a Canon A590 Low Battery even with new batteries installed
Use NMH type batteries standard batteries are not good enough for the write load that this camera draws. I think it recomjmends this in your manual if you still have it.
also dont use rechargables
Please rate my help++++Thyanks for using FIXYA
May 09, 2010 | Canon PowerShot A590 IS Digital Camera
Canon A720IS flash problem/low battery indicator
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Mar 13, 2009 | Canon PowerShot A720 IS Digital Camera
Replace battery sign in New canon A590si camera.
You're using the wrong batteries. You need to purchase lithium batteries. They are quality batteries for high powered, battery operated electronics. Personally, I have a battery charger and use rechargable duracell batteries. (HR6/ DC1500/ NiMH/ 1,2V) Gives you approximately 16 hrs before having to recharge.
Dec 01, 2008 | Canon PowerShot A540 Digital Camera
Battery Indicator Flashing and then Camera Shut down
Maybe reflash the firmware? Check Canon website for firmware update and instructions.
Feb 24, 2007 | Canon PowerShot A70 Digital Camera
Canon PowerShot A640 Digital Camera Logo
1,202 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
