Question about Microsoft Xbox 360 Console
My xbox 360 arcade dvd drive is not getting power from the xbox 360 wont eject or close
  • 43 Answers
Take it into a games store/ fixer man and get them to look at/ replace the motor that opens and closes the disk tray. =]
Posted on Nov 09, 2010
  • rickardodiaz Nov 09, 2010
    does the xbox make any sound, like a motor as you press eject?
    If so this sounds like the rubber belt has come loose, you can GENTLY pry the drive open with a credit card or similar, and just simply replace the belt.
    If the drive makes no sound whatsoever, then is could be jammed, try opening the drive GENTLY (as mentioned before) and do so very slowly. Just a little wiggle whilst pressing the eject button may release your drive.
    Good luck!!!
What happens when my xbox 360 arcade wont play any 360 games? My xbox 360 arcade will not play any of my 360 games. The disc are brand new. I bought the xbox 360 arcade used.
Find someone in your local area that can adjust the laser power level on the DVD drive. This is a temporary solution. A better solution is to buy a new drive off of ebay that is the same one that you have and change the PCB boards so you have the same PCB board in the new case with everything else. To see what drive you have, take the face plate off of the console. Look at the front of the DVD drive and there is a small hole on the lower right hand side of the drive. Look at the two wires inside the hole. Red and Black are a Samsung drive, White are a Lite-on drive, yellow are a Benq and a black plug is a hitichi.
This is very easy and only requires minimal soldering.
Sep 02, 2010 | Microsoft Xbox 360 Console
Tip
Xbox 360 - Stuck or sticking tray fix!
If your Xbox 360 DVD drive won’t eject it can be a very simple fix.
The Samsung drive is almost always a very simple fix, if you have another drive, it may be more difficult.
To identify your drive, follow this guide:
• Remove the faceplate by firmly grasping the opening for the USB ports and pulling.
• Underneath the DVD tray there should be a small hole.
• Look at the wires in the hole to identify which drive type you have.
Red and Black Wires = Samsung Drive
Yellow Wires = LiteOn Drive
White Wires = BenQ Drive
No Wires = Hitachi Drive
SAMSUNG:
It is very common for a Samsung drive to not eject. It’s a very simple fix for this!
1. Power on your Xbox 360
2. Press the eject button
3. When the Xbox 360 “tries” to eject, just simply push in on the tray cover.
That should make it eject!
If it does not, please follow the guide for the other drives below:
This requires you to disassemble your Xbox 360. IF you don’t know how, look it up on google, there are plenty of guides.
Then follow these steps:
1. Remove your Xbox 360 DVD drive from the Xbox 360
2. Turn over and remove the four screws securing the drive (6 screws if it’s a Hitachi)
3. Remove the top cover of the DVD drive.
4. Put the drive back in the Xbox 360, connect the wires, and power on your Xbox 360.
5. Once the 360 powers on, eject the drive. Most of the time it should eject normally. If it doesn’t you may have to force it.
6. Unplug the Xbox 360. If you turn it off with the power button the tray will close first, we need it open.
7. Near the front of the drive, you should now be able to see and access a small rubber band that was hidden by the tray.
8. Remove the band, lubricate and replace.
9. Replace the top cover and hook up and test.
10. If that doesn’t work, you may need a new rubber band. If you can get one of the right size, replace and test.
on May 13, 2010 | Video Game Consoles & Games
Tip
If your Xbox 360 Disc tray won't eject
SAMSUNG:
on Feb 02, 2010 | Video Game Consoles & Games
New Xbox 360 Arcade, Memory Problem
Could it be due to the lack of hard drive?
May 14, 2010 | Microsoft Xbox 360 Console
I power my 360 the light just blinks and the dvd drive wont open
could be that you have your avi cable set to hd mode and play it on a reg tv. or the cable could be bad it self. some times the blinking light is trying to tell you that its not getting the proper signle
Jul 21, 2009 | Microsoft Xbox 360 Arcade
My son saved money and bought a Xbox 360 Arcade. He did not realize that he could not play his xbox games on his new system. Is there an upgrade to allow old xbox games to be played on on the xbox 360
Some game are compatible with the new xbox 360. They are called backwards compatible and you do need to flash upgrade the OS on the new xbox 360 system.
You need to go to the xbox website and go to support and download the flash update then burn it to disk and put it on the xbox to update the software. Again not all old games are compatible with the new xbox system. If your buying used games like I do make sure it says bc next to the title before buying them.
Here is the link to the upgrade
http://www.xbox.com/en-US/games/backwardscompatibility.htm
May 19, 2009 | Microsoft Xbox 360 Arcade
My xbox 360 wont read my games or wont eject
The power connector to the dvd drive could have came loose. If its out of warranty they you could check it, if not then send it in for free.
Jan 18, 2009 | Microsoft Xbox 360 Console
Xbox 360
you need to send it off to get repaired
Aug 26, 2008 | Microsoft Xbox 360 Console
Xbox 360
The Arcade model comes with no harddrive, no hdmi (for digital connection to an HDTV), and I beleive the controller is wired instead of wireless. If you are planning on just playing games then the arcade may be a good choice for you as it's cheaper but you may find yourself wanting a hard drive sooner than later. Without a hard drive you will not be able to purchase or rent movies and you will not be able to download game demos and Xbox Live Arcade games. To compensate Microsoft includes a disc with some of the greatest hits of XBox Live Arcade with the Arcade version. The Pro comes with a 20GB hard drive but still no HDMI. The Elite version has a 120GB hard drive and HDMI. For most people the Pro is the one to get. If you were to get the Arcade then purchase a hard drive later you will pay more than the price of the pro.
Jul 07, 2008 | Microsoft Xbox 360 Console
Unreadable disk
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Apr 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
65 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
