Question about Dewalt 1/2 Drill DW236
My Dewalt 1/2" Drill (DW236) keyless chuck is
  • Dewalt Master
  • 7,733 Answers
Where does the green wire connect from the power cord on a dewalt dw 236 drill
The green wire is always the ground pin (ground connection)
Hope this helps.
Feb 28, 2015 | Dewalt Dw236 1/2" Heavy Duty Vsr Drill...
Where does the green wire from the power cord attach to on a dewalt dw 236 drill
The green wire is always the ground wire. It should be connected to the ground pin on the power connector.
Hope this helps.
The chuck is stuck closed how do i remove it
You need to uoen it to remove it. Try taping on outside of chuck collar lightly to get it to open and turn it .
Apr 24, 2014 | Dewalt 1/2 Drill DW236
Where do i connect each lead
On some machines they have push fit connections and you have to make sure the end of each wire is solid (soldering can do this) you should see against two of the connection holes an arrow which denotes where the wires go.The live is usually on it's own where as the neutral has a couple of wires around it.
Jan 30, 2013 | Dewalt Dw236 1/2" Heavy Duty Vsr Drill...
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
I have a dc 759 it has a plastic cover over the keyless chuck ....it is stripped out.....can i just replace the plastic cover? .... if so how and where can i get one
If the drill is not too old, I would take it to your nearest factory dewalt repair shop. they have a good warranty on their items. If it is older you probably need to replace the chuck itself. You need to remove the plastic to get the chuck open and then there is a screw down inside the chuck that needs removed. The chuck should come right off and just reverse the process to install the new one.
Nov 12, 2010 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
How do I remove the old chuck from my keyless drill?
Hi \
Try opening the chuck all the way....there should be a screw/nut at the back that you can get a tool on>
HTH,
Mike...
Dec 09, 2009 | Dewalt 1/2 Drill DW236
Drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Keyless chuck problem
I had the locking screw come loose in the center and bottom of the chuck it has a left hand thread and is a torx head . It had backed out and prevented the chuck from closing.
Mar 14, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt 1/2 Drill DW236 Logo
1,301 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
