Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
It won't power on. Was fine 2 weeks ago when last used. I have tried different electrical outlets.
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Posted on Nov 10, 2010
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
My Sharp Aquos LC-26D44E-GY in the spare room has stopped working. It worked ok about 2 weeks ago, went to switch it on last night & its dead. We had a thunder/lightening storm last week? Ive changed...
First check your power outlet, try connecting the TV to a different power outlet. Then see whether the LED light on the TV is on or blinking. Anyhow, this might need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
Installed 8 low voltage lights with a malibu digital 120w timer 2 months ago. The timer does not always work. I'll unplug then power up the system and then the lights turn on. Never had this problem...
Timer is not identified:
Open following link to see low-voltage digital timers and then add a comment if needed:
Page also has links to warranty information, and list of advisories so power pack lasts longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#digital
There are 2 likely suspects: Bad timer, or electrical problem.
There is no repair for bad timer, but timer has warranty through the manufacturer/ Malibu.
Electrical: Since power pack worked correctly before, then outlet probably has correct polarity, but I always suggest checking outlet with circuit analyzer.
Also plug lamp into same outlet and see if there is flickering that would indicate loose wire. Wiggle circuit breaker and see if lamp flickers. Move the outlet and see if lamp flickers.
Outdoor outlets get loose wires because of exposure to temperature and dust and moisture. Replace outlet and don't use the quick connects, instead use screw terminals.
If possible, move timer to different outlet on different breaker and see if problem persists.
Oct 05, 2011 | Hardware & Accessories
My nintendo 64 does not turn on anymore and the last time i played it did. But the last time I played it was probably a year or two ago. But it has been in a case and not left out or anything
Here are some troubleshooting steps to get your Nintendo 64 up and running again.
  1. Try unplugging and replugging in the power cable.
  2. Use a different electrical outlet.
  3. Use a different power cord.
If problems persist you may need to purchase a new system. Best of luck.
Jun 13, 2011 | Video Game Consoles & Games
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
Lost electrical power at 2 outlets. No TV power
wires could be crossed or burnt out
Jun 14, 2009 | Televison & Video
Total power loss during use
Check the voltage on the outlet,make sure it is 115v -- 122volts max, any less will cause it shut off, make sure the polarity off the outlet is correct and it is grounded,check all of your wiring connections, if all this is ok replace unit with a different unit or different supplier of unit
Jan 26, 2009 | Microwave Ovens
All TV's in house failing, a few at a time
Hey PNorris,
If multiple electronic devices are failing in your home all at once, I would probably first have to ask if your home recently experienced an electrical storm or major power surge of any kind.
Normally the effects of such large-scale surges are immediately noticeable - TV's and other major electronic devices may fail to turn on, fuses may be blown or circuit breakers tripped, and in some cases electrical wiring may be melted.
If nothing like this has happened recently, low-level power surges may still be a potential cause of this problem. When the motor from any large appliance (such as an air conditioner or refrigerator) turns on or off, it often diverts power to and from other electronic devices using the same circuits. This fluctuation in electrical current may result in low-level power surges to every connected device. While not immediately noticeable, these low-level surges can often cause the eventual failure of (and gradually degrading quality in) many audio/video components.
Typically, the easiest way to avoid situations like this is to make sure that outlets are not overloaded and surge protectors are used with every major electrical device in your home. For older homes however, replacing the house's wiring may be necessary. Homes that were originally built at the turn of the 20th century may not always have wiring capable of supporting the electrical needs of many modern appliances.
Ultimately, this means that in addition to contacting your local TV repair facility, you may want to also speak with an electrician. This is probably the best way to determine whether or not power surges have caused these failures, and may give you a better idea how to proceed.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 12, 2008 | Televison & Video
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
63 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
