Question about Coby MP-C7085 MP3 Player
Will not connect with the computer
When i plug in my mp3 player the computer doesn't recognize the usb connection, the cord and usb port are both fine. i've tried mtp and msc mode and neither work, the only thing that happens when i plug it in is the mp3 player turns on, but i don't get the screen with the sync icon on the player. any ideas?
The first time I got a coby mp3, the same problem happened to me, i just returned it and the next one they gave me worked fine.
Posted on Jun 18, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
Follow this process
right click on computer then
1. click properties
2.hardware
3.device manager
4.universal serial bus controller(open the + sign)
5.click upper one double click
6 go to driver
7.click on the update driver
8. then choose second one (advanced) then next
9.click don't search
10.then next next if it is over
same process with anotherone then restart your computer and enjoy you ipod
and don't forget to give rating
Posted on Jun 16, 2008
I plug my mp3 player into the usb port on my computer and it doesnt turn on to charge like it did before. i tried to turn on my mps player and it acts like there is no power. i just got this mp3 player and...
Hello
Check the connections on both ends to make sure they are attached securely. If the MP3 player is still not recognized, go into the player settings and change the Online Device from Media Device to USB Disk. Use a different USB cord if you have one because it could be broken and not allowing your computer to recognize it.
connect the device to a different USB port on your computer. If the MP3 player is still not charging, plug it into a wall charger. Try charging the Coby device overnight. If it still will not charge, the battery may be bad and you'll need to contact Coby for assistance
Apr 30, 2011 | Coby MP620 MP3 Player
Tip
Connecting an Eclipse MP3 Player to a Computer
Many people have found that their computers do not recognize the Eclipse mp3 Player, even after connecting with a USB cable. I had the same problem but discovered that the problem lies with the cables themselves. I have several USB 2.0 5-position cables that fit the Eclipse USB port perfectly, but only ONE of them actually works - the cable that came with the player itself. If you've lost this cable, you may be in trouble.
Attached is a screen-grab of the type of USB plug and port involved. You don't see them around very much anymore, and I have no further advice if your player doesn't have a USB port of this shape.
on Feb 01, 2015 | Eclipse Audio Players & Recorders
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
My computer doesn't recognize my gpx ml648 mp3 player when it is plugged in.. why not?
I am going to type up what the owners manual says for this:
1. Try running Windows Update to see if there are any Service Packs they have available. You can do this by going to www.windowsupdate.com
2. Scan for hardware changes. To do so, open Device Manager. This can be found by right clicking on My Computer. Choose Properties from the menu that appears, In this System Properties menu, click on the Hardware tab. From the Hardware tab, click on Device Manager. Within Device Manager, there should be a listing for Portable Devices. If there isn't a listing for Portable Devices or the listing shown is highlighted with a question mark, right click on Universal Serial Bus Controllers and select Scan for hardware changes.
3. If no devices connected to a USB port can be recognized, try connecting the mp3 player to a different USB port.
Also, if you are using a USB extention cord - stop. make sure the cord from your player is directly connected to your computer.
Nov 01, 2009 | GPX ML648B MP3 Player
My mp3 is not connecting with my computer
Try connecting through a different USB port. It does not like going through a hub and I discovered that the two USB ports in the front of my computer won't recognize the player, but when I connect to any of the ports in the back, it connects fine and recognizes the device.
Sep 07, 2009 | Sony Walkman NWZ-S616F MP3 Player
Mp3 will not connect with my computer
I had the same problem. Don't buy a new cord. There is a sony place in winnipeg you can get it fixed there.
May 30, 2009 | Sony Walkman NWZ-S616F MP3 Player
My computer doesn't reconize my mp3
check if your usb cord if defective.
To check if the mp3 is recognized by the computer go to device manager in the compuer properties.
Go to device manager go to hardware tab and search for new hardware, if you see a question mark in the usb port it means that the computer cant recognize it and you may need a driver. Some mp3 have cd installer of its software. Install it in your computer. and try if the computer can recognize it.
also check if your usb port is working properly...
Sep 16, 2008 | Audio Players & Recorders
Computer doesn't recognize usb connection
follow this process
1. click properties
2.hardware
3.device manager
6 go to driver
Jun 16, 2008 | Coby MP-C7085 MP3 Player
Coby MP-C7085 MP3 Player Logo
59 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
