Question about NEC Electra Elite DTU 16D-2 Corded Phone
I am trying to change the time on my NEC Elite 16-Button Display Phone DTU-16D-2. Any suggestions?
Hit feture then 9 and continue to type in the correct time
Posted on Nov 16, 2010
How to Change Time on NEC Dterm Series E phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time.
Mar 14, 2012 | NEC Electra Elite DTU 16D-2 Corded Phone
How can i have my nec-dtu-16-2 work with Nortel PABX?
Would you expect a Nortel phone to work on an NEC sysem? The phone is digital and it requires an NEC system to work. Nortel M7208,7310, T7316 are phones that typically work on Nofrtel digital systems. They also require a digital port.
Carl
Feb 05, 2010 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC DTU-16d-2 background music
you would need to enter system programming mode and change MB 1-8-31 to external. The internal music is pretty bad. This works on elite and ipk platforms. It depends on your system type. Look at the phone system and see what letters it has on it.
ldtsnj.com
Apr 02, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Display Not Working
There is a ribbon cable on the display that may have come loose. If you open it you could plug it back in. If that is not the problem than reset the digital station card or you need to get the phones fixed.
ldtsnj.com
Mar 19, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
How to change time on NEC Electra Elite IPK? I
You have to be on the root phone or "first phone".
To check various phones -Hit {feature} 4.
Should display 100= TEL 01. Once on the first phone then use {feature} 9 #.
Time will flash at top of display and can be adjusted.
If you are not on the first phone you will get error at the top of the display. Leave the hand set on the hook.
Mar 11, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
"NEC DTU-16D-2" Need it to ring!
Woo Hoo! I figured this one out on my own!
However...WARNING! I wouldn't recommend doing this unless you are technically savvy, as one wrong move could totally mess up all of your phones!!!
I searched and downloaded the Programming Manual from here: http://www.nec.co.th/html/download/Manual/Programming.pdf.
This manual will not only tell you how to fix this issue, but how to pretty much fix/change all programming for the NEC Electra Elite DTU-16D-2 phones.
I have also searched and downloaded the Feature Manual from here: http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
Happy Programming! =)
KayCee
Dec 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Display contrast - too dark
You should be able to adjust LCD contrast when phone is idle, just use the up/down arrow button to adjust it (don't go off-hook). If you have background music set, the above procedure will adjust the music volume instead. You can turn Background music on and off by pressing <Feature>,2,6 when your phone is idle. Alternatively, you may press <Speaker> 6,0,2 and then use the UP/Down arrow key to adjust LCD contrast.
Dec 11, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Set Time DTH-16D-1 (BK) TEL
Here's how you adjust the time:
1. Press <TRANSFER>
2. Press <CONF>
3. Press *
4. Press <TRANSFER>
5. Press <CONF>
6. Press #
7. "CAT MODE" displayed on LCD
8. Press <REDIAL or LNR/SPD>
9. "COMMAND" displayed on LCD
10. Press 02
11. Press <RECALL>
12. Press 2
13. Press <RECALL>
14. "02>2>Current Time" displayed on LCD
15. Input correct time using military time (HH MM SS)
16. Press <CONF>
Dec 28, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
I need to program a HeadSet Button
For the DTU phone on an NEC Elite system:
Memory Block 4-12
put in the port number and the Lkey of the extension you want to make a headset key.
Programmin on a 16button phone, Lkey 11 needs to be lit and will display H SET to verify.
For the DTP phone, it is generally on an NEC 2000, which is entirely different.
Oct 12, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
304 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
