Question about Whirlpool Refrigerators
Ice machine quit ? model#ED5LHAXMT00 SER#SP3935855
  • carter151 Nov 08, 2010
    I HAVE NOT TRIED ANYTHING. I WILL TRY ANYTHING YOU SUGGEST ?
    WOULD IT HELP TOO TURN OFF AND RESTART AFTER EVERYTHING IS DEFROSTED. WHERE CAN I FIND THE WATER PAN YOU MENTIONED
  • Whirlpool Master
  • 1,711 Answers
Can you give some information about your problem, what you see, what you noticed, what you have try.
Posted on Nov 08, 2010
  • espressonist
    espressonist Nov 08, 2010
    First thing to check is the water supply, check the water basin part No 20 MOLD-ICE
    Part Number: AP4365074 made by WHIRLPOOL
    If is empty, then you have a water feeding problem.
    If it is full of ice then you have a motor system problem.
    Try to listen what do you hear.
    We have a link with your fridge model parts and ice maker so you can understand how your model is
    http://www.appliancepartspros.com/partse...
    Test it a let us know to go further.
    http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504702&diagram_id=131623#d131623
  • espressonist
    The pan is the water pan where the water will feeze and makes the ice cubes. Moreoever yes if you see that this pan is frozen try first to reset and even leave it the fridge off for two hours with doors keep closed and after switch it on to see if it was everything frozen up and stuck. Just do that so we can have a start from some this.
Ice maker in kenmore coldspot refrigerator quit making ice, nowater flow
There are several causes of no ice maker operation. First, is the freezer cold enough? It must be below 32F to operate the icemaker. 2nd: Is the bale or metal rod that runs along the side of the ice maker in the down position? 3rd: You may have a failed water solenoid valve, located on the back of the unit. The plastic or copper water line from your house's water supply is attached to this valve.
Apr 11, 2015 | Kenmore Refrigerators
My refer started to leak water, so I vacumed all the filters now it wont get cold and quit making ice, I may have put a wire on wrong,do you no where I mite get a wire diagram?
look bening th toe grill the may be a tec sheet there .. but to help more i need model and ser # .. ck on line with with sears / they may show in the parts the wir dig/ ,.. mm
Jul 10, 2011 | Kenmore Refrigerators
I have a GE monogram side by side refrigerator; the refrigeration side is not keeping cool and the freezer is not quite as cold as it typically is, though it makes ice just fine. There is no visble ice on...
if its making ice and if the coils are some what clear .. i would look and the air dampner . that controls the air flow to the fresh food area , this is a common failure in the ge .. mm there is a up date kit for this .. see your parts dist in your area .. wou will need the correc and complete model #` and ser # of your unit .. mm hope this helps feed back pls ..
Jul 10, 2011 | Refrigerators
Tried to adjust temp of refrigerator and the panel went crazy, flashing through the various settings. Not sure what to do.
need a model # and ser # off the machine itself to give correct ans and part that has failed .. this is what i think . your machine uses a prosser with sensors and the prosser has failed . this can cause the flashing and how knows what . some models the ice mker will keep opening the ice door and never quit and the flashing controls . . to correct you will need to replace the controls in the frig side .. mm / hope this helps . mm
Nov 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
Water in door works but ice maker quit .its a roper side by side mod#rs25aqxfnoo ser#sg1235753
That ice box uses a dual solenoid dual mechanical valve and operates the water on one side and ice maker on the other. The solenoid for the icemaker (which has a smaller water line) might be open or the mechanicals inside may be fouled with sand and sediment or lime deposits. If that checks out then the thing that powers that water valve is the ice maker itsel. So if your water valve is good then your ice maker is bad most likely. I have a page which shows repair photos and manual: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 14, 2010 | Refrigerators
Delfield model #mrr2n-s ser. 0403036101321-t ice
can not immediately locate manual.
If this unit is a cooler, check this:
Anything that can effect air flow. Fans not running or running in wrong direction.
Too much product in unit.
Thermostat set too low or stickes and unit does not shut off unit.
Possibly has a defrost timer. Most coolers do not but some do. Look for one and see if it is working. Make a mark on the face and wait 15 minutes to see if it moves.
Drain pan clogged.
Doors not closing or seals not sealing.
these are the things to check out.
Aug 03, 2009 | Delfield (F18WC60) Commercial Refrigerator
TAYLOR ICE CREAM MACHINES SPARE REQUEST
Get rid of this unit it is too old to repair.
Jul 10, 2009 | Taylor 632-33 Ice Cream Maker
MAKING ICE BUT ICE AND WATER DISPENSER QUIT WORKING.
Sounds like a plugged water filter, assuming the water is turned on to the fridge. If you have a manual, refer to the section about water filters. The filter is usually accessible from the front of the fridge at the bottom....requires about a 1/2 turn counter-clockwise. Some units require that the water be turned off first but not all.
If you do not hear a click when activating the dispenser, there could be an issue with the water solenoid (water valve) that opens and closes when you use the water dispenser....agai...check the manual if at all possible.
Apr 17, 2009 | Frigidaire Refrigerators
Refrigerators Logo
88 people viewed this question
Top Whirlpool Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
