Question about MSI K9VGM-V Motherboard
What is the max size of sata HD I can install?
    President:
  • 2,992 Answers
You can use any size hard drive supported by your operating system. For 32-bit Windows systems, the limit is 2TB, but large if you have a 64-bit OS.
Posted on Nov 08, 2010
Once removing my old harddrive and putting into a Amicroe USB 3.0 SATA External HD Aluminium Enclosure it asks to format before use losing all my harddrive i was trying to save. Is there a way to repa
What OS are you using? If this is a Windows system (or non-Apple, at any rate), what does the BIOS say about the HD size?
Something has become corrupt. You might not make it out "alive".
Sep 27, 2014 | Computers & Internet
I want to upgrade the hard drive. What type do I need ide, ata, sata
the upgrading can be done only if the motherboard support if your laptop had sata provision you can use them if you dont have you cant use sata check the motherboard
Dec 15, 2010 | Acer Aspire 5100-5480 Notebook
Hi from Portugal. I have got a mobo a8n-sli SE and im having trouble connecting my new wd 64mb 1gb green sata HD. I already have got 2 working hd´s, one IDE 128gb and one Sata 320gb and now i...
ur mother bios should support 1TB HDD, only then it ll get detected... u can update the bios of your motherboard with latest bios that is available for ur board in ASus support site...if you update the bios your hdd may get detected...
Sep 30, 2010 | ASUS A8N-SLI Motherboard
What is the max HDD size for my Acer T135. Can I
yep - there is no maximum HDD size for computers just as long as you have the right connection (Sata or IDE) then you can fit any size you like.
Enjoy :D
Dec 03, 2009 | Acer Aspire T135 PC Desktop
Sata harddrive max size for abit is7 e2?
hard drive can be as much you want does not have a max size ,anyway not the motherboard you have to worry about if you put bigger hard drive you shold change the power source .
Nov 13, 2009 | Abit IS7-E2 Motherboard
Thinkpad T42 Hard Disk problem
Hello.
It seems the hard disk size will max out at 80GB with a 5,400 RPM speed according to IBM.
Im sorry to say that this means that it will not support a 120Gb hard drive.
Regards...
/Tech5508
Feb 14, 2009 | IBM ThinkPad T42 Notebook
SATA hard disk size
Your Motherboard is SATA 1.0 - If you select a newer 2.0 drive you will have to place the 1.5gb jumper on the drive to be visible to the bios and operate at 1.5 instead of 3.0 gbs - http://global.msi.com.tw/index.php?func=searchresult&keywords=ms-7043&table=download
this is the link to the manual and drivers for your mobo
The other option is to purchase an updated SATA 2.0 controller card and then you can support all the new size HD's - here is the link to one such card for $29.99 http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2254079&CatId=1455 - if you are not ready to update the mobo, then this is a great solutions
Dec 19, 2008 | Computers & Internet
K8V-MX motherboard+HDD size limit
yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Oct 03, 2008 | ASUS K8V-MX Motherboard
Max size sata drive for pcchips a31g
Hi Jason_UK, the motherboard revision does not matter in regards to the SATA size. (The board does support SATA).
2TB is a limit imposed by the MBR partition table. Assuming the disk uses 512 sectors.
If the sector size is increased to 4KB, the limit becomes 16TB. Suggest you setup your serial ATA SATA disk drives by downloading the manufactures bootable floppy disk setup software. Most SATA manufactures also provide bootable CD software if you do not have a floppy drive in your system. You will be able to change the size of the clusters allowing you to have access to the entire drive. The floppy software will also allow you to format the disk & there are other features that can be turned on or off. Neither windows nor the bios can make these changes.
Good luck Jason!
Mike
Sep 09, 2008 | PC Chips Computers & Internet
MSI K9VGM-V Motherboard Logo
53 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
