Question about Interactive Media Kanguru Presenters Mouse (KMOUSE-PRES)
Want to open mouse logitech M-RAG97 to replace battery. Took out screws 2 under feet and try to get grip on screws(?) under label. Somehow none of my screwdrivers gets any grip on thes 2 (?) 3(?) screws. What to do? N. Kuipers
    Master:
  • 362 Answers
Hello, take a look at this youtube link for some really useful stuff.
regards,
nicam49
http://www.youtube.com/watch?v=O7Jp1oj_WxA
Posted on Nov 08, 2010
My logitech wireless mouse stopped working. I cannot figure out how to put new batteries in. Other than trying new batteries, I dont know what to do. I have no instructions for this mouse.
The screws are under the back 2 feet and under the label. The label you can just feel for the holes and press thru with a screw driver. For the 2 feet, you can either peel them off (and buy replacements or re-glue the old ones back on), or just press the screw driver thru the center of the feet
Aug 12, 2010 | Logitech 3-Button Cordless Optical Scroll...
Poor battery life with Logitech V450 cordless mouse
The problem is likely in the software (drivers), assuming that you are using quality batteries (those manufacturer's specs are based on top-shelf, fresh-off-the-truck alkaline batteries).
When you replaced the first set of batteries, the absence of a mouse caused the receiver to search, and having found none, it's common for the driver to reset to default settings.
The Logitech driver is the first suspect; go to Control Panel, Logitech Mouse...Driver Properties... Look for the "Auto-off" setting, and change it to 10-30 mins (or the lowest setting you can live with)...What you're looking for is the driver that has reverted to "never" in the auto-off setting...and if that isn't changed here, then it was Windows.
You'll have to tunnel a bit to get to this one, but it's not as hard as it looks.
The second suspect is the Windows driver; For Win XP, from the Control Panel, go to "Mouse"...or for Win-7 go to Control Panel- Devices and Printers, Hardware- and choose "Mouse" from the text links.
From the new menu, choose the "hardware" tab, and the "Properties" button near the bottom.
The new menu page has a text area that states "This device is working properly", and under that is a button labeled "Change Settings"...Click it.
Click the radio button labeled "Allow the computer to turn off this device to save power"...and you're done.
Click the "OK" buttons to close the menu sets.
Apr 18, 2010 | Logitech V450 Nano Cordless Laser Mouse
Mouse dead and wont charge. is there a battery to change?
I have the same problem, called Logitech and they were no help at all. I tried to open the casing to see if there was a replaceable battery and the entire casing broke, now its useless.
Apr 15, 2010 | Logitech Cordless Mouse
Wireless Logitech mouse with NO connect button on it. Only buttons on it are Power and Reset (and one to open battery case). Cannot figure out how to connect to receiver. Was previously connected, but I...
Ok, try this in the steps ordered
1 remove the receiver from the USB port
2 remove the battery from the mouse
3 turn on the pc
4 after everything is loaded on the pc, plug the mouse receiver into the USB port
5 put the battery back in to the mouse and let it "find" the receiver.
If these steps don't work, try doing the steps and use a different USB port. If that doesn't work try a different battery in the mouse.
If none of this works and the receiver hasn't been bent (happens allot in laptops), then it sounds like your mouse took a dump.
Mar 18, 2010 | Logitech Cordless Mouse
How do you open it in order to change the batteries?
If there's no door on the bottom of the mouse for putting in standard AA or AAA batteries, then the battery is built in and would need to be replaced by the manufacturer or someone with technical savvy. There's probably a screw hidden under the label that would enable the shell to be popped open, but you would be voiding your warranty.
Mar 11, 2010 | Logitech Cordless Mouse
I cant open the mouse to get to the battery.
Hi
Please see the link it has a excellent guide
http://www.vk2k.com/Logitech-MX1000-Battery/
Please can i ask that you leave feedback and vote if this has been useful
Feb 10, 2010 | Logitech MX1000 Laser Cordless...
How do I change batteries on a cordless mouse MX5000. There is no door/cover to open.
Steps to change the mouse batteries:
1. With the small end of the mouse pointed towards you, just take your thumbs and slide the other end out.
Take note: The word logitech should be upside when you are doing this. It takes 2 AA batteries.
I hope that it is very helpful for you..Thanks..:-)
Nov 26, 2009 | Logitech Cordless Mouse
Replacement USB charging cradle for Logitech Mouse
It sounds like you are talking about a wireless unit, and I am going to assume that it has stopped charging.....Try this first before you purchase a new cradle for it....Take a pencil eraser and clean the terminal prongs on the cradle, just as if you were erasing on paper, then do the same to the terminal plates on the mouse....
Sep 27, 2009 | Computers & Internet
Logictech LX3 Optical Mous: Safe way to open to check
The screws are located under the mouse feet. However, doing this will void the warranty on your mouse.
Jul 02, 2009 | Logitech LX3 Optical Mouse
Logitech USB mouse Model # M-RAG97-does it have an internal battery, and if so, how do you open mouse?????????????
Turn mouse over - 2 screws under label - you can see the idents
Two other screws under rerar - remove feet or just punch though
the feet to get to screws.
Best of luck
Colin
Mar 21, 2009 | Interactive Media Kanguru Presenters Mouse...
Interactive Media Kanguru Presenters Mouse (KMOUSE-PRES) Logo
1,336 people viewed this question
Top Interactive Media Computers & Internet Experts
David Payne
David Payne
Are you an Interactive Media Computer and Internet Expert? Answer questions, earn points and help others
