Question about Maytag Neptune MDE5500AY Electric Dryer
There is intermittent squeeking when the dryer is in operation. Is this the drum bearing or the drive belt? How do I access both to check?
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Nov 11, 2010
Dryer is squeeking
Hi
The motor bearings may be worn. Remove the drum drive belt and then start the dryer. If it squeals with the belt off then the motor bearings are likely worn.
There is a small roller that tightens the drive belt for the drum. They can squeak. Remove the lower front panel and you should see the small roller near the motor and belt.
Another is the two larger rollers that support the drum. You will see this if you remove the front lower panel. Another is where the drum rides on the upper round part of the door/opening and it has a plastic guide that separates the metal drum from the metal door/opening. Over time this wears out and the two metal pieces will squeak.
Please check the bellow links to know detailed idea related to your query:-
http://www.ehow.com/how_5062711_fix-squeaky-dryer.html
http://www.mademan.com/mm/how-fix-clothes-dryer-squeaking.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Ge frontloader dryer is squeeking incessantly, high pitch squeek driving us all crazy. by manually turning the drum i can isolate the squeek, but cannot see anything wrong. does it need to be taken...
There is a teflon bearing that holds the back of the drum you will need to replace. To get to it remove the top cover, take off the control panel, remove the front cover, take off the belt, then take the drum out, ususlly by lifting it up as you pull it foward. While have it all apart I would reccomend replacing the teflon glides at the front that the drum rides on.
Jan 31, 2011 | General Electric DCVH680EJWW Dryer
I have a 5 yr old KitchenAid front load dry that just started to make loud squeaking sound when running or even if I turn the drum when the dry is off. Drys clothing good, just making noise and want to...
You will need to check the tub roller wheels. This is a common noise when the wheel bearings start to ware down. They are not expensive, and you should be able to do this yourself. Good Luck Friend.
Feb 22, 2018 | KitchenAid KEHS02R Electric Dryer
Dryer still squeeking after I replaced the drum bearing
more than likely tensioning pulley on the drive belt, lubricate with bearing grease or replace if badly worn.
Oct 25, 2010 | Frigidaire FEQ332E Electric Dryer
When my dryer is running i hear a loud metal on metal squeeking, like something (coin perhaps) caught between the drum and the frame. how do i open it up to check?
Your drum bearing has woren off. You take the dryer off from the front. Take the tension of the belt, and replace the drum bearing.
Nov 24, 2009 | Frigidaire Dryers
I have GE profile Model DPSR473EW with loud squeak when drum turns ? I also need to learn how to access the drum etc...
I have experienced two problems with "loud squeeks" with the DPSR473EW. First, if you take the top off (open door, remove two screws under top door lip releasing the top), then.., remove two small screws (inside up high - one on each side) holding the front panel/door assembly on. Pull the front panel/door assy away from the main unit - can't seperate due to some wires near the blower. On the door/front panel assy..., you will see four "teflon slides" that fit into a plastic semi-circular assy (the drum rides on those four teflon slides). Most of the time, this is where the squeeks come from - I've seen them worn thru..., and the drum riding on the plastic (just order the teflon slides - qty 4 - WE1M333). If the plastic piece that the slides fit into is worn, replace it - WE2M26 (top bearing). This should do it. If the slides look OK (so the squeek hasn't been fixed), the other place for a squeek is...., the back bearing. This bearing is basically a male rotating plastic sleeve running in a metal female hole. I have seen those wear thru the plastic bushing..., causing lots of noise. To inspect that bearing, you will need to a) remove the belt (plenty of instructions on the internet), then b)remove the drum..., then..., you can inspect that back bearing (two pieces - one piece on the back of the drum, the female piece mounted on the heater shroud.. If you need to replace that bearing, or one half of it - you can order pn WE25M40 - it will have both pieces. Good Luck
Nov 15, 2009 | GE Profile DPSR473EW Dryer
Squeeking noise when on.
I think the drum drive belt is slipping. Other possibilities are: A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Oct 21, 2009 | Maytag Dryers
My series 80 dryer squeaks
do not lubricate anything in a dryer you will damage .locate the the squeek if it is coming from the rear of the unit most likly need to replace the drum support or wheels if its intermittant and has a squeek squeeek noise that either gets worse or goes away when the dryer heats up the tensioner pully or the moter berrings are bad
Aug 10, 2009 | Dryers
Dryer squeekes on and off
Hello.
Intermittent squeaking usually arises from drum rollers, a bearing at the back of the tub or the pulley for the belt. Locate where the squeak is coming from the loudest and you can narrow down the cause.
Loud in the back middle: Drum bearing kit
Loud in the back bottom: Drum rollers.
Loud in the top front: Drum glides
Lound in the bottom front: Belt pulley.
Jul 21, 2009 | Dryers
Squeaks from drum area during operation
Hi there!
I think it is the drum main bearing that has started to sieze.
If it is not this, then the drive belt may need replacement.
If this leads to a solution, please take a moment to accept. Thank you.
Jun 18, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
49 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
