Increase the transmission level on Brother Fax 645
I have just done a test of my fax and it said my transmission level was too low. How do I increase it?
  • Alvin Barnabas
    Alvin Barnabas May 11, 2010
    Brother has many model fax machines. Is it a plain fax, insta fax intelli fax , or personal fax.
    Scholar:
  • 78 Answers
Maintenace Mode
Menu, *, 2, 8, 6, 4
Print out the number 11 and switch 13 will tell you what level its at.
Now its bit switches so it gets tricky. In maintenace mode you choose 10 to change switches then go to switch 13.
You will have something that looks like 10111001 (binary). The last four numbers represent the transmission level. The tricky bit is that your level is in fact a minus number so want to reduce it to make it louder. The example I gave you the number you look at are 1001. The first number represents a 8, second a 4, third a 2 and the fourth a 1. The first and fourth are on ie a "1" so it equals 8 + 1 = 9 with a maximum of 16. My advise would be to take 1 or 2 of the total number that you work out.
Posted on Jun 20, 2008
When i send a Fax how do i get a copy that the fax was Recived to the person i sent it to
You will get sound signal like longer beep. when you get three short beeps it means error (sent fax was not successful).
Also you can set XMIT report (means after every your sent fax, you will get printed out sheet with confirmation or error for previous sent fax - not recommended, will increase consumption of paper and toner).
If want to, follow steps:
- press key "Menu/Set"
- press "2" key
- press "4" key
- press "1" key (will see "trans: off")
- with navigation key "down" or "up" select "trans: on" or "trans: on + image"
- then press key "Menu/Set" to confirm it
Done
Feb 02, 2011 | Brother IntelliFax-2820 Laser Fax
Our RX report for our Canon 830i fax machine lists a transaction failed (NG) with error code #0106
This error usually means you have a phone line problem.
You need to try to increase your transmission level, or check the line equalization. It could also be a problem with an echo on the phone line.
Dec 16, 2009 | Canon Laser Class 830i Plain Paper Fax
Fax transmission level too low
click on setup
select advanced fax setup-ok
fax speed-ok
options should be fast med and slow
Feb 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I need to print instructions on how to use a brother fax -645 machine. how to set and send faxes
An on line manual probably does not exist. Put paper in feeder face down, dial number, press send.
Sep 11, 2008 | Sharp UX 108 Roll paper Thermal Fax
Need some help
Go to www.brother.com. They might have your manual available for download.
Mar 28, 2008 | Brother IntelliFAX 885MC Plain Paper...
How to use a brother fax- 645 plain paper fax
You may have been given a heap of junk. Happens all the time. Just place the document face down in the ADF and dial the number then press the green button to send.
Feb 27, 2008 | Brother IntelliFAX 885MC Plain Paper...
I need help with a fax machine
Sounds like you may have a noisy phone line, incorrectly set transmission level or no filters installed if using broadband adsl service, also pick up phone is it free of any background noise or crackles? (tel phone company or cable problem if noisy)
In australia there is a service for test fax level across phone line called FOLDS (Fax online diag service) maybe your carrier have one too so you can test?
Oct 09, 2007 | Brother IntelliFAX 560 Plain Paper Fax
366 people viewed this question
jasbo
jasbo
