Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
I need a part cd143f-100a for a chain saw, looks like a magneto coil
  • 7,733 Answers
Can you please tell me the air gap between coil and flywheel on a sthill chain saw and flywheel nut size thanks
Use a flexible feeler gauge to measure the gap. The magneto gap for any 2-cycle engine chain saw should 12-18 thousands of an inch. The gap is much less important than simply NOT HITTING the coil frame at any point on the flywheel. The nut is probably metric but I cannot tell you what size it should be. BE CAREFUL! Some chain saws have LEFT HANDED THREADS on such shafts! But you can usually tell by studying the protruding threads at the nut ... if there are any!
Apr 26, 2017 | Garden
Poulan chainsaw not getting any fire?
check to see if your magneto is rusty if so clean with fine grit paper if still does'nt fire may be time to replace the magneto
Aug 08, 2014 | Poulan 16" 38cc Gas Chain Saw P3816
Homelite chain saw 3316c
ok check the magneto if rusty clean with fine grit paper then try it if not then may be time to change the coil and magneto..
Jul 13, 2014 | Garden
What causes a polan chain saw to **** back when i pull the rope
Dorothyjack:
It sounds as though your magneto has gone out of timing. Between the flywheel and the drive shaft there is a small square key that keeps the flywheel from slipping on the driveshaft. The spark coming from the magneto is not causing the spark plug to fire at the exact time it is supposed to. You will need to remove the side cover from the motor, and check to see if the slot in the flywheel and the slot in the driveshaft (where the square key fits) are aligned exactly. if those two slots are not aligned (even a little bit) the saw's engine timing is off. This is caused by the chain being stopped suddenly while you are cutting (for instance if the chain pops off of the chain bar. it will be necessary to remove the flywheel (using a flywheel puller) and replace the key. then reassemble the saw making sure the chain tension is correct and that the magneto to flywheel spacing is correct.
Dec 30, 2012 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin: need gap for magneto adj....
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 27, 2010 | Poulan Garden
Magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Magneto wires got ripped out.
Arboristsite dot com. Please do a search to see if your question has been asked before you post. Lou
Sep 02, 2009 | Husqvarna Chain Saw 20" Bar
Starts but when throttled it dies. Will idle all day at idle.
It may be a faulty coil, but if you haven't tried it yet, I would be inclined to play with the settings of the plug.
Maybe a combination of adjusting the plug, and the gap between the contact and the magneto. If that doesn't do it, change the 'cheaper' contact first.
If problems Still persist, you may have to change the magneto.
Good luck with that, hope I've helped you.
Don't forget to rate ;) thanks
Jul 31, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Weak spark on 55 rancher chain saw/ airgap on magneto
the air gap is .010 to .012 inches,hope this helps, if not contact me and i'll help you with anything i can
Mar 12, 2009 | Husqvarna Chain Saw 20" Bar
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
709 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
