Question about Makita 2704 Contractors 15 Amp 10 Inch Benchtop Table Saw
I need a wiring diagram for a 2704 Makita. - Makita 2704 Contractors 15 Amp 10 Inch Benchtop Table Saw
  • Makita Master
  • 7,733 Answers
Wiring for makita mlt100 i need a wiring diagram
Request the diagram directly from Makita.
Feb 06, 2017 | Makita Saws
Wiring diagram for switch on makita mlt100 saw
ring Makita on 01908 210710 and ask for technical
May 30, 2012 | Makita Saws
My 2704 is blowing fuses, there is no fault on the lead
You may have a motor winding lead that has touched the case of the motor, shorting out the windings, drawing too much amperage, thus blowing fuses. You may have to disassemble your motor and check the stator windings for a short as well as the armature windings. Also the motor could be hanging up due to bearing trouble and causing the motor to draw too much amperage. Probably the cheapest thing to do would be to replace the motor.
Jun 08, 2011 | Makita 2704 Contractors 15 Amp 10 Inch...
My 2704 bench saw has packed up. thought it was the brushes, fitted new ones. it spins up but lot of blue sparks comming out of the motor. It has done a lot of work, is it best to fit a new motor or can i...
before you replace it, you can try and clean the commutator. To do this first unplug the tool and turn the saw on its backside. remove the brushes and find a emory board (cardboard) while turning the blade by hand (use a glove) lightly touch the board to the commutator to try and clean the surface, While doing this try and notice any raised sections of the comm, if there are any then you would need a new armature and possibly field. I would try cleaning first though. Let me know if you have any more questions.
Mar 10, 2011 | Makita 2704 Contractors 15 Amp 10 Inch...
My makita 2704 table saw stopped working while cutting a 4"x2" piece of timber the motor was a little hot so left it too cool an now when i try to start it up it fires up for a second or two then...
there are no capacitators that I see. What I would do is unplug the tool and remove the brushes and check there condition for burning/wear and if you can look into the brush tube and carefully turn the motor by hand and look at the commutator for discoloration. Let me know if you need more help. You can download a breakdown at "makitausa.com"
Mar 01, 2011 | Makita 2704 Contractors 15 Amp 10 Inch...
Electric brake doesnt work unless off switch hit really hard.doesnt switch on sometimes
sounds like a faulty switch. before removing write yourself or take a photo of where the wires go. Also check the condition of the brushes, if they are too short the brake won't work either.
Jan 18, 2011 | Makita 2704 Contractors 15 Amp 10 Inch...
Need wiring diagram to check continuity on trigger switchfor makita 2400b
If you cannot find wireing diagram,just have the saw unplugged and take one of the wires connected to the trigger off. Then by useing an ohm meter you can check for continuity.
Feb 21, 2010 | Makita 10" Miter Saw LS1030N
Makita 2704 I overloaded my motor
if the motor RPM drops dramatically when the noise starts, it is probably a dry motor bushing, if this just started, lubricating the motor may just fix it.
Feb 13, 2009 | Makita 2704 Contractors 15 Amp 10 Inch...
Makita 2704 Contractors 15 Amp 10 Inch Benchtop Table Saw Logo
523 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
