Question about Toshiba Computers & Internet
Need manual for Toshiba 10/100 network, model PA2722U I need the power supply and cord. What are the voltages and amperages for its Inputs and Outputs?
Pyrhyc
  • 2028 Answers
SOURCE: plugged in wrong power cord
There is no overload circuit on these. This probably did in the board, however, it may have just got the processor. Start there.
Posted on Jul 25, 2008
SOURCE: Toshiba P15 S479 Laptop
I had the same problem. The AC adapter connections on the mother board had to be resoldered.
Posted on Dec 30, 2008
Bubbabear64
  • 2794 Answers
SOURCE: The three inputs/outputs on the
Toshibas have an output for using an tv through composite output. It requires a special cable with a mini jack on one end and three rca male ends on the other. The yellow one for video and the red and white ones for audio.
Posted on Jan 16, 2009
  • 25 Answers
SOURCE: Power cord
Depends, do you need just the cord, or the entire adapter? I suggest looking here:
http://www.toshibadirect.com/td/b2c/findAcAdapters.jsp
Posted on Aug 10, 2009
SOURCE: adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Posted on Jan 14, 2010
Using wrong power cord
Sounds like a dirty receptacle. If you're a smoker, I guarantee that's the problem. Take the cigarette lighter fuse out of your vehicle and clean the receptacle with sandpaper wrapped around a small stick. Good luck!
Apr 17, 2014 | Beltronics Vehicle Parts & Accessories
I really need help with this, i cant keep doing this. When my laptop warns me about 10% charge i get confused because i had my ac on the whole time, i check and it says "Plugged in, not charging. Like what...
HI, first of all you should not use another power supply for anything electronic unless you know it has the proper voltage and amperage.
The bottom of your laptop should tell you what "input" voltage and amperage that it needs. The power supply should tell you what "output" voltage and amperage it supplies. You also need to make sure that the "+" and "-" in the circular plug are correct. See the example below.
Using the wrong power supply can seriously harm electronics!
Aside from that, if your laptop is over a year old and you are still using the original battery, it is entirely possible that your battery "dead" or "dying". If it still holds a charge but only last an hour or so it is most likely losing it ability to charge fully.
If the battery is not charging at all, it could be "dead" or the controller for charging the battery could be "dead"... it could also be your power supply!
The only way to really tell is to get either the power supply or battery (or both) tested, to see if it/they are producing the proper voltage and amperage.
Nov 03, 2013 | Toshiba Computers & Internet
Trying to order battery and new power supply for computer 96254
Without the Make, Model of computer It's difficult to help. But a word of advise, Beware of inexpensive aftermarket Batteries and cord/chargers. They sometimes , at best, do not work properly, a worst, can be a fire hazzard. It's cheap for a reason. Be sure to buy the EXACT power specs, Voltage, Amperage. Look to the Laptop Manufacturer for exact replacement. They may be pricey, but , in the long run a better bet.
Dec 02, 2012 | Computers & Internet
My printer will not come on at all. i have the adapter in to the wall jack but nothing happens. i have checked to ensure the wall jack works.
Solution one: Make sure the electrical outlet works
Unplug the power cord from the electrical outlet.
Plug another appliance into the electrical outlet to make sure the outlet works.
If the electrical outlet does not work , plug the product into another outlet that does work.
If the electrical outlet works, but the product still does not turn on , continue to the next step.
Solution two: Make sure the power supply is compatible with the HP product
The term power supply refers to both the power module and the power cord.
NOTE: To make sure that your product and power supply are compatible, HP suggests you use the original power supply shipped with your product.
Example of a power module Example of a power cord
NOTE: The power module might have a permanently attached power cord, or the power cord might detach from the power module.
Make sure the voltage and amperage specifications printed on the power supply match the voltage and amperage specifications printed on the HP product.
Voltage and amperage specifications printed on the power supply Voltage and amperage requirements printed on the HP product
If the voltage and amperage specifications between the product and the power supply are compatible, make sure the connector on the power cord is the same shape and color as the connector on the HP product.
WARNING: Do not force a power cord into an HP product that is incompatible with the HP product (different shape or size).
If the power cord is not compatible with the product, replace the power cord with a compatible cord. To buy a compatible cord, right-click the following link, How to Buy HP , and then click Open in New Window .
If the power cord is compatible with the product, but the products still does not turn on, continue to the next step.
Solution three: Reset the power module and test the power
Step one: Reset the power module
The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
Unplug the power supply from the rear of the product.
Unplug the power cord from the electrical outlet, power strip, or surge protector.
If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
Wait 15 seconds.
Reconnect the power cord to the power module.
Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
Check to see if the power module has an LED.
If the power module does not have an LED, continue to the next step.
If the power module has an LED, check to see if the LED lights up.
If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
If the LED lights up, continue to the next step.
Step two: Test the power on the All-in-One
Follow these steps to test the power on the product.
Reconnect the power supply to the rear of the product.
Press and quickly release the Power button to start a Power On/Off cycle. Do not hold the button down.
Figure 1: Press and quickly release the Power button
If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button again.
If these steps resolved the issue , there is no need to continue troubleshooting.
If the issue persists , see the next step.
Solution four: Test the power with a compatible power cord from a different product
If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
If the product does not turn on with the alternate power cord, continue to the next step.
Solution five: Service the HP product
If you have completed all the preceding steps and are still experiencing a problem, service the product.
Mar 26, 2011 | HP PSC 750 All-In-One InkJet Printer
Can not get hp 1210 to start -power is getting to machine but it will not start..
  1. Unplug the power cord from the electrical outlet.
  2. Plug another appliance into the electrical outlet to make sure the outlet works.
    • If the electrical outlet does not work , plug the product into another outlet that does work.
    • If the electrical outlet works, but the product still does not turn on , continue to the next step.
  1. Make sure the voltage and amperage specifications printed on the power supply match the voltage and amperage specifications printed on the HP product. Voltage and amperage specifications printed on the power supply Voltage and amperage requirements printed on the HP product c01962881.gif c01962212.gif In this example, the voltage (+32 V) and the amperage (2000 mA) from the power supply is compatible with the voltage and amperage specified on the HP product.
  2. If the voltage and amperage specifications between the product and the power supply are compatible, make sure the connector on the power cord is the same shape and color as the connector on the HP product. WARNING: Do not force a power cord into an HP product that is incompatible with the HP product (different shape or size).
    • If the power cord is not compatible with the product, replace the power cord with a compatible cord. To buy a compatible cord, right-click the following link, How to Buy HP , and then click Open in New Window .
    • If the power cord is compatible with the product, but the products still does not turn on, continue to the next step.
Solution three: Reset the power module and test the power Step one: Reset the power module The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
  1. Unplug the power supply from the rear of the product.
  2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
  3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. Reconnect the power cord to the power module.
  6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
  7. Check to see if the power module has an LED.
    • If the power module does not have an LED, continue to the next step.
    • If the power module has an LED, check to see if the LED lights up.
      • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
      • If the LED lights up, continue to the next step.
Step two: Test the power on the All-in-One Follow these steps to test the power on the product.
  1. Reconnect the power supply to the rear of the product.
  2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
  • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
  • If the product does not turn on with the alternate power cord, continue to the next step.
Solution five: Service the HP productIf you have completed all the steps listed above and are still experiencing a problem, service t
Dec 01, 2010 | HP PSC 1210 All-In-One InkJet Printer
What power supply is required for the Bafo 700 7 port usb hub ?
Probably the one it came with?
Anyway, if there are details about voltage and amperage on the back of it you could buy an aftermarket switching powersupply.
The voltage output of the powersupply has to be within 5-10% of what the hub needs, but the amperage can be equal or higher. (anyone who disagrees with this is wrong)
May 26, 2010 | BafoTech BAFO (BF-700) Networking Hub
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
I bought a replacement battery for my Toshiba Satellite m-305D-S8431. The input is 100-240V the output is 19V 4.74 on the original battery and only 19V 3.45V on the replacement. The first day I plugged it...
The voltage is right but amperage is wrong so yes send the battery back and have them send you a battery with the right amperage.
You should be able to use the laptop on AC power for the time being until you receive the replacement battery.
Make sure you tell them the correct voltage and amperage so the don't make the same mistake again.
Good luck and thanks for choosing FixYa!!
Jun 12, 2009 | Toshiba Satellite M305D Notebook
My tablet is not pluging in
Toshiba computers have a label on the bottom that displays the exact voltage and minimum amperage required to power the computer ("DC15V 3.0A", for example, which means 15 volts DC (direct current), at 3.0 amps. Each Toshiba AC adapter has a label indicating its output voltage and amperage capacity (for example, "DC15V 3.0A"). Important considerations for using AC adapters with portable computers:
The connectors must be compatible -- they must mate together correctly.
The voltage level must match exactly (a computer designed to run from 15 volts can be powered only by an adapter rated to produce 15 volts). If the AC adapter's voltage is higher than the computer's requirement, the computer and the battery may be damaged, If the AC adapter's voltage is lower, the computer may not operate correctly, or not operate at all.
The AC adapter must supply at least enough amperage (current) to meet the computer's amperage requirement. Otherwise, the computer may not run properly, the battery may not charge correctly, or may charge very slowly.
The quality of the power (ripple, noise and other factors) provided by the AC adapter must be very high. AC adapters from other manufacturers may supply sufficient amperage at the correct voltage level but the quality of the power may be poor, which can cause the computer to operate erratically, and could even cause damage to the computer. Whenever possible, use the correct Toshiba AC adapter for your computer.
The computer's power light may blink to indicate that there's a problem with the power from the AC adapter.
Mar 25, 2008 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
