Question about Garden
I have a MS181 STIHL chainsaw, within a month of having it, i notticed a spitting spluttering noice, i took it back and they said it was nothing. However it has got worse. I only notice it when its just ticking over. Any suggestions, it almost sounds like this if you say it to yourself ( tuttssss )
    Brigadier General:
  • 4,088 Answers
Check the muffler for loose bolts or blown gasket. If the cylinder head is removable, the head gasket may be leaking every time it fires. Is there a compression release on the cylinder head which could be leaking. Any of these problems should be covered under warranty, but you may need to find a more sympathetic service shop. Hope this helps!
Posted on Nov 09, 2010
Instruction on how to start a stihl chainsaw model 014 AV
this is a picture of a 014
looks basic..older model .. no safety features
starting all depends on
carby idle hi /low set correctly
air filter clean
clean fuel....fuel /oil mix
good spark
new spark plug if required
chain oil in oilier section
correct chain tension on the cutting bar
being a two stroke
and the engine has good compression
crank casing seals are in good condition
never have your body in line with the chain
it could run off the bar at startup ..flick .onto your arm or face
choke on
trigger lock on
hold the handle and pull cord handle ..firmly
let the weight of the chainsaw start itself
let the chainsaw go downwards till motor splutters
choke off
trigger lock on
drop the chainsaw downwards a few more times
and it should start
other way is put foot in the foot plate of the handle
and start sequence is the same
if not something is out of adjustment or needs servicing
Oct 14, 2016 | Stihl Garden
Why is my new stihl is not lubricating blade and chain
Anon there is an adjustment screw as indicated in the manual and this will need turning to start the flow of oil.
Aug 29, 2014 | Stihl MS181 14" Chainsaw
Throttle down linkage
Open up handle and check for alignment on trigger and parts. You can look at an exploded view to see all the handle and trigger parts.
Sep 06, 2013 | Stihl MS181 14" Chainsaw
Throttle trigger will not lock
1. Make sure dead mans handle is fully depressed
2. Squeeze throttle in
3. Push choke switch all the way down
4. Pull saw over till it fires
5. Click choke switch up one position to half choke
6. Pull over saw until it fires up, saw should start running at high rev's
7 .'blip' throttle for saw to return to tick over.
If the choke switch doesn't stay down in section '3' check chokelinkage to carb.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
Gas / oil mix for craftsman chainsaw 36cc
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 26, 2009 | Garden
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
