Question about Whirlpool Ovens
Hi there- the digital temp reading of my oven does not match temp inside. i will set bake temp at 350 and oven stops heating at 200. if i keep turning oven on and off, then it will eventually reach set temp, but after a while, temp starts to go down again. hope you can help- thanks, ruby
  • Ruby Lascano Nov 08, 2010
    Whirlpool Model RB760PXY0
    i'm sorry, i do not understand the last paragraph. please explain. because i use my oven frequently and the holidays are fast approaching, i need my oven to work as soon as possible. is there a definitive solution, instead of trying one thing, then another, then another? thanks a lot.
  • 4,323 Answers
Hi Ruby
The issue is with the oven temp. sensor going bad and should be replaced. Please check this to locate oven temp. sensor: hi there- the digital temp - daniel_s.jpg
Hope this helps....please let me know if you need further assistance.
Daniel
Posted on Nov 08, 2010
  • Whirlpool Master
  • 1,711 Answers
What is the brand and model of your oven
  • espressonist
    espressonist Nov 08, 2010
    Your problem is a very frequent one and easy to understand. Your oven has an electronic control so the temperature is control from the electronic control board and the temperature sensor which are two different parts.
    However since the electronic control is rather expensive is wise to replace first the temperature sensor parts number 9, Oven temperature sensor- Size: 6 inches long. Includes ceramic wire nuts.
    Part Number:
    AP3130719 made by WHIRLPOOL
    Which much more, less expensive and if your problem insists then to go and replace the part number 11, Microcomputer Part Number: AP3095479 made by WHIRLPOOL. Despite that in this case the problem is only one relay on the board you need to replace the whole board.
    The above parts and all other parts of your oven can be found in the following link.
    http://www.appliancepartspros.com/partse...
    Part Number:
    http://www.appliancepartspros.com/partsearch/model.aspx?model_id=258353&diagram_id=88791#d88791
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
Jan 23, 2018 | Bosch HBL3420UC Electric Single Oven
Model RBS275PDB12. I had a recent Power Failure. Since the oven has malfunctioned. When placed on bake the preheat timer does not display. At 350, the baking element gets warm. At higher temps the...
Good Afternoon! If your Whirlpool oven isn't heating to temperature, and your temperature sensor is reading good, the control board may be the issue. Fixyourboard.com can test and if necessary repair the control board in your oven. We back all control board rebuilds with an industry leading two year warranty. Contact us for more information- info@fixyourboard.com
Thank you!
Mar 30, 2017 | Whirlpool RBS275PD Electric Single Oven
I have an XL44 GE Spectra Oven/range. The cleaning feature no longer works and recently we have experienced the oven not getting to the desired temp for both Bake and Convection Bake. We set it to 350 and...
Page 22
Of the service manual shows your diagram. The oven sensor should read 1100 ohms @room temp (75f) All these new fangled electronically controlled ovens use a sensor. The negative temp coefficient sensor relays back changes in resistance whenever the temp changes inside the oven. If that sensor is not correct, open, or shorted to frame then the control will not function properly.
More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 23, 2011 | Ovens
My electric Samsung oven will not hold a temperature setting, especially on the bake setting. The oven seems to preheat fine and then when you put the food in, obviously the temp will drop because you open...
After finding a cheap one on Craig's and reading the problems I decided to roll the dice and buy this range. It has the exact problem described above. The owner had replaced the control module and temp probe with no luck. I hooked up the range and sure enough it would come up to temperature (let's say 350) then dropped back to below 200 and never recovered. Lots of relay clicking but no heat. I unplugged it, took off the back and sure enough, one of the connections to the bottom burner was burnt and the wire was laying in the bottom of the range. I cut the bad part off of the wire, added a new high temp stainless terminal reconnected and viola', it works fine now. Wonderful range for practically nothing. It took about 20 minutes to repair and cost $2.00 for the new terminal. Piece of cake. Take a look inside before you call someone. These terminals Samsung used are cheap, not crimped properly etc.... hope this helps! I'll change them all out tomorrow.
Jun 20, 2011 | Ovens
I turn the oven to 350 degrees and it never gets hot.
First, I guess we need to define hot. If you mean hot enough to bake whatever it is you wanted to bake, then it's possible, if this is a unit that has a "timed bake" feature, that someone neglected to put the control back in manual mode, after having used the "timed bake". If this happened, then the oven will only heat to 160 - 180 degrees, and will maintain that temp. It's called a keep warm setting, which is designed to keep the food that was recently baked, warm, until someone can come get it out and served. Check this feature if you have it and see if it's in manual mode, if not change it and the oven should heat up to 350 and beyond.
If there is NO "timed bake" feature, and there's some heat, just not enough to get to a bake mode, then it's possible that the oven's ceramic glo igniter is cracked and not heating to the point that it allows the oven's safety gas valve to open for gas flow to the burner. If there's no heat at all, the problem could still be the igniter, but it could also be electronic control box feeding the igniter. These things must be checked by a tech with an ohmmeter, and possibly replaced.
Mar 24, 2011 | Ovens
Bottom element is not heating to temp an shuts off during heat up - without error code showing in the display. IE. - Press Bake, 350 degrees defaults on screen; Press Start. YOu hear the Click as it...
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 05, 2011 | GE JTP15 Electric Single Oven
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Hi. I have a ge convection oven(JCTP17) that has been working great until recently. I bought a Taylor oven thermometer model number (503) To check othe oven temps to see how accurate the oven is. I do a...
The Taylor oven thermometer you bought is decent at best. It is most likely the sensor inside the oven. Has your clock displayed any fault codes? F, followed by a number? Changing the sensor will probably correct the problem.
Aug 19, 2009 | Ovens
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Ovens Logo
219 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
