Question about IBM Infoprint 1422 Laser Printer
IBM 4523-001 printer gives 935 print head error. What is the problem?
I use a Unisys uds9718 printer. I receive 935 service print head error. Any suggestions? I have wiped down all the rollers.
This is similar to an error I fixed for a relative, who has an HP printer. What you need to do is call the manuacturer, and ask for another print head. My relative got hers free, because she was under warranty. Hopefully it's the same case for you.
Just change the print head and your good to go. Hope I helped. Post on my site and I will get back to you.
codfanboys.comli.com
Nov 22, 2011 | Office Equipment & Supplies
Lexmark e450dn print head error: 935.1x, 935.2x --------------------------------------------------------------------- what can i do? i cleaned the scanner unit and error its present on...
935 error indicates that scanner motor cannot reach proper speed. Likely the scanner motor is bad but it can also be the controller board.
Mar 10, 2011 | Lexmark E450dn Laser Printer
935 service printer head error. how do I fix it?
The Mirror Motor of the printhead is unable to reach operating speed. This means you have to replace the printhead.
Mar 08, 2011 | Lexmark Optra M412 Laser Printer
Can this fax machine be used as a printer?
Lexmark is one of the industry leaders in printers. Over time with use your printer may require maintenance and you will need to replace the ink cartridges, print heads and ribbons in your printer. If your printer is displaying the 935 printhead error here are some things to look into.
you cannot use fax machine as a printer because it is different specific programmed.
please rate me by telling how helpfull it is.
Jan 02, 2011 | HP 640 Inkjet Fax Machine
935 Service Print Error
935 - Mirror Motor unable to reach operating speed.
This error code indicates a problem with the mirror motor in the laser unit, the cable to the engine board cable or engine board itself.
Check the continuity of the mirror motor cable connected to J3 on the engine board.
If incorrect, replace the cable.
The voltage at J3-7 measures approximately +24 V dc.
If incorrect, replace the engine board.
If correct, replace the FRUs in the following order: engine board -> printhead assembly
Or you could try if a power cycle resolves the error (at least temporarily)
Dec 28, 2010 | Lexmark Optra T612n Laser Printer
Dell 1320C colour laser. Switch on and get the ! led constantly flashing What can I do
Hi there
Not much can do only go over every thing take out all the toners and look all inside make sure there is no paper sticking, make sure paper try is in ok, put all toners back and try again.
All the best and Good Luck : Pineworks
May 09, 2010 | Dell 1320c Laser Printer
PRINT HEAD ERROR
there are several different printhead errors 931 933 scanner motor died scanners bad. 932 934 935 are loose lock errors these can be caused by either the scanner or the engine board
Nov 09, 2009 | Lexmark Optra T614 Laser Printer
Canon i255 printer--print head error
my cannon printer i255 head has a problem and it should be replaced so i need a printer head of i255, please give the price of printer head
Mar 10, 2009 | Canon Office Equipment & Supplies
IBM Infoprint 1422 Laser Printer Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
