Question about Ford Tractor Naa Golden Jubilee Emblem
Need a diagram for steering for 1953 ford jubilee It turn right but the steering wheel unscrew when I turn it left and it dose not trun the wheels at all
3 Suggested Answers
  • 22 Answers
SOURCE: 1953 GOLDEN JUBILEE FORD NAA HARD TO STEER
The best place online to find info about the jubilee is at www.ntractorclub.com and post your question there in the forums. They were able to tell me how to change the front oil seal on my jubillee. As i don't have a front end loader on mine, I think that the guys at ntractorclub.com would have the exprience and knowledge that you are looking for. And it is a free service much like fixya but they are only interested in ford n tractors.
Hatter1
Posted on May 21, 2009
unvme
  • 266 Answers
SOURCE: 53 ford jubilee carburator diagram i need to know
i havent seen one in years.... it's a good tractor.... here is a good website to help you http://www.myfordtractors.com/carburetor.shtml they have the information you need plus the rebuild kits are cheep. this is for 3 differant carbs they used but basics are still the same. enjoy your tractor, there alot of groups that restore these, your tractor was made for only 1 year. this site has other information on 12 convertions , upgrades,parts, and ideas.... good luck and happy riding!
Posted on Dec 27, 2010
2008 pontiac g6 steering wheel removal procedure
Turn on your car. Turn the steering wheel so the front tires are pointing directly forward. Turn off your car.
  • Pop the hood on your car and disconnect the black and red battery cables from the battery with pliers. By disconnecting the battery you will prevent the airbag and horn from malfunctioning or blowing.
  • 3 Take the center cover off of your steering wheel. There should be four to six screws on the back side of the steering wheel. Unscrew these, then pry the cover off with a flathead screwdriver.
  • 4 Remove the retaining clip on the center of your steering wheel with pliers. Place the correct size socket on the retaining nut, and loosen the nut, unscrewing it one turn.
  • 5 Lie back in the seat and prop your knees under the bottom/sides of the steering wheel. Apply pressure on the back side of the steering wheel with your knees by pushing on your toes.
  • 6 Place the rubber mallet over the retaining nut with your left hand. Apply pressure with your knees. With your right hand, bang on top of the rubber mallet until the steering wheel pops loose.
  • 7
  • Unscrew the retaining nut completely and remove the steering wheel.
  • Feb 14, 2013 | 2008 Pontiac G6
    Power steering is hard to turn at times, fluid is full, is there a belt other then the serpintine??? i dont see one on the power steering pump
    does it make noise when turning ? when installing new power steering pump with both front tires in air on jack stands or jacks start and fully steer right fully steer left repeat a couple times and shut off now pump is bled place on ground and test....by turning take a drive....
    Mar 19, 2011 | 2002 Dodge Stratus
    Locked up Steering Wheel
    Your Wheels may not be straight which could cause the steering wheel lock to get stuck. Turn the steering wheel left and right, from one stop to the other, watching how far the wheel travels. Now, turn the wheel to the center of the travel distance and turn the key. If this doesn't free it up, turn the key as you turn the steering wheel left then right to get the lock to release the wheel. Hope this helps and please rate my solution - and thanks for using Fixya!!
    Jan 04, 2011 | 2003 Ford Focus
    Need diagram of how to fit a fan belt to a 1997 ford escort 1.8 16v with power steering and air con
    play in steering wheel when you turn left and right and its stiff turning to the right and it has a roaring when you drive it
    May 01, 2010 | 1997 Ford Escort
    Put in new power steringpump and house on 1999 ford taurus now it keeps blowing off powerstering cap. pushhing out fluid.
    When installing power steering pump you should lift front of car up. Fill reservour up with fluid and trun steering wheel with ignition off about 5 to 8 times full revolution. This will take air out of system. Also make sure that lines are connected correctly. It sounds like there is possiblilty of are in the system.
    Oct 30, 2009 | 1999 Ford Taurus
    Installing a new steering gear in a 96 dodge intrepid 3.5l no clue where to begin as the stearing wheel was not held still so it could be anywhere how does a professional straighten out this kind of unique...
    well you might of destroyed clockspring in steering cloum,(operates horn,airbag and cruise,)if you turn wheel to much with rack shaft unhooked you may have a problem.now use a pair of pliers turn rack shaft all the way to left,now count the turns as you trun all the way to right.(should be about 3turns )now trun back half the amount,3truns is1.5 back.set steerwheel straight,connect shaft.wheel straight.
    Oct 04, 2009 | 1996 Dodge Intrepid
    1998 ford f250 brake lights and turn signals quit working checked all fuses in cab and under hood center brake light works
    Check for a broken wire or loose connection at the multifunction switch. This can occur especially often if you use tilt steering. there is a few screws under the steering column shroud, unscrew the tilt wheel knob, you may vice grips to get it to unscrew. remove the shroud and check wiring and connections, remove the multifunction switch and make sure there are no wires loose in the connectors. If you have a wiring diagram you can jump the circuits at the connector, if no loose anything and you get lights to go on by jumping the switch, replace the multifunction switch (that's the lever on the left of the steering wheel, in case you were wondering)
    Aug 04, 2009 | 1994 Ford F350 Crew Cab
    1953 Ford NAA tractor hard to steer. When small front end loader is full I cannot turn left.
    Hi..my name is Keith..and i restore 9N's,2N's and 8N's..and i have dabbled with NAA's and others..but i would suspect its in the steering box..and i suspect its the left sector gear(steering gear) is worn or has a bad spot on a tooth..i would jack the front axle up and suport it with jack stands and operate the steering wheel and see if i could feel any binding in the steering box or in the front wheel (Left and Right) axles ..and i would also check the tierod ends..i hope this has helped..if not..please write back
    May 26, 2009 | Ford Tractor Naa Golden Jubilee Emblem
    Hatter1
    May 21, 2009 | Ford Tractor Naa Golden Jubilee Emblem
    Noise in front end when steering wheel is turned
    is your van 4WD, AWD, or rear wheel drive? if it is 4WD or AWD, the front axle seals might be going bad. PLEASE RATE MY ANSWER.
    Feb 26, 2009 | 1997 Ford Econoline
    Ford Tractor Naa Golden Jubilee Emblem Logo
    258 people viewed this question
    Top Ford Garden Experts
    Dennis Key
    Dennis Key
    donald boissonneault
    fordexpert
    Are you a Ford Garden Expert? Answer questions, earn points and help others
