Dryers Logo
Posted on Nov 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Convert from 4-wire pigtail to 3-wire pigtail connection. Moved existing Maytag washer and dryer to new home. Existing electric connection was with 4-wire. New location requires me to change. On back of dryer, I see three wires plus green wire to ground. 1. Does it make any difference which way the three wires from pigtail are connected to back of dryer? 2. Do I just ignore the ground? 3. Is there a wiring diagram showing that could be sent to me on how to connect the pigtail?
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Nov 11, 2010
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10845030
Points
101584
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
We have s maytag mdet336aym. The power cord plug does not fit our wall outlet. A person at Lowe's said we could use our old one. It has four wires: green, white, black and red from a whirlpool maybe 15...
As I understand you, you have a 4-wire receptacle in the wall and have just acquired a used dryer, that has an older, 3-wire cord attached. You need to change the dryer cord to connect to the existing 4-wire receptacle in the wall. (Dryers sold new, retail do not come with a cord attached so I assume that this must be a used dryer with an existing cord).
If this dryer has a 3-wire cord attached, it MUST be replaced with a newer 4-wire cord, per the National Electrical Code, as you have a 4-wire receptacle. (However I see no reason that you could not use your existing 4-wire cord from your soon-to-be-replaced dryer, if it's still in good shape).
In older dryers, wired with an existing 3-wire cord, there is usually a metal link provided between the center lug (the neutral lug) and a ground connection on the metal chassis. If it's present, this link MUST BE REMOVED WHEN CONNECTING A 4-WIRE CORD. This is very, very, very important.
The reason is, under a fault condition, current could be carried by the neutral conductor (in a 220-volt circuit, the white wire carries the neutral or unbalanced current. There is no neutral in a 120-volt circuit, even though some people think there is).
The presence of this current can be shunted onto the metal frame of the dryer, making it hot to earth ground (until the circuit breaker pops) and providing a possible shock hazard to a person touching the dryer). Removing this link, removes this potential hazard.
When wiring a 4-wire cord, the white wire in connected to the center lug, the two black conductors (could be a black and a red) are connected to either of the lugs on either side of the center lug, and the green conductor is connected to the metal cabinet. (Once you have the metal junction box cover removed from the dryer, you will see a screw driven into the metal cabinet provided to connect the green wire).
Again, when using a 4-wire cord, there must be no connection between the metal cabinet and the neutral connection through the use of a metal link. It must be removed and discarded.
5helpful
How to connect a four wire pigtail
The white wire goes to the middle terminal post on the dryer.
The red and black wires go to the outside terminal posts.Doesn't matter which.
The green ground wire needs to be attached to the outside metal case...anywhere. The easiest way is to put the eyelet on the screw that attaches the terminal cover plate when you put it back on. Sandwich it between the screw head, the plate and the case.
Hope that helps. Let me know if you need more info
Best, G
I am changing the 4 wire on my 2 yr old maytag dryer to a 3 wire to fit the recptical in my new house. Other then the 2 hots and 1 neutral connection, my dryer also has a white ground wire off to the side,...
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
Feb 19, 2010 • Dryers
2helpful
3 wire to 4 wir
2answers
How to hook up a 4 wire plug to a Maytag clothes dryer model LDE8824ACM with 3 wire connecters.
Feb 09, 2010 • Dryers
1helpful
Need to replace existing three wire plug with new four wire plug. there are only three terminals to connect to. what do i do?
Based on your description....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
Feb 08, 2010 • Dryers
Need to connect 4 wire pigtail to replace 3 wire
The following link explains how to convert a 3-wire to a 4-wire power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the Neutral (White) and the Ground (Green or Bare Copper) wires are terminated at the terminal block. In a 4 -wire configuration these wires are independent of each other. In other words, neutral does NOT get grounded.
If you have any questions, please let me know. I hope this helps you.
1helpful
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
We have a kenmore 70 series electric dryer, and we have a three prong receptacle, but the plug is 4 prong. What type of adapter do we need?
According to the National Electrical Code, as of 2000 all newer homes are required to have a 4-prong receptacle for all 220VAC appliances. However, if your home already had a pre-existing 3 prong outlet, you shouldn't have to upgrade to a 4 prong. The following link explains:
The main difference is how the neutral (WHITE) and green (GROUND) wires are termnated. In a 4 wire configuration, the neutral and ground are independent of each other. In a 3 wire configuration these two wires are terminated together. The instructions to convert a 4-prong appliance to a 3-prong are at the bottom of the page in the link I provided.
NOTE: If this is a new dryer, keep in mind, some REQUIRE a 4-prong plug even if you have a pre-existing 3 prong outlet. Read through your installation instructions that came with the appliance if in doubt. If this is the case, you will need to have a 4 wire outlet installed by a certified electrician.
If you have questions, please let me know. I hope this helps you.
Aug 02, 2009 • Dryers
2helpful
I have an old maytag electric dryer model #DE608 that has a three wire cord. I moved into a new home with a four hole dryer outlet. Can I switch the dryer electrical line from the existing three wire to a...
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Jul 06, 2009 • Dryers
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
