Question about Hayden Industries SuperVac 2400 Central System Vacuum
I have replaced the circuit board twice on my hayden 2400 and after working for 24 hours the circuit board then fails, with no signs of it tripping. Everything is wired in correctly the supplier is unsure of the problem but leading up to me replacing the circuit board the machine itself had became intermittent switching on and off while hoovering
    Novelist:
  • 147 Answers
Disconnect the wiring from the unit, and go back and plug in your hose.
Get a volt tester and test the voltage coming from the lines at the machine. It should read 0 volts. Check both AC and DC voltage.
Also, check the same setup if you have a security system. Arm the security system (or have someone do it for you) and test the voltage at the line again. Again it should read 0.
If both come up 0 volts, the security and the hose I mean, unplug the hose and try one more time again AC and DC volts.
The only other thing i could see it being is a problem with the motor, if the unit is 7-10 years or more, it may need a set of motor brushes for the motor.
Let me know how this goes.
Mark
Posted on Nov 08, 2010
My Henry Hoover cut out and will not work. Emptied bag and replaced fuse but no success.
If no burning or smelling, maybe nothing to do with motor, and if caused by the safety cut-out, it will need about an hour to cool down, and then check filter, bag, and drop coin through hose, pipes and the floor tool, to check for blockages and to stop it running hot. Damaged cable, worn carbon brushes, broken electrical rewind electrical contacts or even the printed circuit board (later models) are the most likely causes.
Jul 08, 2011 | Hoover Vacuums
Please, I want menual kylink General Phone Operation nipx 1000 console
Here is the system description PDF:
http://www.kylink.com.tw/download/NIPX%20series%20PABX%20System%20Description-V5.pdf
If you need a different kind of manual, you can contact Kylink here:
http://www.kylink.com.tw/contact%20us.html
Jul 12, 2010 | Hayden Industries SuperVac 2400 Central...
I have a built in vacuum with a Hayden Deluxe Superpack carpet nozzle. The vacuum works but the Superpack power nozzle does not turn on. Reset does not work. Are there steps for troubleshooting, or...
Find a local vacuum repair center. Could be a short in the hose. The PN could need a new motor or circuit breaker. It will be cheaper to repair than replace, but check the hose for current at the handle end.
Jul 02, 2010 | Hayden Industries SuperVac 6000 Central...
I need a Hayden Superpack Deluxe owners manual so I can change the belt
Hi There,
Actually Hayden uses Panasonic to make all of their power nozzles. Replacing the belt on your Hayden is the identical process to replacing the belt on Panasonic canisters. Kenmore canisters also use Panasonic power nozzles, it's the same process with these.
There is also a power nozzle overload switch on the top of the power nozzle that will shut down if anything is vacuumed up that causes stress on the belt. Try pushing this reset switch before opening up the power nozzle to install a belt. It may be something as simple as a reset switch.
If this doesn't work, here's a link to a repair that I've posted on Fixya on how to replace the belt on a Kenmore canister power nozzle, the process will be identical to your Hayden power nozzle.
http://www.fixya.com/support/t4563318-change_belt_sears_vacuum
Hopefully this helped you. Please be so kind and rate the repair, or leave feedback for the fixya community.
Thank you,
Chris
May 22, 2010 | Hayden Industries SuperVac 6000 Central...
Hayden product. how to disassemble the head to replace the belt.
Actually Hayden's power nozzle is manufacturered by Panasonic for Hayden. Panasonic is the same maker of Kenmore vacuums as well. I have written a detailed repair solution on how to replace the belt on a Kenmore Canister vacuum, and the repair on your power nozzle will be identical.
Here's the link:
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
The only difference could be that you may have a newer style power nozzle then this one, and the screws on the newer nozzles are actually on the bottom of the power nozzle rather then underneath of the headlights.
Hope this helped you,
Chris J.
GoVacuum
Apr 10, 2010 | Hayden Industries SuperVac 3600 Central...
Odd noise coming from central vacumn cleaner
The rattling noise, will likely increase when the head is flipped upside down. Generally means you have a stone caught in the belt or a blown or stripped tooth on the belt.
If you gently squeeze the outside edges of the light housing it will pop off to reveal two screws to remove the lid. Check for other screws at the neck of the power head. Once removed your belt and brush will be visible. Remove the brush roll with end caps and flip the belt inside out rolling it between your finger , look for cracks or a floppy or missing tooth. Replace if any sign of wear.
Inspect the dust caps on your brush. There is a washer under each, likely buried in lint. Do not lose as these are a spacers for each end of the brush. Clean shaft and lube with WD40. Spray caps with the same. vacuum loose grit and dust bunnies away from motor and reinstall, your red button must align with the lid when replacing
Jul 19, 2009 | Hayden Industries SuperVac 2400 Central...
I have a Hayden SuperVac 3600, almost 10 years old. The unit still runs, but now when I switch to the power nozzle, it doesn't have power to turn that. I think this happened once before and maybe they...
The hose has fuseable link inside, generally a 3-7 amp. It is at the wall end underneath the hose cuff. Easy to replace as it crimps in line. If you have a meter you can also test the detachable hose to wall cord for continuity, then check the hose to handle as well.
You can also detach the hose to wall cord from the hose, and plug your power head directly into that cord,, then into the wall thereby eliminating the hose itself.
Hayden makes a serviceable hose. If damaged or the fuse blown it can be serviced by a good tech. If the fuse is blown you need to clean and inspect the power head as this may be the cause
Jun 20, 2009 | Hayden Industries SuperVac 6000 Central...
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Hayden Supervac 3600
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11860&thid=808510
Posted by kdm0 on Jul 20, 2008
Hi, I have a Hayden Supervac 3600 central vac system in a house I just purchased. The Amber light indicating that it needs regular maintenance is on. I have cleaned and serviced the motor, everything is fine and suction is well. How do I reset the service light? The reset button seems to do nothing. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I heard of this happening before and you need to refer to the owner’s manual and or to contact the factory or manufacturer of which I will provide to you @ the end of this question. There may be some type of rely switch or board that might need replacing but check with the factory. If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.haydenvac.com/company/company.html
Customer Service 1-800-461-5300
Company Phone # 1-705-726-3361
Company Fax 3 1-705-726-2186
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 20, 2008 | Hayden Industries SuperVac 3600 Central...
Hayden Vac2400
Check the carbon brushes, they maybe worn out and need replacing.
Jan 06, 2008 | Hayden Industries SuperVac 2400 Central...
Hayden Industries SuperVac 2400 Central System Vacuum Logo
303 people viewed this question
Top Hayden Industries Vacuums Experts
Are you a Hayden Industries Vacuum Expert? Answer questions, earn points and help others
