AC doesn't blow cold air
Please email instructions to rich_gelman@yahoo.com
...would be sincerely appreciated. so sweaty, can't sleep at night.  unit blows room temp air. bought at walkmart just 12 months ago. thanks in advance,
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Threr are suppose to be two sounds comming from the window unit. One, the fan sound and the compressor sounds, (this compresses the refrigerants aove room temperatures (around 240*) & send it to the back coils and remove it to room temperatures and send it to the front coils which if enough freon, it will cool to at least 40*. Turn the thermostat all the way up or down while its off and see if you hear a clicking noise which tells you the thermostat is working which that what calls for cool. If it started loosing cools little by little, then you have a leak, and leaked all the freon out! If it stopped cooling all of once, then your compressor is not kicking in.
Posted on Jun 18, 2008
Bluestar split ac indoor unit making abnormal noises. I have a 5 star 1 ton bluestar ac model 5HW12ZBI. It makes noise (kit -kit) when the ac trips off. The noise is minor during day time but it Ibecomes...
From your details i can observe the blower motor bearing worn out. or its side bushes in which there is small bearing that may be worn out. Replace it. Finally check for correct voltage too.
May 07, 2014 | Heating & Cooling
97 Nissan Maxima heat still blowing when AC is on
Well thinking about the problem there e a flap in the vent pipes to shut off theatre and ac unit perhaps something has got in the pipe and stopping it closing or perhaps your heater control is US and needs replaceing . ( but I take it you have turned your heater to cold )
Dec 14, 2017 | 1997 Nissan Maxima
Cold and hot stiky air
try cleaning the filter and fan blades.
Jan 01, 2012 | Heating & Cooling
I noticed my ac in my 2004 Corolla with 138,000 miles wasn't blowing as cold in recent months. I've never had the AC serviced in the 8 years I've owned it. So I used one of those 12 ounce self...
If this was happening to me.... I'd goto an airconditioning re-gas centre and get them to check for gas leaks. In my old commodore the Evaporator Core was leaking and causing some of the issues you have mentioned.
Aug 04, 2011 | 2004 Toyota Corolla
MY WINDOW AC UNIT DOES NOT BLOW COLD AIR. I CHECKED THE FILTER, AND IT IS CLEAN. ANY SUGGESTIONS WOULD BE APPRECIATED.
Depending on the age of your unit, you could need some coolant added because the unit might have developed a leak. Also, generally in the top of the unit, you will see the cooling coils. These may need to be brushed if there is an accumulation of dust because this will prevent cooling. Finally, and I hate to admit this, but sometimes my unit is switched to "air" or to "exhaust" and of course, all the air is blowing OUT instead of IN.
I hope one of my suggestions helps. With this heat, you don't need to live without your AC. If this does help, please rate my suggestion!
Jun 07, 2011 | Heating & Cooling
The air conditioning isn't blowing cold air anymore. It takes a while for it to get Cold, it blows cool air but not cold.
My name is Ron,and I have one solution,Sounds like you need some freon added,if that doesn`t fix ya ,the ac compressor could be weak,or blockage in ac system,or vent door not opening,or opening slowly,and not all the way...hope this helps,roniecon@gmail.com
Jul 19, 2009 | 1996 Ford Explorer
AC not blowing cold air at times
poss causes are, sticking low pressure switch, defective Ac compressor clutch closing coil or incorrect clutch driven plate air gap, spec is 0.26 thousands.
May 11, 2009 | 2003 Ford ZX2
Need insturction manual for Model 8996CRH
email me if you sitll need it. desirae2323@yahoo.com
Feb 26, 2009 | Simplicity for Children Ellis 4 in 1 Sleep...
Central Air not cooling properly
This tubbing carries the refrigerant. The small line is flowing to their inside air handler. If the line is hot it is an indication that the outside unit is not able to release the heat. The most common reason is that the coil (looks like a car radiator) is dirty or plugged. This can be cleaned with a brush or sometimes a garden hose. They do make acid type cleaners for doing this, but the use of the acids are restricted in some areas.
By the way the other black pipe should have a larger copper line behind the black insulation. That line should be cold and sweaty like a nice glass of ice tea:)
Jun 26, 2008 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
679 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
