Question about Citizen iDP-3550 Matrix Printer
How do i reset my citizen 3550 printer - Citizen iDP-3550 Matrix Printer
3 Suggested Answers
SOURCE: Citizen iDp 3550 prints double-spaced
It is a dip switch setting, on dip switch #6, it needs to be "On" It will then single space the lines. After re-setting the switch under the cover, turn off the printer for 30 seconds to clear the buffer...then holding the "LF" button, turn it back on, until its self test is complete. You problem will be over.
Posted on Feb 06, 2008
  • 127 Answers
SOURCE: i have a citizen 3550
Thank you for posting to Fixya.com and it is my pleasure to guide you.
To help you in the furture I have found the manual for reference. Click the link or copy paste it to download it. http://www.posguys.com/download/iDP3550UME_09E.pdf
From the manual for the Interface Cables, the manual has pictures.
4.2 Connecting the Interface Cable
1. Turn off the power. (Mating side included)
2. Check the top and bottom of the cable terminals, and connect to the interface connector.
3. Secure the cable terminals.
Serial interface: Tighten screws to secure.
Parallel interface : Turn clamps to secure.
4. Connect the interface cable to the computer.
4.3 Connecting the Drawer Kick-Out Connector
2. Check the top and bottom of the drawer kick-out cable connector and connect it to the drawer kick-out connector located at the lower section of the printer.
3. Screw the grounding cable of the drawer to the grounding terminal located at the lower section of the printer.
CAUTION: • Connect only the prescribed drawer (Solenoid) to the drawer kick -out connector.
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Posted on Jun 21, 2011
Printer double spaces between lines
That is a setting in your printer setup menu under options or advanced. Page set up should come up under advanced or as its own tab.
Apr 09, 2014 | Citizen iDP-3550 Matrix Printer
I have a citizen 3550 printer how can i hook it up to my computer to print out misc. things instead of using you conventional printer?
Jun 21, 2011 | Citizen iDP-3550 Matrix Printer
Printer is printing jibberish = looks like a lot of "f"s underlined.
Try to turn the printer off and then on again. If that does not clear it you need to re-install the driver, the driver may be corrupt.
Nov 16, 2010 | Citizen iDP-3550 Matrix Printer
My hp deskjet 3550 is not printing. the green light at the power button keeps on blinking. What is the problem? both ink cartridges are full. there is no paper jam.
1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
May 28, 2010 | HP Color Laserjet 3550 Printer
I lost the CD installer of my HP Deskjet 3550, how I can install it?how do i install the printer... I lost the CD installer of my HP Deskjet 3550,HOW CAN I GET
Below is the link for you to install the Softwares / Drivers for your HP Deskjet 3550 Printer.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=305947&lc=en&cc=us&dlc=en&lang=en&cc=us
Just select your OS (Vista, XP or whichever u r using) and you will get the software and drivers for the same.
Hope this will help.
Apr 24, 2009 | HP DeskJet 3550 InkJet Printer
Hp 3550 fuser problem
try this
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support
Oct 29, 2008 | HP LaserJet 3550 Printer
Hp 3550 software
Here you go. Just click the link below to take you to the download site.
HP 3550 Printer drivers and software
Oct 14, 2008 | HP DeskJet 3550 InkJet Printer
Hp 3550 driver
i need the drivers of the printers hp 3550 deskjet
Sep 16, 2008 | HP DeskJet 3550 InkJet Printer
Jan 14, 2008 | Citizen 3550 Matrix Printer
Citizen iDP-3550 Matrix Printer Logo
132 people viewed this question
Top Citizen Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tejodhar Atreya...
Tejodhar Atreya...
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
