Question about Hotpoint Dryers
I have a hotpoint gas dryer that blows cold air not hot
  • Hotpoint Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
dididsaythat
  • 291 Answers
SOURCE: Electric Dryer
Dont see a model # or make  but here some tips
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a..
Hi-limit fuse that need to be checked for Continuity and replaced if bad
if you dont have a ohm meter you can hook the wires together
with a small piece of wire and by pass the themostates and hi limit fuse to see if thats the problem or not
Posted on Oct 17, 2007
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
  • 686 Answers
SOURCE: Maytag Gas Dryer MDG308DAWW doesn't blow hot air, no clicks heard
Look at the bottom of your front panel and see if you can see a screw on either side about 2-3 inches from the very bottom edge of the front panel. If so take them out and pull the bottom away far enough to disengage the top of the front panel from the top panel. If this works for ya. then now you have it openened, if not repost me.
Posted on Apr 13, 2009
  • 52 Answers
SOURCE: dryer does not blow hot air
If this is an electric dryer, it could be the heating coil is broken or burnt through, you may have a restriction of built up lint in the vent hose, or one leg of the 220 volt breaker tripped. Please rate my solution.
Posted on Apr 21, 2009
SOURCE: Dryer blowing cold air only
older homes with fuses can have to fuses on the dryer circut-1 could blow and the dryer would run without heat
Posted on Jun 20, 2009
Why is my dryer blowing out cold air?
It sounds as though you have a defective heating element.
May 31, 2012 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer heats up for a couple of minutes and then stop heating and blow cold air
Try cleaning out your Lint Trap, this will be either on the door inside, or inside at the back of the dryer, this should just pull off, remove the built up lint and replace.
Nov 02, 2010 | Hotpoint NWSR483GBWW Gas Dryer
Dryer only blows cold air
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Feb 09, 2010 | Hotpoint TDC32 Electric Dryer
No hot air blowing - cold air only. Hotpoint Aqurius condenser dryer.
We have a full video library on appliance repair video’s
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Jan 02, 2010 | Hotpoint Dryers
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
Hotpoint tdc62p changed thermostats as blowing out cold air,
Make sure that all filters are properly cleaned, and that the air inlet and outlet vents are clear. Make sure water container is empty.
The best way to clean the filter at the bottom is to run cold water through it, this will clear out all the lint.. Make sure you have the correct stats ( there are many for the hotpoint range) and that you have them in the correct position on the heater back plate.
Plz rate this solution.
thanks.
Dec 16, 2008 | Hotpoint TDC32 Electric Dryer
Blows fuse for heat after about 30 minutes
yes , occassionally though it will run for full cycle ....but not very often
Sep 06, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
60 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
