Question about Kyocera CS-2050 Black and White Copier
We installed a new toner cartridge in our copier and now "image cycle" appears. What does this mean? and how do we fix this issue? our copier is a Kyocera mita
  • 165 Answers
It is just an internal counter for for drum or fuser just ignore it
Posted on Nov 20, 2010
Printer has all full cartridges, not printing clearly
Does this machine have drum units, image units and toner units? what combination? Replacing the toner cartridge will not fix the issue with the drum or image unit.
Nov 20, 2015 | Office Equipment & Supplies
Independent-supply toner message
Treat the same as "Non-Genuine Toner". Caused by installing a refilled toner cartridge or taking out cartridge out, putting a new toner, and then putting the old one back in. Place a new toner in the machine, change SP5-051-001 to 1, and cycle power.
Jan 12, 2012 | Office Equipment & Supplies
I have a Sharp SF-2020 pedestal copier. The red triangle dots appeared above the yellow digital copy #. Prior to this, it took over a minute for the copier to "boot up". I added factory toner...
Hi r_finch424,
The blink red triangle means that the toner is completely over and can't be refilled. The toner cartridge comes with on-chip sensor that counts the toner life. To resolve this issue, you need to replace a new toner cartridge.
Hope it helps.
Thank you for using FixYa.
Aug 29, 2011 | Sharp SF 2020 Copier
My Canon MF3240 Printer says "Toner is not set" "Insert Toner". I've tried all the stuff I found online such as... - remove paper, remove and replace toner - clear paper or dust...
Welcome to Fixya
This means that the toner is inserted properly. I provided you link on how to install the cartridge properly. Try to take out the cartridge and wait for 1 minute then put it back in.
Let me know if you have further questions.
Thank you for using Fixya!
Apr 08, 2011 | Office Equipment & Supplies
Thank you Kitty but I'm not clear on how cleaning the Print Heads and replacing toner would fix this faded banding issue. I printed long Vertical bars of Magenta, Cyan, Yellow and Black. All colors fad at...
you need to clear the rollers and the heat drum (fixes the image and melts the toner onto the paper) if you have done any two sided copy, or have used paper with an image on one side, the ink may have gotten onto the roller and left a trace which would account for the banding being in the same place all the time. the rollers and etc are difficult to get at, and not really a job for amateurs
Mar 10, 2011 | Samsung Office Equipment & Supplies
Code erreur U2-40
U2-40, mostly appears in sharp copiers when you installing new toner cartridge.the reason of this code is faulty CRUM chip because of different type of toner manufacture .
you cane this problem by replace the chip in the new toner cartridge by the chip in old toner cartridge
- the chip is located in the rear toner cartridge -
I hope this help!
Feb 14, 2011 | Sharp AR-5316 Advanced Digital Imager...
I changed the toner on my Lexmark E250dn and now it has the "!" light on all the time and won't print. It's a new cartridge what is going on?
"!" means error.
Try removing cartridge and installing it again and might be one of the cartridge missing.
Try operating manual. Might helps, there are lots of reason for the error
ftp://ftp.lexmark.com/depot/LXK/E250_Depot_Repair_rev092606.pdf
Suspected
Follow the link on dispute about wrong cartridge due "Toner cartridge region mismatch"
http://www.techsupportforum.com/hardware-support/printer-support/379157-lexmark-e250dn-amp-quot-toner-cartridge-region-mismatch-amp-quot.html
Hope this helps
May 21, 2010 | Lexmark E250dn Laser Printer
Message: Dispose of use toner powder
try installing a new cartridge or a reconditioned one it would be cheaper, some have exchange of toner catridges and a small fee for a reconditioned one
rod
Feb 03, 2009 | Lanier Office Equipment & Supplies
HP laserjet 2100
You could do whats called a 1/2 test...put paper in the mp tray, do a print and when there is only about 2-3 inches of the paper sticking out the mp tray open the toner lid and lift out the toner cartridge..pull back the toner drum protector/flap and look at the image on the drum or the image that was about to go down on the paper...is it nice and dark on the drum..if so then you have a toner transfer issue...getting the toner from the cartridge to the paper. If this is the case then you may want to start with a new transfer roller. If the image is not dark on the toner drum then this an image formation problem. Some of the solutions here are bad toner cartridge (suggest using an OEM until problem isolated)....bad laser scanner or a dirty scanner....or a bad high voltage power supply ...
Inkworks
Apr 17, 2008 | HP LaserJet 2100 Printer
COPIER
its self adding toner, besure your cartridge is not empty, take it out and shake it side to side. youll feel if its got toner, Remember kids, when you shake up toner, it gathers air and will leak or pour just like water. you may have to turn off & on so it completes its stir cycle a couple times. By they way, i,m not an apprentice or rookie. long time service co owner.
Dec 07, 2007 | Kyocera CS-2050 Black and White Copier
Kyocera CS-2050 Black and White Copier Logo
60 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
