Question about KitchenAid KGST307 Gas Kitchen Range
When I opened the oven door the left side hinge pulled out of the range about 3 " I can't push it back in Did screws fall out inside ?
2 Suggested Answers
  • 1314 Answers
SOURCE: Oven Door Hinge is broken Kitchenaid KERC507 range
at about any appliance parts store in you area you just need your model and serial number there are links on this site kitchenaide is made by whirlpool so they can help or if you want to do it online this is good http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jun 20, 2008
Oven door removal
Most residential oven doors are removable by taking out two screws of each hinge. Located on the door on left n Right sides where the hinge slides into the door. These also are the way to adjust the door by loosening n then snug the screws, close the door. Adjust it, then carefully open without affecting your adjustment. Then tighten the screws. When removing the door MAKE SURE THE DOOR IS FULLY OPENED. THE HINGES ARE SPRING LOADED N WILL SNAP BACK.
Sep 24, 2012 | Whirlpool WFE361LVS Stainless Steel...
Whirlpool Supercapacity 465 Oven (RF396 LXE2) Door Problem
These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
Feb 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Hinge receivers for u1661
I had this EXACT same problem and the hinge receivers WERE THE PROBLEM!
Easy fix. All you need is a Phillips head screw driver (cross head that is) and about 30 minutes.
1. First off remove the oven door.
2. pull out over so that you can easily access the rear
3. Disconnect oven from the electricity (make sure the mains power is OFF before you do this)
4. Remove the back panel by unscrewing all the screws
5. turn oven over onto its side and remove the bottom panel (more screws)
6. You can now get to the receiver - its held inplace by 1 screw just inside the oven door above the receiver (and maybe another 1 on the side, but i cant remember).
7. Undo screw(s),slide out receiver, replace and put back together in the reverse order.
Honestly, it is very easy (I did it with no help, idea and 1 have 10 sausages for fingers).
Sep 07, 2012 | Neff U1661 Double circotherm super...
I need to replace the hinge receptacles on a Jenn-air wall oven (WW30430PC). How do I access those parts?
The only way to replace the hinge receptacles is to pull the oven out of the opening. If you need parts you can get them on the link below. Also if you call the link below they will walk you through on how to replace.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45883&diagram_id=28594572#d28594572
May 16, 2011 | Jenn-Air Ovens
I have preloaded the replacement hinge, but it appears that to remove the old hinge it must be unloaded. If that is true, how do you load the new hinge while it is on the door?
Ovens come in many varieties including freestanding units and stacked models that are inserted into a wall. Kitchen oven units that get a lot of use or are getting old may have problems develop, such as a loose or squeaky door which may require replacing the hinges. You can replace the hinges on the door to your oven by first removing the door from the rest of the oven.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate Instructions Things You'll Need:
  • Screwdriver
  1. Step 1 Open the oven door and examine the hinges to see how the they are secured to the door. Some oven doors slide into the hinge assembly or have a locking mechanism that secures the door to a latch on the main unit.
  2. Step 2 Remove the door from the oven by disengaging the locking mechanism and then pull the oven door out. You may need to release a catch on the door or remove a pin from a hole in the hinge.
  3. Step 3 Place the door on a flat surface such as a table or the floor.
  4. Step 4 Remove the screws that hold the sections of the door together to access the hinges.
  5. Step 5 Remove the hinges from the door. The hinges may be attached to the door with screws or they may be held in place when the door sections are tightened or secured.
  6. Step 6 Insert the new hinges into the door and secure them with the screwdriver or place the section of door back on. Tighten all of the screws securing the sections together.
  7. Step 7 Place the oven door back into place by sliding it on the same way that it came off.
Regards
Iversh
Jul 24, 2010 | Ovens
I removed the range door to clean oven. Now I
NOTE: The door removal pins you inserted must still
be in both sides of the door.
1.
Grasp the door on the sides with your fingers on
the front of the door and your thumbs on the
inside surface.
2.
Rest the hinge hanger so that it is flat (at the
bottom of the hinge hanger on the bottom of the
front frame slot).
3.
Position the door with the hinge hanger slots
almost parallel to the front frame.
4.
Push up and in until the hinge hanger slots
become fastened to the range. Lower the door
and rotate it slightly from the front to the back
until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front
frame slot.
5.
Pull door open about halfway and remove the
door removal pins. Save door removal pins for
future use.
6.
Close the door.
Dec 25, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool range
Hello dolphin 1 mom
Welcome tofixya.
You said, accidentally removed the door to my range and now it won't go back on. The door won't go back into the slots on the range.
Send me your e-mail address and I'll e-mail the diagram with the door instructions for removal and replacement.
It will not fit in here with the diagrams.
Waiting for you.
Huuum
Please do not forget to enter a rating when we are done
These are the installation instructions, but with no diagrams
To Remove:
1. Open the oven door. Insert door removal pins, included with
your range, into both hinge hangers. Do not remove the pins
while the door is removed from the range.
2. Slowly close the door until it rests against the door removal
pins.
3. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on the inside surface.
4. Pull door straight up, then toward you. Hinge hangers will
slide out of front frame hinge slot. Do not remove door
removal pins until the door is replaced on the range.
To Replace:
1. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on its inside surface.
2. Hold oven door so that the top edge of each hinge hanger is
horizontal. Insert hinge hangers into the front frame hinge
slots.
3. Tilt top of door toward range. Slide hinge hangers down onto
front frame support pins. Make sure the hinge hangers are
fully seated and engaged on the support pins.
4. Insert the door stop clip with its angular surface at the top of
the frame hinge slot, then push in the bottom of the clip until
its flanges are flush with the front frame.
5. Open the door completely and remove the door removal pins.
Save door removal pins for future use.
6. Close the door.
StorageDrawer
The storage drawer can be removed. Before removing, make sure
drawer is cool and empty.
To Remove:
1. Pull the storage drawer straight back past the drawer stop
notch and the end of the side rails.
2. Lift up the back of the drawer and pull the drawer out.
To Replace:
1. Lift up the back of the drawer and place it inside the range in
its fully forward position.
2. Lift up the front of the drawer to a level position.
3. Slowly push the drawer into the range until the drawer side
rails engage with the gap in the drawer glides.
4. Once the drawer is fully engaged on both sides, slide the
drawer back into the closed position.
NOTE: When removing and replacing the storage drawer, a slight
push may be needed to move the drawer stop notch past the
drawer glides.
A. Removal pins
B. Hinge hanger
A. Hinge hanger
B. Door frame hinge
C. Support pins
A
B
A
B
C
A. Drawer stop notch
B. End of side rail
A. Engage drawer glide
A B
A
Sep 09, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Stove handle/door
need strong fingers and a helper... lay the door on the floor push open the hinges and there is a hole on the side of the hinge have your helper slide in a small nail only about 1/4 " in to the hole this will keep the hinge out do the same on the other side then reinstall the door open up and remove your nails
Feb 26, 2008 | Whirlpool RF315 Dual Fuel (Electric and...
Oven door
it depends on the type of hinges, you would most likely have to push the hinges down and latch it with the small hook on both sides then put your door back on , push the door fully open ond unhook the small hooks.
Feb 18, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Amana ARG7300 Oven Door won't go back on
The hinges are not sticking out enough ( tabs have wore down ) to engage the hinges on the door . Push the hinges out with a screwdriver and measure the distance to a screw further up the door and cut two pieces of wood (one for each side ) .push the hinges back out and jam the wood in . It goes in easy and the wood falls out when you put the door to open
Jan 23, 2008 | Kitchen Ranges
KitchenAid KGST307 Gas Kitchen Range Logo
131 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
