Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
What would the dimensions be for a sub box if i were putting two solo baric l7's in it?
  • 23 Answers
Check out these pages for some good info on enclosure basics and Solobaric specifics:
http://www.kicker.com/intro_to_enclosures
Posted on Nov 09, 2010
L7 15 not sounding right.how do I wire the sub in a ported box
It's quite simple, positive from amp to positive of speaker, negative to negative. Make sure it's getting sub frequencies only and not full spectrum signal. Next (if everything checks out so far) see if the box dimensions and ports are correct for your sub. The sub and box combo will have lots of factors when considering tuning of the box and port size. You can find all sorts of info on the website for your sub. Qtas, max excursion etc etc etc. They might even list a few total volume and port dimension sizes for the sub you have and your taste in music. It's quite a science to get it right. More than buying a sub and buying/building a box to get great performance. When you get it right though... music to your ears (and chest)
Feb 20, 2014 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
My kicker 12 inch solo-baric L7 rattles real bad like something is loose but there is nothing visibly loose what could it be ?
Its blown. Maybe not completely but youve done some damage. If your sure its not hitting the box anywhere and its tight, then thats what it is. Youve burnt the voice coils a little. They regulate how far the sub goes in and out. I have two kicker L7 12s that have bad voice coils. And thats what they do. Theyre in my trunk though so its not to noticeable and they still hit super hard. -->
Also it could be the seal for the box. They wear out and boxes get leaks or weak causing flexibility in the material so when subs hit it vibrates the box really bad. Try removing she speaker from the box then turn it up and see if it makes the noise. If not then its probably the box. Let me know.
Feb 10, 2011 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I have a Kicker Solo-Baric, L7, 12 inch subwoofer making a scratching noise. The cone is fine but the inside is not. Can i get this repaired? Kicker said no. This is a $250-300 sub. I hate to just throw it...
The bad news is that your voice coils could be fried up, basically mechanical failure. Might as well buy a new sub because replacing a voice coil means you got to rip the whole sub apart, very complicating.
Oct 15, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
S10L7 displacement
Recommended Sealed Enclosures – Moderate Efficiency
  • 0.66 cu ft is the displacement of the sub
  • S10L7 .66 cu.ft. Power Handling = 600W 1.0 cu.ft. Power Handling =600W
  • 18.69 l 28.32 l
The following page shows examples of the minimum enclosure sizes for each of the Solo- Baric L7s. Panel dimensions assume 3/4" wood thickness. 5 Panel dimensions for minimum recommended enclosures: Model Volume (cu.ft.) Panel A Panel B Panel C S8L7 0.33 10"x10" 10"x8" 8"X8.5" S10L7 0.66 12"x12" 12"x10.5" 10.5"x10.5" S12L7 0.88 13"x13" 13"x11.5" 11.5"x11.5" S15L7 1.5 16.5"x16.5" 16.5"x11.5" 15"x11.5"
Jun 03, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I bulit a box for 2 L7 15s and at about 1/2 WAY up one of em seems to pop or bottem out
The box is either to small or to big or requires a port or not, depending. The box must be within spec for the subs.If box is smaller put stuffing in the box will make the box seem bigger to the sub.
Here is a website that is about making sub boxes and will give you an understanding of how sub boxes work
http://www.diysubwoofers.org/faq.htm
Mar 24, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How do i wire my solo-baric L7 12"
how should i wire my s12 L7 2 ohm dual voice coil to my JL 500/1 amp
Sep 15, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I have my l7 solo baric on series mode they sund
Hello rigo11785,
The MTX Thunder 1501D is stable at 1ohm and outputs 1,500 watts RMS into that impedance. An L7 with 2ohm DVC's would present a 1ohm load if wired in parallel and would allow the amp to produce more power than into the 4ohm series load. The problem is that the L7's maximum power handling rating is only 1,000 watts RMS, so if you wire the coils in parallel, you'll very likely overdrive the sub and perhaps damage it. Now, if you bought another L7 and ran the voice coils in series and the subs in parallel, that would be a 2ohm load and well within their power handling capability.
With that amp and sub, I'd recommend leaving the voice coils in series.
Hope this helps.
Jul 28, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Whats the best settings for a 2 ohm solo baric 15
settings are all about what amp and box u got. tell what setting your talking about.
Apr 21, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
78 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
