Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
My hayward fires up for about 6 minutes then shuts off with a LO alert blinking
    President:
  • Hayward Master
  • 1,378 Answers
You problems could be in any of the following areas per the Hayward owner's manual. If you need help with continuing the diagnosis please comment with what specific help you need.
my hayward fires up for about 6 minutes then shuts - john224.jpg If you can not enlarge this enough to read it, please contact me thru our site at www.arrowpools.net and I'll email the manual to you. If you have the manual that came with the heater, your troubleshooting info is on page 38.
John
Posted on Nov 08, 2010
Hayward h200 pool heater (LO) Error code
check gas pressure sounds like gas meter is too small
Jul 12, 2013 | Hayward H-series Electronic Gas Pool...
Our hayward heater H250 model was installed last year.. this year it started up after the winter no problem. We put it on Standby mode while the poolliner was being replaced and not it will not come on.....
Thank you for posting your question here on Fixya.com.
A 'LO' error code for a Hayward heater is a limit string open error. If the limit string opens the heater shuts down and goes into lockout. Automatic restart is 2 minutes after the error condition is corrected and the limit string closes.
The limit string is a series of switches designed to turn off the heater if air or water temperatures exceed a safe operating limit.
The problem may be faulty a switch(es) but is far more likely to be a system condition the switches are reacting too that needs to be corrected. Low flow of combustion air due to obstructions around the heater or the vent; low flow of water through the heater allowing too high a water temp; Poor venting or sooted-over heat exchanger causing flame rollout; inlet and outlet hose connections reversed; these are all conditions that should be eliminated if they exist.
If you are not familiar with these switches or the conditions described you may want to consider calling in a professional. Hayward can refer you to someone in your area who is. Call Hayward at 908-351-5400 or try the website locator found here. It is likely to still be covered under warranty.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Jun 08, 2011 | Hayward 250kbtu Ng Pool Heater - Inground
Lo error showing and it kicks off about every 6 minutes
The problem may be faulty a switch(es) but is far more likely to be a system condition the switches are reacting too that needs to be corrected. Low flow of combustion air due to obstructions around the heater or the vent; low flow of water through the heater allowing too high a water temp; Poor venting or sooted-over heat exchanger causing flame rollout. These are all conditions that should be eliminated if they exist.
John
Mar 23, 2011 | Hayward H Series Pool & Spa Heater 400k...
HOW DO YOU CORRECT ''LO'' ERROR (LIMIT STRING PROBLEM) ON A HAYWARD HEATER H250FD??
You need to find out what is bad in the string. The first thing to check is the pressure switch. Not so much the switch but clean the filter and baskets and check the impeller for a clog. These will let the pre sw shut the heater down. The second thing to check is the roll out switch. This is in the bottom of the cabinet on the fire wall just above the burners. It looks like a black sleeve on the wire that crosses the cabinet. It's a wax switch that melts and shuts the heater down if the fire rolls out the front of the heater. If this has gone bad you will need to find the reason it did and fix that or it will just do it again.
The other things on the string you just need to jump past and check, then replace the bad component. Good luck.
Sep 06, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Jul 12, 2010 | Thermador PC366BS Stainless Steel Gas...
Pool heater trouble
LO would be low water pressure. You may want to have a pro look at the heater only because it can be dangerous to work on it with out the proper knowledge.
Jul 03, 2017 | Hayward 250kbtu Ng Pool Heater - Inground
Heater fires but only runs 2 minutes then shuts off is a model abg100 swim pro by hayward
the pump is not circulating, so the high limit is shutting it off. You need to check out your circulating pump
Sep 05, 2009 | Hayward H Series Induced Draft Abg 100,000...
LO service message
LO is ignition lockout. The heater has tried to fire three times without success. It is usually the prressure switch but can also be the temp limit switch or the vent pressure switch. Locate and jump one at a time to find faulty switch.
Aug 15, 2009 | Hayward H Series Pool & Spa Heater 400k...
"LO" error code on new H400FDN heater
it is low water pressure sensed, unit will not start unless pump is working
Jun 07, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Error code LO
Is the heater installed indoors?? if so you'll need a vent pressure orifice kit.
if not check your water press. (below 18 PSI on filter) Place filter on "recir" if it fires and stays on . it's the pressure.
check to see if all connections a set tight hi-ltd switch wire harness etc.
May 24, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
390 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
