Question about Goodman GMS90703BXA Heater
I have a Goodman GMP 075-3 Rev B and cannot find the filter to replace it can you tell me where it is
I have the EXACT same problem. Cant find the filter and no manual came wit hthe furnace when I bought hte house!!! AGH!!
Posted on Dec 02, 2010
  • John Eckart Dec 21, 2010
    According to the manual, if your furnace width is 14", then the filter will be 14 x 25 x 1, but i have found that i need to use a 12 x 24 x 1 on mine because the larger one doesn't fit. I could probably squeeze a 13 x 24 x 1 in there though. You're probably going to have to do a trial and error.
Janitrol gas furnace gmp 075-3 ,ignitor lites but pilot nor heat will go on
Check out pressure switch , check hoses are tight and not split , check air filter is clean jump out pressure switch and see iif it lights .
Jan 10, 2013 | Heating & Cooling
We need to change the heat exchanger for my Goodman Heat Furnace model no.-GMP 075-3
Not an easy task! Take many pictures as well as draw out and mark which wire went where. You will have to remove everything from inside the cabinet to get to the heat exchanger. It may be easier to replace the furnace. If you are paying a professional to do the exchange, figure three hours if they have done it before, if not figure 5 to 6.
Apr 02, 2011 | Goodman Heating & Cooling
I have a 1991-93 Goodman GMP 075-4 furnace. The other night I adjusted the temp to have it kick on, everything sounded okay, it never lit. I have checked the ingniter, it has continuity. WHat else should I...
Look at pressure switch and inspect the tubing for any water logging, crimps, or cracks. Also ensure there are no obstructions in the vent line.
Is the ignitor glowing at all? Did you test the voltage going to the ignitor?
I hope you find this information to be very helpful to you moving forward. :-)
May 10, 2010 | Goodman GMS90703BXA Heater
Goodman furnace\ blower comes on,unasked
Sounds like the fan switch on the furnace is set to low. Turn power off to furnace, take door off of furnace look for a fan switch, it may be a fan - limit together. The limit settings should be approximately 160° to 200°, and the fan settings should be about 100° to 140° set it to 120° it it's already set there then you probably need to replace it.
Aug 03, 2009 | Heating & Cooling
Twinning problem
Switch the leads and also make sure that you have a good ground.
Mar 30, 2009 | Goodman Heating & Cooling
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
398 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
