Question about Kenmore 63942 Dryer
I have an electric kenmore dryer, model #110 63942101, and it continually shuts itself off after running only moments. dryer will restart on no heat or after sitting a sec. There is no blockage in exhaust...any suggestions?
SOURCE: kenmore heavy duty clothes dryer will not heat
most problems with dryers not heating is the thermo fuse is blown. bout 20 buck to replace it looks like a small white flat football. but most likely if it went out that means the the high temp thermostat is messed up too
Posted on Feb 07, 2008
  • 131 Answers
SOURCE: Dryer runs but doesn't heat up when sttings call for heat.
You may need to do some troubleshooting. This can be done with the machine unplugged - you may have to activate the start switch, belt switch (if it has one) and the motor centrifugal switch manually.
Tip for troubleshooting 220v systems - clip one lead of a ohm meter to either L1 or L2 on the terminal block. It doesn't matter which one. According to the tech sheet (under console) follow the path for current from your clipped terminal, through the heating element, to the opposite terminal. All the readings should be less than 100 ohms, until you reach the failed part. Confirm failure by disconnecting a lead from the suspected part, and test only that part.
Live troubleshooting is sometimes slightly easier, but much more dangerous than the procedure described above. - It is definitely not recommended for beginners, or for professionals, if it can be avoided.
Posted on Mar 10, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Posted on Feb 09, 2009
  • 1122 Answers
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore dryer model 96281100 runs but don't dry(no heat)
If the Thermal Fuse were blown, the dryer would not run at all. If your dryer runs, but does NOT heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need. The heating components are usually listed under the "Bulkhead" section.
NOTE: In many cases the problem is NOT the heating element. The heating element has protection devices that are designed to regulate the heat temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Read through the information I provided and, if you have any questions, please post back with your complete model number (located on a nameplate around the door opening) so I can provide you with better service. I hope you find this information is helpful.
Posted on Feb 27, 2010
My kenmore dryer model#110.61202013 wont heat up
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating
Feb 22, 2015 | Kenmore Dryers
Kenmore gas dryer model 110 775 42600 won't heat what is wrong
ELECTRIC Dryer no heat or little heat:
Jul 04, 2014 | Kenmore 500 6952 Dryer
I have a kenmore quietpak 9 dryer model 110.85866400, the dryer blows air but does not heat, how do I repair it?
Jul 04, 2014 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Electric Dryer Model 66812. The motor runs, but the heat doesn't come on ... so it's not drying. What's wrong? Is it worth fixing? Estimate to fix?
May 12, 2014 | Kenmore 62802 Electric Dryer
My kennmore dryer model # 11062912100 won't heat up what is the possible cause?
May 05, 2014 | Kenmore 62602 Electric Dryer
Dryer does not heat up. What can it be, and how
If it is an electric model then look for restricted venting and check the high limit mounted on the heating element and the element itself for continuity.
If it is a gas model check the flame sensor and ignitor for continuity. Check the blower housing duct fuse for continuity...read more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 30, 2009 | Kenmore 64652 Electric Dryer
Kenmore Model 11070852990. Will not heat. Not
could be three things. 1st) 240v should enter the unit. if 120v is missing then the unit will run but will not heat (on an electric dryer).
2nd) the thermal cut-off is not showing continuity and therefore not allowing voltage to travel to the element. 3rd) could be the element itself not showing continuity.
If it's a gas dryer, it's most likely a thermal fuse or the ignitor. please let me know if i can be of better help. good luck :)
Jul 13, 2009 | Dryers
Feb 08, 2009 | Kenmore 62602 Electric Dryer
Kenmore 63942 Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
