Question about Macally 1 Bay PHR-250CC (0701107485355) FireWire (IEEE 1394), USB 2.0 External Drive Case
My FireWire/USB 2.0 PHR-250cc has stopped responding to my Mac: it is not read/recognized by the computer when I turn it on, and is not listed in Volumes in the terminal. The drive lights up, and the LED will occasionally flash red as though it is working on something. My computer, however, makes no sign a new piece of hardware has been attached. Not sure how to fix this? I've tried changing the connecting wire, no dice. thanks! Laura
2 Suggested Answers
  • 8 Answers
SOURCE: Hp Pavilion dv4 does not see drive. Cant find Win
Try using the Windows XP drivers. It should work under Windows 7
Posted on Feb 11, 2010
Hard Drive not mounting
Check the jumper on each hard-drive.
My guess is that the WD drive has the jumper in the "correct" position, for mounting inside an external case, while the other drives have their jumper set to an "incorrect" position.
Set the jumper to MA(ster), not to SL(ave), nor to C(able)S(elect).
Sep 08, 2009 | Macally 1 Bay PHR-250CC (0701107485355)...
Why does my iPod appears on my computer but not in iTunes?
Laptop or portable connecting via USB? "See iPod not recognized when connected to Windows laptop over USB for more information. Your computer doesn't meet iPod system requirements Make sure that your computer meets the system requirements to use iPod for Windows. Your iPod displays an exclamation point folder or sad iPod icon, or doesn't appear in iTunes or My Computer If your iPod displays a folder with an exclamation point icon or a sad (unhappy) iPod icon on its screen, or if your iPod doesn't appear in iTunes or My Computer, follow these instructions to resolve the issue. Your iPod isn't formatted for Windows iPod for Windows Software only recognizes iPod for Windows. You cannot use iPod for Macintosh with a Windows PC. To see which platform your iPod is formatted for, follow these instructions. Your iPod isn't connected to a high-power USB port If you're connecting an iPod, iPod mini, or iPod shuffle to your Windows computer, make sure that you're connecting it to a high-power USB 2.0 port on your computer (not a low-power one such as the USB port on your keyboard or bus-powered USB hub). Typically, USB 2.0 high-power ports are located directly on your computer. Try connecting your iPod to another USB port on the computer (or to a self-powered USB 2.0 hub that's connected to a high-power USB 2.0 port on your computer) if the computer still doesn't recognize your iPod. Alternatively, if your computer has a FireWire connection, try using that instead. If you're connecting an iPod, iPod mini, or iPod shuffle to a Windows laptop computer through USB, connect the laptop to a power outlet before connecting your iPod. You're not using a WHQL-certified IEEE 1394 card If you have a FireWire (IEEE 1394) card installed in your computer and are using it to connect your iPod, make sure that the card is Windows Hardware Quality Labs (WHQL) certified. If it isn't, your iPod may not be recognized, or you may not be able to send music to the iPod. If you're not sure about your card's WHQL certification, check the inbox material that came with your FireWire card or contact the card's manufacturer. You can view a list of WHQL-certified cards on the Windows Hardware Compatibility List website. To view this: Go to the Windows Hardware Compatibility List website. Enter All Products in the ""Search for"" field. From the Product Categories pop-up menu, choose 1394 Controller. Click the Search Now button. Note: Windows XP information is not listed on the initial search screen, but is listed when you click on an individual card. You can also check the list of recommended FireWire and USB cards that have been tested by Apple with iPod and Windows XP. (Apple sells FireWire cards that are compatible with iPod at the Apple Store.) To rule out an issue with your FireWire card, try connecting a different FireWire device to the card to see if your computer recognizes it. Your connections aren't secure Make sure that there i
Oct 02, 2005 | Apple iPod nano
Maybe radical but this worked for me.
My computer-select ipod,Right click and format disc (fat 32)
Once refomatted plug in to computer and start Itunes.
Click on Restore to factory settings, At the end of that you will need to plug it briefly into an ac outlet.
Reconnect ti computer and start Itunes.
Sync with library.
This worked for me after trying everything else I could fine failed.
My error when I ran diagnostics said "one or more sync tests failed."
Sep 28, 2005 | Apple iPod nano
Why isn't the charging icon always animated (flashing)?
For Mac users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes.The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. If the charging icon is flashing and your computer doesn't recognize it,Can't see your iPod in iTunes or or the Finder? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB or FireWire port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or in the Finder when you connect it to your Mac. The most likely causes are listed below in logical order (you'll find information for both USB and FireWire iPod connections). Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. Battery depleted? If you have an iPod nano, click here to find out what you'll see if the battery is depleted. If this is what you are seeing, wait 10 minutes while iPod nano is charging. You're using USB instead of FireWire If you use USB instead of FireWire to connect, it won't appear in iTunes unless you update to Mac OS X 10.3.4 or later. If you can't update your software, then use FireWire instead. Note: iPod shuffle and iPod nano are compatible with USB only. With any model of iPod (except for iPod shuffle), if you connect it to a low-powered USB port (such as one on your keyboard or bus-powered USB hub), the following alert may appear: If you click OK, your iPod won't appear. Make sure that you connect your iPod directly to one of the computer's USB ports or to a powered (as in connected to an electrical outlet) USB hub. Your Mac is sleeping Your Mac must be awake to recognize iPod. Be sure that you wake the computer before connecting your iPod. Your Mac doesn't meet iPod system requirements Make sure that your Mac meets the iPod system requirements. Third-party FireWire and USB cards and PC cards may not work and are not supported by Apple. You're missing some system sof
For Mac users "iPod does not appear in iPod Updater or iTunes in Mac OS X Under some circumstances, iPod appears in the Finder in Mac OS X, but does not appear in the iTunes Source list or does not appear in the iPod Updater. Symptom iPod's disk icon appears in the Finder, but it does not appear in the iTunes Source list or in the iPod Updater. Note: The iPod may appear in iTunes, but not in the iPod Updater. Important: If you are using iPod shuffle, you must have 10.2.8 or 10.3.4 or later to connect it to your Mac over USB. Other iPods require 10.3.4 or later Products affected Mac OS X iPod (5 GB) iPod (10 GB) iPod (touch wheel) iPod (dock connector) iPod mini - USB requires Mac OS X 10.3.4 or later. iPod mini (Second Generation) - USB requires Mac OS X 10.3.4 or later. iPod (Click Wheel) - USB requires Mac OS X 10.3.4 or later. iPod with color display (including iPod photo) iPod nano Solution iPod nano Certain models of single processor Power Macintosh G5 computers may show iPod nano mounted in the Finder but not recognized in iTunes. If this happens to you, try restarting your computer and Setting Energy Saver to highest performance and turn off hard disk sleep. If you have an iPod nano, but don't have a G5, then follow the other steps below. Mac OS X 10.4.x Perform an archive installation of Mac OS X10.4. Mac OS X 10.3.x Navigate to /System/Library/Extensions. Drag the iPodDriver.kext file to the Trash (you will be required to enter an administrator account password). Download and install the Mac OS X Combined Update 10.3.9. Restart the computer when prompted to do so by the installer. Connect the iPod. Mac OS X 10.2.8 and earlier To resolve this issue with earlier versions of Mac OS X, you'll need to delete one file and reinstall iTunes. Follow each of the steps below. Step 1 Delete the file using Terminal Warning: The steps below describe how to remove a file by entering commands in the Terminal application (located in the Utilities folder inside of the Applications folder). Users unfamiliar with Terminal and UNIX-like environments should proceed with caution. The entry of incorrect commands may result in data loss or unusable system software. Open Terminal (/Applications/Utilities). Type: sudo rm -R /System/Library/Extensions/iPodDriver.kext Press Return. Enter the administrator account password when prompted. Quit Terminal. Restart the computer (From the Apple menu, choose Restart). Step 2 Reinstall iTunes Download the latest version of iTunes from the iTunes download page. Install iTunes. Restart the computer after the installation has completed. Connect iPod. Step 3 Delete the iPod.plist file Remove the following file in the your home directory and launch the iPod updater again ~/Library/Preferences/com.apple.ipod.plist "
Why my iPod doesn?t appear in iTunes?
Macally 1 Bay PHR-250CC (0701107485355) FireWire (IEEE 1394), USB 2.0 External Drive Case Logo
231 people viewed this question
Top Macally Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
David
David
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
