Question about Miele Ovens
We have a EBG 2692 UT oven 15 years old ( Imperial) the oven was in proces 180 C , after 20 min slowly power off no light inside , no display , nothing the rest of equipment was still working. How is helping us? Wie weet meer over de EBG 2692 UT?? Oven 15 jaar oud (imperial) hij werkt niet meer.. Oven stond aan en ging langzaam uit en er brand niets meer. Zowel in de oven als schakel paneel. Gewoon dood als een pier. wie kan ons helpen?
SOURCE: Imperial Singal Gas Convection Oven with Digital Controls
NO SE APAGA EL PILOTO
Posted on Jul 21, 2008
  • 13433 Answers
SOURCE: OVEN BLACK-OUT!
Read this troubleshooting page, it may provide you with a solution to the problem.
http://www.repairclinic.com/0088_13_1.asp
Posted on Aug 03, 2008
SOURCE: our imperial convection oven will not light. NO ignition
Your door switch is not reading that the unit is closed
Posted on May 28, 2010
SOURCE: turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Posted on Oct 03, 2010
SOURCE: I have a Frigidaire Custom Imperial double oven
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Posted on Dec 11, 2010
Hi I have an old 1970's St.george imperial wall oven and I can't turn the roast light off which makes the oven heat up to under half the heat it normally does. How do I turn the roast light off?
since I have no model or serial, I assume this is an electric oven based on the description provided. this is usually an indication that the heating element has gone bad. possibly having a short to ground which completes a partial circuit in turn giving you heat and a light. I would look in this direction first.
Jan 04, 2018 | Imperial Ovens
Hi my parents have a 10 year old Electrolux oven eob63100k it works for about 50 mins then turns itself off and after approx 15 mins comes back on again all by itself any ideas?
Thermostat issue when it reaches heat its set to it should turn off and then come back on when it drops below that temp
check if thermostat is clean
Sep 26, 2017 | Electrolux Ovens
I am looking for a glass oven door of my imperial oven mine broke BML 3367 UT 00 fabricnr.00/1138 anu
have you tried to find one on applianceparts.com? If not I would try there.
May 04, 2014 | Imperial Ovens
What causes the flame switch to cut out ion an Imperial ICVD convection oven
This flame sensor switch is a safety device that only allows the main valve to open after is is satisfied there is a pilot flame. Otherwise if there were no pilot and the main valve was allowed to open, the inside of the burner area would quickly fill with gas and pose an exposion hazard. The original capillary tube type switch is obsolete and a new electronic unit conversion kit is available. Contact Imperial tech support for more information
Apr 29, 2012 | Imperial ICVD-2-HH Turbo-Flow Gas Double...
Hotpoint BD 42 Oven, main oven fan turning slowly and oven is not heating up to temperature
Hi you will to have a tester , start off by checking power at the outlet , if you have the 220 volts then we need to check the elements inside the oven, you may a have a bad element and a bad fan , after checking power get bacl to me , also need model number and serial number
Dec 01, 2011 | Ovens
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
Ovens Logo
331 people viewed this question
Top Miele Ovens Experts
Paul Bade
Marvin
Marvin
Are you a Miele Oven Expert? Answer questions, earn points and help others
