Question about Amana Heating & Cooling
Amana 88 SSE Air Command Gas Furnace Model GUICO9OFA50 Light blinks three times says pressure switch stuck open. I would like to know if I can fix the problem or replace a part. I was't able to jump it at the furnace. I have some training in HVAC but I don't have a manual on my equipment.
5 Suggested Answers
huuum
  • 750 Answers
SOURCE: Amana Air Command 80, 20
Hello Bob,
Welcome to fixya,
You said, Amana Air Command 80, 20 years old.
Electronic ignition.
Furnace does not start.
Good power to furnace.
Thermostat properly set.
Where do I start looking?
Sounds like you possibly have one or more bad jets if the unit is a gas furnace!
Let me know how it goes.
Huuum
WOW, listen to this story!
I understand you are looking for the solution to fix your furnace your self.
But I want to tell you my story about my smart wife and our furnace.
When we moved into this house the furnace was 20 years old and she suggested that we put a new one that it will save us money.
I laughed at her and replied if it's not broken why fix it!
Six years later it finally broke down and I replaced the whole furnace and central air unit with a new one.
Our utility bill went down $100 dollars a month!
That's $7200. that I lost over 6 years due to not respecting my wife's power of reasoning!
If you can afford it or can get financing replace any unit 20 years old and it will pay for it self.
Can you imaging $1200. a year for 20 years is $24,000 dollars I'm saving with a new and efficient unit.
Do the math!!!!!!!!!
Thank You,
Huuum, Hope I gave you some good fatherly advice.
Please remember to leave a rating
Posted on Oct 13, 2008
  • 85 Answers
SOURCE: my amana 80 sse furnace
Turn off breaker. Turn it back on. If furnace is completely dead still, change your transformer. It's cheap..
Posted on Dec 11, 2008
tborn6
  • 700 Answers
SOURCE: furnace manual
here's the link for your problem and I hope that it helpshttp://johnstonesupply9.com/TechDocs/Amana/Gas%20Furnaces/GCIC%20Gas%20Furnace/GUIC%20GCIC%20TECH%20INFO.pdf Thanks for unis FixYa!
Posted on Dec 23, 2008
  • 34217 Answers
SOURCE: My furnace model dgaa056bdtb is blowing cold air I've had it on for an hour and it's still blowing cold air and we've been without the furnace for a while using heaters and oven but it's still cold
Something is preventing the burner from firing.
Posted on Jan 08, 2017
Amana model ACS4250A (slide in). How do I remove the front panel?
[PDF]80-90 FURNACE SERVICE MANUAL.pdf - Johnstone Supply
johnstonesupply9.com/.../Amana/Gas%20Furnaces/GCCA%20Gas%20Fu...
Instructions. This manual is to be used by qualified HVAC technicians only. Amana .... Gas Furnace Upflow/Horizontal Induced Draft A Air Command 80 SSE.
Nov 06, 2015 | Kitchen Ranges
Furnace problems
On - OK
1 Blink - Ignition failure. Check Gas flow, gas pressure, gas valve, flame sensor.
2 Blinks - Closed pressure switch. Check pressure switch (stuck in closed position).
3 Blinks - Pressure switch - failre to close. Check venter, pressure switch, vent blockage.
4 Blinks - Open limit switch. Main limit or aux limit are open. (My comment - Means overheating in chamber. Often result of blocked intake air. Bad filter. In my case, plastic wrap had been sucked into the intake. )
6 Blinks - False flame sensed. Check sticking gas valve.
Rapid continuous blinking - Incorrect twinning, incorrect primary polarity. Reverse transformer secondary leads, reverse primary wires.
Closed pressure switch can be from dirty combustion vents, bad chamber pressure - like missing screws, maladjusted gas pressure, failing pressure switch, loose hoses, moisture in the hoses or fan blades The switch need to be closed to ge the unit to work
Jan 23, 2008 | Goodman GMS90703BXA Heater
Amana furnace
Are you sure the control board is good? I would look at that before going elsewhere.
May 02, 2017 | Heating & Cooling
"switch stuck open"
Pressure switch stuck open , check tubes are on tight not split on the connections to the pressure switch, sound like you will need a new one
Dec 31, 2011 | Dayton Gas Furnace Heater
Have a Amana Distinctions model GMH800453ANAB furnance light indicator blinks 6 times . Which reads open Roll out. What is this and can I repair myself.
Hello, A roll out is a switch that senses the temp near the burners. If the the flame pattern in the burners is abnormal that roll out switch will open and turn off the furnace for safety. You can try cleaning the burners yourself and see if that will fix the problem, make sure you turn off the power and gas to the Furnace when working on it. However, if that does not fix the problem Iw ould call a HVAC technician to inspect the furnace, sometimes it could be low combustion air or a problem with the gas input to the burners.
Mar 07, 2011 | Amana Heating & Cooling
Amana Air Command 80 SSE gas furnace will not stay running
In the path of the flame on the last burner that starts, there will be a small rod. That rod is the flame sensor. Take a scrub pad and polish it. Also check the electrical connection that goes back to the circuit board. Disconnect any ground wire from the circuit board to furnace cabinet, sand it and replace it.
Mar 14, 2010 | Heating & Cooling
My furnace tries three times then red light blinks once
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Your furnace has a diagnostic chart on the reverse of the lower panel incorporated in the wiring diagram. One blink tells you that it is a failure but wont tell you where to start looking.
Nov 27, 2009 | Goodman GMS90703BXA Heater
Furnace dont have heat
pressure switch stuck take off hose **** on it then put back on
Dec 21, 2008 | Amana PTC153B35AE Air Conditioner
Furnace manual
May 26, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
77 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
