Question about Cameras
My response to the power question
Yeah the camera powers on just fine, I can even play the tape back on the lcd screen, just no image when I go to record.
  • 4,472 Answers
Something happened with the recording part of the camera. Servicing it will definetly cost less then a new camera.
Hope this helps,
Lee
Posted on Jun 16, 2008
My canon camera seems to work fine in record mode. The LCD shows the video and the timestamp, and tape is moving. Yet in playback mode no matter what Tape I use (even if I know the tape has video on it)...
The playback head is dirty. Insert a brand new tape into the drive and perform a record, through the entire tape until it reaches the end. Then play a pre-recorded tape.
Nov 13, 2010 | Canon VIXIA HV30 DV Camcorder
No response when i press play
hi
reset your camin its default condition.
change your battery.
scan your memory card and cam memory with antivirus.
connect it to pc.
Mar 23, 2008 | Panasonic Palmcorder PV-DV103 Mini DV...
Some of my Hi8 tapes play in fastforward motion along with the audio, but the other tapes play just fine. What can I do?
Clean the header of your camera. Buy a different camera to play those tapes. Try looking for a tape cleaner and tape lubrificant. Some tapes go so dry and overheat while playing on your camera that they end up on a blue screen and only play on FF and most of times not even that.
A good advice is to keep your tape cold, camera cold and try again.
Dont heat your tapes.
Also try battery playback, so it does not over heat with the power supply on.
Oct 01, 2010 | Samsung Electronics - Others
Same problem. The LCD screen works, i.e. I can see and manipulate the menu, etc. And it will play back one of my many tapes (just the one). Full power or battery, night shot off, when I put it in record...
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's a common problem as this cable is bend each time when we open the LCD screen, so the cable become faulty.Good luck
Meggita
Oct 01, 2009 | Sony Handycam CCD-TRV608 Camcorder
Lines through the tape when recording or playing back
It could need a head adjustment. Any camera store can do that for you.
Feb 11, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
TAPE ACCEPTANCE
Amazing! I was just about to throw the camera through the window when I decided to look on here for a solution. A few love taps on the non-tape side....POOF! I have a working camera. Thanks!
Nov 17, 2007 | Canon ZR100 Mini DV Digital Camcorder
Recoding and viewing
sir , the lcd flap of the camera has been spoilr\ed due to this the image is not coming on lcd , only u have to take the image through view fider , lcd fpc has to be changed / repaire u can contact me also omaxphoto@yahoo.co.in
Mar 28, 2007 | Sony CCD-TRV228E Camcorder
My camera will not turn off !!!!!
WOW: All three Solutions Work Fine.
I Removed the 6 small bolts and took the camera apart.
lifted the tape and cleaned the contacts u;nder the tape with alcohol, let them dry then replaced the tape, lineing up the contacts on the tape with the ones on the body of the camera. Put the camera back together and put back the 6 bolts, inserted the batteries and presto: the camera worked. Thanks for the info , it really worked. Wes Reed
Sep 11, 2006 | HP Photosmart M407 Digital Camera
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
